Welcome to the North American Subaru Impreza Owners Club Sunday September 23, 2018
Old 03-29-2007, 07:58 PM   #1
dbo
Member#: 114430
2005 WRX/STI
Default Should I Rebuild Motor Or Get A New Shortblock
well i got my oil changed over a week ago. after i got oil changed i noticed a metalic rattle at 3000 rpm. well i finnaly got it into subaru today and they told me it looks like the main bearings are shot. they are going to tear down the motor and let me know. if it is because of oil i am going to try to get the company where i got the oil changed at to pay for it. what do you think i should do? should i have them rebuild motor or should i get a new shortblock? if so what kind should i get? im only looking to spend 3 grand. also i wanted to know how much boost can the stockblock hold? i got protuned and had a max of 1.4 bar and was running my meth once in a while. only used the meth like 7 time other then that i would run on my no meth map.
dbo is offline   Reply With Quote
Old 03-29-2007, 08:05 PM   #2
jays05
Member#: 78165
05 STI 35r + e85
Another one bites the dust right after an oil change...
jays05 is offline   Reply With Quote
Old 03-29-2007, 09:10 PM   #3
wRxbeater11
Member#: 12682
Are you stock?
wRxbeater11 is offline   Reply With Quote
Old 03-29-2007, 09:49 PM   #4
Poolhut23
Member#: 135272
How do oil changes cause this? (serious, not sarcastic question) I want to make sure to check/avoid problems that could cause my **** to break...
Poolhut23 is offline   Reply With Quote
Old 03-29-2007, 10:26 PM   #5
dbo
Member#: 114430
2005 WRX/STI
nope not stock cobb stg 2 with protune and meth and larger tmic
Old 03-29-2007, 10:29 PM   #6
wRxbeater11
Member#: 12682
Im guessing the dealer isint going to cover the car under warranty?
Old 03-29-2007, 10:31 PM   #7
wRxbeater11
Member#: 12682
As for rebuilding depends on how much damage there is on the block. maybe a new crank or maybe it can be machined. Where are you located?
Old 03-29-2007, 10:33 PM   #8
BlowDro
Member#: 112116
2006 WRX
how long ago was ur last change?
BlowDro is offline   Reply With Quote
Old 03-30-2007, 11:03 AM   #9
dbo
Member#: 114430
2005 WRX/STI
i am wating for subaru to tell me how bad the block was damaged. i was thinking about gettin some cobb or cosworth bearings and rods if thats all i need. do you think subaru would install these if i got them? which company do you think is better? i had the oil changed 9 days ago but the 2nd day after i had it changed i was gettin the noise but never had time to take it to subaru untill yesterday. also does any one how much boost the stock block can handle i had a protune and was running 1.4bar is that to much?
Old 03-30-2007, 06:38 PM   #10
Got Boost?
Member#: 113096
06 sti
for 3k, I would rebuild with proven parts
Got Boost? is offline   Reply With Quote
Old 03-30-2007, 06:58 PM   #11
lDeez lNutz
Member#: 94339
2005 STi
how many miles on your car? who tuned it? do you drive it like you stole it? what oil do you use? how often do you change it?
lDeez lNutz is offline   Reply With Quote
Old 03-30-2007, 07:11 PM   #12
BlowDro
Member#: 112116
2006 WRX
i ment how many miles were on the last oil before u had it changed.
Old 03-31-2007, 03:53 PM   #13
dbo
Member#: 114430
2005 WRX/STI
car had 28000 miles the last oil change had 1500 miles on it beacuse i changed oil before i deployed and when i got back i drove the car for 1500 miles then decied to get the oil changed since car sat for 5 months. no i dont drive my car like i stole it if i am driving fast i normally shift before 6000 rpm but i dont drive it like that that much. i use mobil 1 5w-30 used it the whole time i owned car. i also change oil ever 3000-4000 miles. car has never burned oil or anything. i am still wating for subaru to let me know what is wrong they said the should know by monday. do you think they will put aftermarket parts in if i ask them? there is no other place around here that i would trust with my car so cant go anywhere else. i am located in south dakota what parts do you think i should go with? i got my car tuned in colorado i dont think it was the tune cuz car was running great.
Old 04-01-2007, 03:48 AM   #14
Caballero_STi
Member#: 122711
05 STi
That's what I did a better pistons, rod etc.. Should throw a new cluth and some better motor mounts at the same time while your motor out.
Good luck with the built motor.
Caballero_STi is offline   Reply With Quote
Old 04-01-2007, 09:12 AM   #15
drewzter
Member#: 39879
2008 Infiniti G37S
Graphite # 73 FS
Like....Jiffy Lube.. ????
drewzter is offline   Reply With Quote
Where to get cheapest NEW shortblock, oil pump etc juiced04 General Community 8 05-22-2009 09:04 PM
i have these tires, their pretty new, should i keep them or get different ones? wrxsnowstyle Tire & Wheel 3 11-30-2006 11:54 AM
rebuild stock block, STI motor, or cobbs 2.5 shortblock? tribaltalon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 02-17-2006 08:13 PM
upgrade 20g or get a new turbo? fastwrx006 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 02-10-2005 01:13 PM
