03-12-2010, 12:39 PM | #1 |
Member#: 59238
SWIC
crawford AOS v2 FMIC STi instructions needed
anyone who has installed one of these chime in on the sti v2 crawford aos
03-12-2010, 02:34 PM | #2 |
Member#: 100834
BAIC
Vehicle:2006 Subaru STI Steel Grey Metallic |
I just put mine on the other day. The only difference is you run the coolant line from the reservoir on top of the intake manifold to the AOS, and then from the AOS to the turbo. All other tubes remain the same. The issue that I had was that the pipe off the AOS that goes to that reservoir on top of the IM points directly at my Perrin fmic pipe lol. I just ran a longer coolant line and went under my IC pipe.
04-27-2010, 08:43 AM | #3 |
Member#: 182971
Vehicle:2007 wrx OBP |
aos
Does the v2 aos stop the gunky gooey stuff from forming inside the aos??
04-27-2010, 08:43 AM | #4 |
Member#: 182971
aos
does the v2 aos stop the gunky gooey stuff from forming inside the can?
10-11-2018, 08:15 PM | #5 |
Member#: 171039
Vehicle:95 RSTi Type-R LTD Mystic Blue Pearl |
where does this AOS bolt to, the firewall ?
Similar Threads | ||||
FS : WA: Crawford AOS V2 | Bariga | Engine/Power/Exhaust | 5 | 06-12-2010 08:24 PM |
Crawford AOS for FMIC having any problems? | communik | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 12 | 03-02-2010 03:34 AM |
FS: Used Crawford AOS - FMIC version | kuldud | VIC Private Classifieds | 8 | 01-18-2010 11:32 AM |
Crawford AOS works with APS FMIC setup | IA Performance | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 17 | 09-12-2009 06:38 PM |
Crawford AOS + APS FMIC = Good Fitment with photos | IA Performance | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 09-09-2009 05:11 PM |
