Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Old 02-13-2008, 01:57 PM   #1
'93Impreza1.8T
Member#: 171092
1993 Impreza 1.8T
Default Cable Clutch To Hydraulic Clutch Swap?
I'm looking to use a stronger cluch now that i'm turbo and i wanted to know what do i need to do a complete cable to hyrolic clutch swap?
p.s. Im running a ej18 sohc with awd 5spd tranny from a '93 impreza wagon ej18 n/a.
'93Impreza1.8T is offline   Reply With Quote
Old 02-13-2008, 03:11 PM   #2
stimko68
Member#: 85396
You will probably need a new clutch pedal, as well as the slave cylinder, master cylinder, and clutch reservior, along with all of the hydraulic lines to connect everything. You may be able to use the existing clutch switch (which just sends a signal to the ECU telling it that the clutch is engaged/disengaged), but you will also need a new clutch fork. I think the hydraulic clutch forks are a bit larger, but I'm not sure on that one. Also I'm not confident on the interchangeability between model years on the clutch components. Best thing would be to find a wrecked Impreza of a similar model year and grab all of the realted hardware off of it.
stimko68 is offline   Reply With Quote
Old 02-13-2008, 03:18 PM   #3
'93Impreza1.8T
Member#: 171092
1993 Impreza 1.8T
thanks i've looked around in my area (satx) and have not yet seen any '93 impreza or legacy with hydraulic clutch they all have cable.
Old 02-13-2008, 03:27 PM   #4
stimko68
Member#: 85396
Yeah, I think that only the newer Imprezas have switched to a hydraulic setup. Try to find an 02+ wrecked WRX (not RS) because those clutch components may fit. The only real issue you would have is the clutch fork. I know that the transmissions changed over the years, and I don't know if the clutch forks got longer/shorter or wider/narrower, etc. I figure as long as whatever clutch fork you get can fit into the throwout bearing on your clutch, and the shaft that goes into the side fits as well, you shouldn't have a problem, since all of the other componenets can be custom fitted to your ride. Good luck!
Old 02-13-2008, 04:50 PM   #5
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
OP: you can use any pedal assembly/master cyl from a non cable type.
you will need any naturally aspirated slave cylinder, NOT like what the previous post says (WRX slave and fork are for pull type clutches. you need push type.)
Hurley 2.5 WRS is offline   Reply With Quote
Old 02-13-2008, 05:26 PM   #6
vica153
Member#: 76586
2006 9-2x Aero
You realize that the forks are not interchangable, right? So you need a transmission that is meant for a hydraulic clutch.
vica153 is offline   Reply With Quote
Old 02-13-2008, 05:54 PM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
Originally Posted by vica153 View Post
You realize that the forks are not interchangable, right? So you need a fork that is meant for a hydraulic clutch.
Fixed it for you......
Jay Storm
Old 02-13-2008, 06:53 PM   #8
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
disscent!
stay with the cable if your keeping the push style transmission
the act street will hold fine
Old 02-13-2008, 08:43 PM   #9
'93Impreza1.8T
Member#: 171092
1993 Impreza 1.8T
thanks every1 thats all i needed to know.
Old 03-26-2008, 03:15 PM   #10
mewantsubie
Member#: 161890
2003 Impreza WRX Wag
96 Impreza OBS
i've got a 98 legacy gt transmission i am putting in a brighton and i was wondering if it would be better to keep the cable or go hydrolic. I wasn't sure if the cable clutch fork would fit in the tranny and in the legacy throw out bearing. Does anyone know?
mewantsubie is offline   Reply With Quote
Old 03-26-2008, 07:31 PM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
There is no reason to swap to a hydro setup, unless you're also swapping to a pull type setup. There are push type clutches strong enough to break gears already...the hydraulic throw out bearing will do nothing to make the clutch stronger, weaker, or easier to live with.
Jay Storm
Old 03-30-2008, 02:57 PM   #12
DeMoe Aurelius
Member#: 162900
2005 Legacy GT 2.5
Atlantic Blue Pearl
Thumbs up
Jay Storm
Jay is right, and always gives good answers.
One of the major differences of the hydro and cables transmissions is feel. Cable to me has like a more direct feel, so when you come off quick it disengages quick, depending on how tight or loose it's adjusted. Hydros are fluid driven and allows quicker shifting a little more smoothly. I'm doing my swap cause I'm getting the tranny with the engine, and I hate the jerk of a quick shift with the cable. Thats just me though, even though The jerk is the power going to the ground I want it smoother when I shift. I dont want the power to shock and break anything, like I did with my old cars.
DeMoe Aurelius is offline   Reply With Quote
Old 03-30-2008, 07:43 PM   #13
DerrickRH
Member#: 75078
2011 Forester 2.5X
Dark Gray Metallic
yeah there is no reason to try and switch hydraulic clutch setup when you have the cable set up already.
DerrickRH is offline   Reply With Quote
Old 03-29-2017, 03:08 AM   #14
Preston138
Member#: 453566
1994 Legacy Turbo
Blue/Grean
Has anyone put a hydraulic setup in a first gen legacy? I'm trying to find out what pedals I can use.
Preston138 is offline   Reply With Quote
Old 04-21-2017, 07:38 PM   #15
Sublimejoe
Member#: 74722
1993 RHD Legacy BF
Championship White
I have done this
Sublimejoe is offline   Reply With Quote
Old 05-16-2017, 10:08 AM   #16
Angelo_Wrx
Member#: 467747
Its going to be alot of work but yes it can be done
Angelo_Wrx is offline   Reply With Quote
Old 05-16-2017, 04:04 PM   #17
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
you can probably just take the parts from a 2.5l outback or "legacy outback" and swap it to the 2.2l. it depends on if your transmission has the bolt holes to mount the slave cylinder. pretty sure everything else is pretty similar just pop the new fork over the ball probably.
i have never done it take all that with a grain of salt. although i have done clutch jobs on old legacys and outbacks with both cable and hydro clutch and they are the same in the way the throwout and pivot work.
CarmelValleyWRX is offline   Reply With Quote
cable to hydraulic clutch swap (looking for parts) driftingouttosea Legacy Forum 3 03-29-2017 03:10 AM
FYI: cable-to-hydraulic clutch swap (long) wac Transmission (AT/MT) & Driveline 13 12-03-2006 09:46 PM
WTB: cable-to-hydraulic clutch swap parts not8player Private 'Wanted' Classifieds 3 04-25-2006 04:22 PM
Cable to Hydraulic Clutch Swap? cybin Subaru Conversions 7 05-28-2004 12:15 AM
stock clutch to ACT clutch auricom Transmission (AT/MT) & Driveline 9 10-01-2001 07:04 PM
