Welcome to the North American Subaru Impreza Owners Club Sunday April 11, 2021
Old 10-20-2006, 02:33 AM   #1
MGAMAN
Member#: 24671
2010 Audi S4 PP
2006 R1 - 06/08 hybrid
Default 02 to 06 front end swap and wiring question
So...my WRX goes in soon for some long awaited front end repairs, during the time its sat witha busted front end its gone through a built motor swap, tranny, and all sorts of wonderful things, but its still a sad sad wrx lol.
anyways: im currently running a set of JDM 02 headlights with hax'd wiring harneses. The front end will be having the bumper, fenders, and hood replaced. I was curious if anyone knows, or has experienced, how hard it would be to do an 06 front end conversion. Since the parts are available from subaru im not worried about cost or sourcing them, just mostly curious on the headlight wiring, and if the panels will bolt on the same as the 02 panels.
MGAMAN is offline   Reply With Quote
Old 10-20-2006, 11:00 AM   #2
sheepdog
Member#: 93773
1995 Flat Khaki GC8
2011 STi Wagon
Theres a thread in this very forum about this. Its more work than just body panels, but can definitely be done. Wiring is apparently not that big of an issue.
sheepdog is offline   Reply With Quote
Old 10-20-2006, 06:55 PM   #3
MGAMAN
Member#: 24671
2010 Audi S4 PP
hmm, I tried a search for it earlier before posting but couldn't find anything, I'll try again.
Old 10-20-2006, 06:55 PM   #4
MGAMAN
Member#: 24671
2010 Audi S4 PP
and hopefully it wont be a problem, the inner fender on one side is being replaced along with bumper beam and most other panels, so ideally they should be able to replace what they need.
Old 10-24-2006, 12:45 AM   #5
DaFastOne
Member#: 19396
02/6 FrankensteinWRX
black
im in the process of converting my 02 to an 06. i just order my bumper and fenders. let me know what you find out and i will keep you posted on what i find.
DaFastOne is offline   Reply With Quote
Old 10-26-2006, 02:30 PM   #6
1VIPWRX
Member#: 107554
yellow
i just emailed charge speed and they said that there doing a swap right now. its gona take a while because of time
1VIPWRX is offline   Reply With Quote
Old 10-27-2006, 01:48 PM   #7
DaFastOne
Member#: 19396
black
this is what i have done so far.
I put on the fenders and they seemed to align up pretty well as just a bolt on. I also put on the sliders, which attach to the front bottom portion of the fenders.
Now im kinda stuck on the corner brackets, this is the item that holds the head light in its place. This does like to bolt on to the stock side panel of the bug eye. so i order a new one off the 06 w/ a new upper tie bar.
originally i was going to just modify it but then i was thinking to myself that if i ever got in a accident then it would be harder to fix the car w/ all the modifications done to make the front bumper hold up.
Oh the front bumper beam had to be taken off it seems like it was in the way of the corner bracket.
but i did manage to get the fornt bumper on, just to see what it looks like.
Old 10-27-2006, 02:40 PM   #8
FatStraws
Member#: 57954
04 No More Subaru
Former ZeroSports Stg. IV
return the bumper and get a Zero/Sports front bumper. the wya i see it is, if you're going to swap, swap it right!
FatStraws is offline   Reply With Quote
Old 10-27-2006, 05:15 PM   #9
DaFastOne
Member#: 19396
black
i was thinking about that. but most body kit on our cars hang too darn low and can easliy get cracked.
Old 11-01-2006, 02:08 PM   #10
DaFastOne
Member#: 19396
black
so today i recieved my radiator support and my corner pieces, i guess its now time to drill out the spot welds.
Old 11-01-2006, 04:21 PM   #11
1VIPWRX
Member#: 107554
yellow
the charge speed web site has a diagram on the 04 to 06 swap. that might help you out.
Old 11-01-2006, 04:26 PM   #12
DaFastOne
Member#: 19396
black
yeah i saw that, unfortunately mine is a 02 so its alittle different than the 04, but i do have that link for some reference.
here is the link we are talking about.
http://www.chargespeed.com/english/gdb-cde-f-e1.htm
Old 11-01-2006, 10:14 PM   #13
JeremyRS
Member#: 65126
00 Leggy Wagon
99 Silverado, 06 HD
JeremyRS is offline   Reply With Quote
Old 11-07-2006, 11:32 AM   #14
DaFastOne
Member#: 19396
black
I drlled out all the spot weld and started to mock up everything. lets just say on the sheet metal located on the sides, alot of it needed to be cut. The one off charge speeds website showing you need to cut the side is a joke.
After cutting everything i painted the exposed metal took measurements to make sure everthing is square and rivited the structural sheet metal pieces together. So far so good. I will try and send some pics soon. let just say its not for the faint hearted.
for testing t make sure everything fits i bolt the fender and the bumper. Lets just say it came out better than what i had originally expected, 100% exact fit.
Bolted the fender
Old 11-07-2006, 01:39 PM   #15
1VIPWRX
Member#: 107554
yellow
cool...please post pictures cause am gona be doin this conversion soon.
Old 11-08-2006, 11:37 AM   #16
DaFastOne
Member#: 19396
black
So i got my hood and its looks all good it ligned up w/ no problems, but i noticed a gap between the top of the side fenders and the hood. i careful exzamined the fenders and noticed the place i rivited the radiator support did quite line up that the tip of the fender closer to the head lights is alittle lower. so now i had to take out the rivits and modify the fender bracing so that the radiator support sits alittle lower.
anyhow here are some of the pics of my progress.
Here is where i need to cut lot.
Old 11-08-2006, 03:46 PM   #17
1VIPWRX
Member#: 107554
yellow
nice.. pic's helps me out alot. i have a fmic, i hope that wont cause problems. did you weld the rad support back in?
Old 11-08-2006, 03:55 PM   #18
DaFastOne
Member#: 19396
black
not yet, i had to still finish modifing it. i will take some more pics later on tonite.
Old 11-08-2006, 07:18 PM   #19
DaFastOne
Member#: 19396
black
oh I didnt weld anything in I rivited them on.
Old 12-17-2006, 07:13 PM   #20
DaFastOne
Member#: 19396
black
ok here is my car as of today.
By the way I also updated the back by putting on 04-05 tail lights.
Old 12-17-2006, 10:29 PM   #21
1VIPWRX
Member#: 107554
yellow
good job man..i will be done soon i hope
Old 12-18-2006, 11:33 AM   #22
Robstunner
Member#: 134222
2015 WRX Limited
ISM
damn. so those 05 tails fit w/ no need for messing the the bumper or what?
Robstunner is offline   Reply With Quote
Old 12-18-2006, 11:37 AM   #23
DaFastOne
Member#: 19396
black
well the tail light doesnt fit 100%. you first need to cut the bumper alittle to get the rounded part in. there is a small gap between the tail lights and the car.
But its pretty damn close
Old 12-18-2006, 11:51 AM   #24
Robstunner
Member#: 134222
2015 WRX Limited
ISM
can i get up close shots of the tails at the curve?
Old 12-18-2006, 03:28 PM   #25
DaFastOne
Member#: 19396
black
yeah sure, i will try to take them tonite
Is it possible to do an 06 to 05 front end swap? mobilezen Interior & Exterior Modification 20 11-30-2013 05:13 PM
03 to 06 front end swap info please wrx03.4wz Subaru Conversions 16 01-08-2008 04:28 PM
04 to 06 Front End Swap pilotstephen Interior & Exterior Modification 5 08-13-2007 07:47 PM
04/05 Front End ---> 06 Front End Swap - Possible? essteaeye Interior & Exterior Modification 1 07-24-2006 11:59 PM
02 to 06 front end conversion All4bSpinnin Subaru Conversions 2 03-27-2006 06:06 PM
