05-15-2010, 09:33 AM | #1 |
Member#: 226989
STI running gear in a Legacy GT
Good Morning folks,
I am not having luck searching the archives for information on swapping in STI running gear into a Legacy GT. I searched the "subaru conversion" and "2.5L turbo charged engine" forums for "legacy" and "GT" but didn't find anything substantial. I was pointed to this website from legacygt.com as a place that might have info for me. I know this isn't a "Legacy" site primarily, but I still hope there's good info here. Here are some details so as to not remain too vague: Vehicle: 2005 Legacy GT (165K for about $6000, I think a good place to start) Donor vehicle: Up for advice, maybe a 2005-2007 WRX STI? If anyone can point me to a thread or website that can give me some good reading I'd appreciate it. I'm going for a poor man's spec.B here I can't find one in my area for under 25K Oh, I realize something like this is not easy, i've been working on cars for 15 years and I'm a electrical engineer so I'm pretty confident I have the skills necessary, maybe not the sanity though
05-15-2010, 10:54 PM | #2 |
Member#: 177
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
its already a poor mans's spec b
swap the manifold and turbo ...get an AP and a tune .. done heads/cams/block are the same already the 6 speed is even easier ... assuming you can find a matching R160 rear end ... what exactly are you asking ? have you been to legacygt.com |
05-15-2010, 11:31 PM | #3 |
Member#: 226989
?? I've been to Legacygt.com, I said in my original post that someone from there thought I should come to this website for information.
I'm simply looking for a build thread of someone who's stripped down a STI and put the parts in a Legacy GT. Based on what I've learned from reading I'm sure it's a fairly straight forward bolt-in swap minus the time getting the electrical correct. But having done similar projects I know the value of someone else's experience. If I can get a heads up on some of the more difficult aspects of the swap I can prepare in advance and shave many weeks off the length of the project. However based on what I've been looking at tonight it seems even wrecked STI's are very expensive. I was hoping to spend 3-4K on one but it seems they are significantly more? If I have to spend 7K+ on a wrecked STI it would be too much, I'd rather rebuild/upgrade a standard GT with high miles but low sticker price. As far as the 6 speed goes, there are several complete setups on EBAY (tranny/ECU/rear end/half shafts/harness etc) all ready to go but those are 3-4K. For me too much just to get the 6 speed into a legacy. My plan "B" I guess would be to re-work a GT. I'm working on a budget of about 12K, so I would like to buy a high mileage GT for 6-7K and invest the remainder in a low(er) mileage engine swap, intake/exhaust/turbo/clutch/tune upgrades and most likely completely go through the suspension. With the ~4K-5K I hope to have left over after vehicle purchase I figure I can do alot with it. If I could find a STI for that great, but for some reason I don't think that's going to happen. But if someone thinks different I'm open to input. Thanks |
05-16-2010, 09:54 AM | #4 |
Member#: 177
your missing the point
THE ENGINE IS THE SAME the 05 lgt has a ej255 which uses the exact same block/heads/cams/injectors as the ej257.. the manifold and TGVs are differnt as i said above some have swapped the manifold over but thats its .. because the lower end is the SAME as for a thread where some one swapped the same engine/wireing in to a car ... there isn't one changing the wiring in a can bus car is swapper suicide, its basically impossible and unnecessary in a 05 lgt as for the 6 speed .. you won't be able to use the rear r180 unless you have custom rear axles made (the R180 has a different bearing diameter) so you will need to find a 3.9 rear end for a 04-06 or a 3.54 for the 06-07 6speed.. The lgt uses rear hubs that are unique to the 05-09 so swapping over the sti hubs is not an option. many people have done this swap at Legacygt.com here is a plan for you lgt aftermarket top mount/front mount (both are produced) injectors 09 sti trubo full exhaust custom tune ~$2500 or less 07 6 speed 3.54 rear diff from 02 wrx new 6speed clutch 05 legacy 4mt drive shaft $3000 = 325 whp +6 speed under $6000 |
05-16-2010, 01:02 PM | #5 | |
Member#: 226989
The rest of your plan looks good, I just wonder can I really get the 6-speed into the legacy for $3K? In addition to getting the tranny/rear diff etc I thought there was also a ECU that controls the center diff? Maybe that's only in certain years of STI's, I don't know, I haven't researched it. I've read posts about stand-alone controllers if one were necessary, but that all adds to the cost. That's good info on the differential/bearings/hubs thank you. I was working on the assumption that all the STI parts would bolt in. I will probably go back to legacygt.com and start looking for threads where people have done just the 6 speed swap and see if I can do it for a reasonable amount. I probably am not looking to go much higher than ~300HP so I might stick with the 5 speed for the time being. |
05-16-2010, 08:48 PM | #6 |
Member#: 177
meh high mileage mostly likely means freeway mileage
do a leak down/compression and mod away ...and start looking for a 255/257 long block one thing to add the 05 lgt has a catted up pipe.. Get it outta there ASAP |
Similar Threads | ||||
STi Uppipe in the Legacy GT | Stryker | Legacy Forum | 14 | 09-12-2013 06:48 PM |
6th gear in a Legacy GT or WRX | WraeDeoHed | Newbies & FAQs | 4 | 12-15-2009 11:54 AM |
'03 WRX/'04 STi center console in '99 Legacy GT | TaurusMcRae007 | Interior & Exterior Modification | 3 | 06-20-2009 03:48 PM |
Sti-ra gears in a Legacy SS case? | spongejosh | Transmission (AT/MT) & Driveline | 3 | 02-16-2008 12:45 PM |
STi intercooler in a Legacy GT | ScoobaSTieve | Legacy Forum | 5 | 04-01-2005 01:25 AM |
