08-15-2007, 09:49 AM | #1 |
Member#: 148076
Vehicle:2005 WRX STi |
Why does my car pull to the left and also is it dangerous?
So recently I just replaced my tie-rod for my 05 sti because i got into a accident where i hit the front left driver side. I drove it around the block and i notice it pulls to the left a bit when i let go of the wheel. I also notice my camber is a little positive. My friend looked at the suspension everything seemed fine. So now i need to take it to the alignment shop. Would it be safe if i drive fast, say 60mph? The alignment shop is about 30 miles away.....
Also why do u guys think it pulls to the left? is it the tie rod ? or maybe the lower control arm? The camber does seem a little positive..
08-15-2007, 09:58 AM | #2 | |
Member#: 156083
TXIC
Vehicle:07 WRX tr Pearl white |
i wouldn't really dog it but you should be fine just cruising there, were they adjustable tie rods? |
08-15-2007, 09:59 AM | #3 |
Member#: 146137
Vehicle:06 WRX R.I.P. 06.06 - 10.08 |
maby your right arm is longer
08-15-2007, 10:03 AM | #4 |
Member#: 148076
well everything is OEM.. i replaced the tie-rod because it was bent...
08-15-2007, 10:04 AM | #5 |
Member#: 148076
08-15-2007, 10:06 AM | #6 |
Member#: 84181
NESIC
Vehicle:NASA #530 GTS2 |
are you sure the accident didnt bend something else? Hub? A-arm? mounting bolts, etc?
You may want to inspect it very closley and compare it to the other side (if it didnt get hit as well) take some measurements and such... The pull could also be tire pressure OR Toe out/in based on your ability to allign the car when you replaced the tie rod end. |
08-15-2007, 10:07 AM | #7 |
Member#: 156083
TXIC
yea just take it to hae it aligned, if it was a adjustable then you might be toe'd out a little which would cause the car to pull also. Any time adjustments are made to suspension its a good rule of thumb to get it realigned, its a pain in the ass but it helps even if your going back to OEM. Take it from me shims fall out things compress and just about anything can happen when you take that crap apart.
08-15-2007, 11:26 AM | #8 |
Member#: 136098
NWIC
Vehicle:07 35r WRX Maxwell Power |
1. have it aligned.
2. check your tire pressure and make sure each side is even. |
08-15-2007, 12:14 PM | #9 |
Member#: 134005
Vehicle:2004 WRX Premium PSM |
+ for alignment
08-15-2007, 02:37 PM | #10 |
Member#: 148732
SCIC
Vehicle:2018 STI Black |
check air, also, our cars are very sensitive when driving on roads that are crowned...
08-15-2007, 04:46 PM | #11 |
Member#: 48199
Vehicle:06 WRX WRB |
Road crowning will cause his car to pull to the right. Assuming he lives in the United States and isnt driving on the wrong side of the road everywhere... OP: You'll be fine, just be aware of the way the car pulls. Tires will also wear more quickly but that generally takes thousands of miles... |
08-15-2007, 06:04 PM | #12 |
Member#: 148076
thx for all the replies guys i guess imma take it to the alignment shop hopefully they can tell me what else i bent ! thx
hopefully nothing will happen when im on the freeway |
under power, pulls to the left, but under coast, it pulls to the right | StiLimited | Brakes, Steering & Suspension | 15 | 02-02-2007 07:34 PM |
SAI is off and the car pulls to the left | JacksWastedLife | Brakes, Steering & Suspension | 1 | 02-13-2005 04:11 PM |
Why does my car pull to the right? | qik-RE | Newbies & FAQs | 11 | 10-25-2004 03:58 PM |
Car is pulling to the left and to the right | MattDell | Brakes, Steering & Suspension | 11 | 08-30-2004 01:29 AM |
My car pulls to the left... | mykrrrr | Mid West Subaru Owners Club Forum -- MWSOC | 2 | 05-30-2002 01:33 PM |
