Welcome to the North American Subaru Impreza Owners Club Friday November 15, 2019
Old 06-26-2007, 03:10 PM   #26
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Originally Posted by mxpunk View Post
whats the color code for the paint that you used on those wrx rims?
ya know, i get asked that all the time and i'm not sure what the name is. its the engine enamel spray can...there are only a select colors to choose from in the engine enamel and its the gold/bronze one.
lol, sorry i'm not more descriptive
Justin
GrimmSpeed is offline   Reply With Quote
Old 06-26-2007, 04:28 PM   #27
Spilner
Member#: 63977
2005 STi
Originally Posted by GrimmSpeed View Post
the L fuel tank should work since its an AWD fuel tank
you need the wrx tank for emisions, I needed it for my 96 brighton wrx swap.
Spilner is offline   Reply With Quote
Old 06-26-2007, 04:32 PM   #28
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
and if my state doesnt have emissions testing?
Old 06-26-2007, 05:14 PM   #29
Spilner
Member#: 63977
2005 STi
then you're one lucky SOB, Massachusetts FTL
Old 06-26-2007, 05:14 PM   #30
wagonL
Member#: 84599
hurry up! so that we can run! hahahah...!!! goodluck justin
wagonL is offline   Reply With Quote
Old 07-12-2007, 12:35 PM   #31
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
tried to get those fenders wider so i can fit the wide r-compounds underneath. didnt turn out as well as i wanted but my buddy(pictured) is coming back to help redo them.
Old 07-14-2007, 06:05 PM   #32
RR02wrx
Member#: 99614
12 STi Limited
Hmm, interesting. I'm torn between what to do about my rubbing issues. I'd like to keep the GD track width, and in a perfect world i'd even like to go alot wider with my wheel/tire setup, but I rub so bad right now.. I'm torn between bringing my track back to GC width, or trying to keep the GD and source other ways to deal with it. Im not sure which is worth it or not. I'm running rota torques 17x8 with only 215/45/17's on em'... rubs during hard cornering or when going over good sized dips or potholes. Any suggestions? I'm not sure i'd want to roll/pull the fenders as much as you have here.. but maybe i'll have a different opinion when i've seen the final product.
RR02wrx is offline   Reply With Quote
Old 07-15-2007, 11:21 PM   #33
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
we actually only flared them out about an inch..looks like so much more though. where exactly on the wheel well is your tire rubbing?
Old 07-15-2007, 11:48 PM   #34
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
how much camber are you running?
subbyspeed is offline   Reply With Quote
Old 07-15-2007, 11:57 PM   #35
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
not sure yet. i havent thought that far ahead lol
Old 07-17-2007, 12:16 AM   #36
RR02wrx
Member#: 99614
12 STi Limited
Not on the tread or sidewall, pretty much right where its curved between those two sections. It's not doing much damage eithor really.. I can see a little mark/line it makes but nothing thats really putting the tires at risk. The fronts rub worse because the rears are rolled a bit, but nothing crazy. If I have people in the back seat then the rears will rub kinda bad.
Old 07-17-2007, 03:07 AM   #37
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
have any pics of it?
my philosophy is you can never have enough room under the wheel well when you like driving your car hard.
Old 07-18-2007, 06:15 PM   #38
RR02wrx
Member#: 99614
12 STi Limited
The pic was taken from a lower point I believe so it may (or may not) look like theres a bit more gap than really is..
Old 07-19-2007, 02:34 AM   #39
Numbchux
Member#: 71658
'84 Brat
4" lift and 29" tires
GC + brembos......I think I need a napkin
that's hott!
Numbchux is offline   Reply With Quote
Old 07-20-2007, 03:14 AM   #40
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
for the love of keeping the outside as stock as possible i needed to fit the front mount underneath the stock L bumper. it went ok, there was definitely ALOT more cutting to do to the L bumper cover than the wrx bumper cover. i was able to salvage about 2/3s of the bumper beam(see cut pieces above). i'm very happy with the turn out....looks sooo sleeperish. i do wish i was able to keep the fogs but i couldnt manage to do that...i'll have to think of a way to mount some hellas somewhere.
Old 07-20-2007, 12:10 PM   #41
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
pretty nice fitment of that small aps!!
Old 07-21-2007, 11:40 PM   #42
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
u did a pretty good job, looks a bit cleaner then mine too!
mxpunk is offline   Reply With Quote
Old 07-25-2007, 01:31 AM   #43
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
dang thats a huge fmic mxpunk. nice work fitting it behind the L bumper.
ok i think i'm going this route for the ebrake. will be plumbing the two rear calipers into this...supposedly you can lift it up a 1/2" and it will be full lock!!! :twisted:
http://www.ksportusa.com/products/ebrake.html
Old 07-25-2007, 02:54 AM   #44
GFimpreza
Member#: 40674
94 Impreza wagon
1.8L + 657cc's
I realize that our parking brakes are really terrible, but isn't a hydraulic setup a little bit of overkill?
Should be fun for hairpins though
Good luck with the project!
GFimpreza is offline   Reply With Quote
Old 07-28-2007, 08:05 PM   #45
GeoffM
Member#: 30252
2005 996GT3,'16 3500
04 Ducati 749R #249
nice project man, looks good!
GeoffM is offline   Reply With Quote
Old 07-29-2007, 02:49 AM   #46
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
thanks grimspeed, it is big considering im using a td04 for now..but i should be able to shoot like 22 psi with a td04 through it and not worry about hot air..lol
dude..that eBrake is way sick. looks like tons of fun. cant wait to see how the car turns out!
Old 07-31-2007, 03:07 PM   #47
dresstoimpreza
Member#: 120366
2005 wrx
have you thought of lightening the hood some? i saw on tv once this guy used a weird drill bit to cut out holes in sheet metal on an sti hood, he didnt drill straight through ofcoarse, more like along the support braces that are on the hood.
dresstoimpreza is offline   Reply With Quote
Old 07-31-2007, 05:15 PM   #48
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
yeah actually i was thinking about cutting off the entire second laying support piece on the underside of the hood...i'm just scared i'll nick the top layer and put a freakin hole in it.
Old 08-01-2007, 01:41 AM   #49
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
so we were able to get the engine, drive shaft, rear diff, and all the axles out. all of the axels came out fine except for one major PITA corner...i'm going to have to pick up another hub assembly.
Old 08-01-2007, 02:29 AM   #50
Tbird Man
Member#: 71991
1999 Legacy GT Ltd.
looks nice. i see you have a rear sway bar. that must be something they started in 96 cause my 95 dosent have one. I am really hopeing they bring the new diesel to the US or at least that it is not too expensive to import so I can swap it into my L coupe. I really think, if the engine is up to it, it could be a stronger swap than the WRX or even STi.
BTW, you have a right side marker on your left fender.
Tbird Man is offline   Reply With Quote
Any bored web designers out there want to help with a fun (quick turnaround) project? Asinine Off-Topic 16 06-04-2010 01:53 PM
GrimmSpeed Project L gets new look GrimmSpeed Member's Car Gallery 14 06-13-2008 04:37 PM
GrimmSpeed Project Legacy GT GrimmSpeed Legacy Forum 7 03-05-2008 06:29 PM
GrimmSpeed Project Impreza L/WRX Dynos GrimmSpeed Proven Power Bragging 28 02-12-2008 09:02 PM
grimmspeed project 07sti. subiedubber16 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 10-25-2007 03:41 AM
