Welcome to the North American Subaru Impreza Owners Club Thursday October 17, 2019
Go Back   NASIOC > NASIOC Reviews > Car Part Reviews
Old 09-04-2007, 09:11 PM   #1
boostdog
Member Sales Rating: (1)
Member#: 149752
2017 wrx
ICE ICE BABY SILVER!
Default $74 Ebay CAI intake review
Ok well i was excited to get home today as my new intake had arrived.
so here it is -
so out with the old
in with the new
the only issue that I had was with the U shaped piece that screws onto the brake dist. block in the fender...it was not wide enough to slide onto the threaded post...So I had to modify it a little...took a little time but no biggie. The quality of the product is ok..the piping is a little thin and seems to scratch/pit easy but I plan on paiting it anyway as I want it red.
Performance wise it is alot quieter that just having the snorkis removed like I had but the butt dyno feels like it's a little quicker.
All in all for 74 bucks shipped with a K&N filter I would buy it again and so far recommend it, just be ware of the issue with the mount that needs to be widened.
also make sure that you install the pipe the correct way or the maf will be backwords and your car won't start ...........like mine did.
boostdog is offline   Reply With Quote
Old 09-04-2007, 09:22 PM   #2
skydes
Member Sales Rating: (5)
Member#: 141347
2005 WRX
reset the ecu.
skydes is offline   Reply With Quote
Old 09-04-2007, 09:28 PM   #3
boostdog
Member#: 149752
2017 wrx
Originally Posted by skydes View Post
reset the ecu.
oh yes i did that too. before taking it for a spin.
Old 09-05-2007, 06:16 PM   #4
Matt_H
Member Sales Rating: (29)
Member#: 107000
2015 BMW X1
Originally Posted by davetrends View Post
reset the eccu.
Matt_H is offline   Reply With Quote
Old 09-04-2007, 09:45 PM   #5
Matt_H
Member#: 107000
2015 BMW X1
Put the air diverter back in (forgot the name).
Old 09-04-2007, 10:24 PM   #6
antigfk
Member#: 122242
2006 WRX LTD
I wonder how the ECU likes that gigantic bend where the MAF sensor is?
antigfk is offline   Reply With Quote
Old 09-05-2007, 07:07 AM   #7
boostdog
Member#: 149752
2017 wrx
it's actually not bent where the maf is...it's just the angle that the pic is at...it's in a straight piece of the intake.
Old 09-05-2007, 06:14 PM   #8
davetrends
Member#: 158472
reset the eccu.
davetrends is offline   Reply With Quote
Old 09-06-2007, 04:22 PM   #9
stickygerbils
Member#: 131292
2008 MINI Cooper S
Chili Red/White
Noice. So what made you go with this? Are you worried about having the same problems that you did with the K&N drop in?
stickygerbils is offline   Reply With Quote
Old 09-07-2007, 09:29 AM   #10
boostdog
Member#: 149752
2017 wrx
So far so good..i wanted something to help clean up the engine bay...and i got to thinking that the issue may have been that the fac. intake was sucking in alot of heat since i just removed the snorkis and nothing else. It was free (anniv. present) from the inlaws soo i fig. i had nothing to loose..i am going to paint it as it does scratch pretty easy being raw aluminum. the filter that came with the kit is very large...looks like it would have more surface area than just a stock sized panel filter too.
Been on the car for 3 days and is working perfect.
Old 09-08-2007, 07:20 PM   #11
stickygerbils
Member#: 131292
2008 MINI Cooper S
Chili Red/White
Ah, no problems with MAF sensor that you know of?
Oh, and happy anniversary!
Old 09-08-2007, 07:25 PM   #12
Engmus
Member#: 115645
After 1 week I would recommend disconnecting the ECU (aka resetting it) and then cleaning the maf with JUST a can of MAF cleaner. Found at advance auto.
That way you can see how much (if any) build up takes place on the maf in that setup.
Engmus is offline   Reply With Quote
Old 09-09-2007, 01:45 AM   #13
Spec_C
Member#: 91423
Chapter/Region: HIIC
2004 PSM STi on Meth
Tuned by Chris [email protected]
so what company sells these on ebay? could you post a link? thanks
Spec_C is offline   Reply With Quote
Old 09-09-2007, 03:08 AM   #14
All4bSpinnin
Member Sales Rating: (10)
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
looks genuine to me....
All4bSpinnin is offline   Reply With Quote
Old 09-09-2007, 10:52 PM   #15
WeldingHank
Member Sales Rating: (22)
Member#: 98645
2002 WRX Wagon
checked your Air/fuels post install?
WeldingHank is offline   Reply With Quote
Old 09-10-2007, 08:46 AM   #16
wrxhard
Member#: 108091
CAI with no tune?
yikes...
I'm gonna make a "Engine blown" thread prediction...
Hopefully you saved everything you need to go back to stock so you can get some warranty work if/when you need it.
wrxhard is offline   Reply With Quote
Old 09-10-2007, 10:16 AM   #17
djpast
Member Sales Rating: (6)
Member#: 31016
2016 Focus RS (blue)
2005 WRX Wagon (white)
You can get an ebay CAI that has the correct size MAF tube (no maf correction needed) for like $40 shipped.
djpast is offline   Reply With Quote
Old 09-10-2007, 10:26 AM   #18
stickygerbils
Member#: 131292
2008 MINI Cooper S
Chili Red/White
Link plz
Old 09-10-2007, 10:46 AM   #19
wrxhard
Member#: 108091
just because it's the right size doesn't mean no maf correction is required. Turbulance is also something you need to look out for. I don't think there's a CAI on the market that DOESN'T require a re-tune. Even the prodrive has a MAF variance of like 10 percent. Which, IMHO is enough to warrant a re-tune. You may say "Well, the Cobb setup doesn't require a re-tune." To which i say, the Cobb setup isn't a CAI. It's a short ram, and it has air straighteners built in and a crap load of r&d, which is why it doesn't cost $74. Sorry, but even my 2002 bugeye is too valuable for even the possibility of problems.
To the OP, i hope this works out for you. Good luck
Old 09-10-2007, 11:29 AM   #20
djpast
Member#: 31016
http://cgi.ebay.com/ebaymotors/IMPRE...spagenameZWDVW
Its a cheap knockoff of buschur's CAI. everything is pretty much the exact same.
I logged before and after the install on my stage 2 tuned car. almost the exact same readings as my stock intake gave. Not saying it work for everone, but it worked for me.
Old 09-10-2007, 09:20 PM   #21
Capt Crunch
Member Sales Rating: (15)
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
Its a cheap knockoff of buschur's CAI...
Which is a knockoff or just about every CAI for the WRX in existence. AEM, Prodrive, Buschur, ebay, they all look the same.
Capt Crunch is offline   Reply With Quote
Old 09-10-2007, 09:27 PM   #22
stickygerbils
Member#: 131292
2008 MINI Cooper S
Chili Red/White
Cheap knockoff... for some odd reason I see a big red flag when I hear that.
Old 09-17-2007, 04:19 PM   #23
Y_I_K_E_S
Member Sales Rating: (8)
Member#: 159449
2005 WRX STi
"Ali"
I'm pretty new to this whole scene. Anyway, where and how would you go about getting a re-tune/ computer chip, etc?
I have an '05 RS that I just put an intake on with a generic pipe and K&N filter. It seems to run great so far.
Y_I_K_E_S is offline   Reply With Quote
Old 09-17-2007, 05:09 PM   #24
parker
Member Sales Rating: (2)
Member#: 46241
- Can I get
A wayo
The MAF sensor being right in the middle of a bend worries me.
the accuracy may change as RPM's climb.
Please have good tests done.
parker is offline   Reply With Quote
Old 09-18-2007, 10:40 PM   #25
boostdog
Member#: 149752
2017 wrx
teh accuracy may change as RPM's climb.
It's not in the middle of the bend...where the maf is it is completely straight.
I will clean the maf as instructed above and report back on the findings. The one posted above to ebay looks exactly like mine but mine came with a k&n filter..see here.
http://cgi.ebay.com/ebaymotors/ws/eB...148991143&rd=1
So far over 1000 miles with nothing at all different. even my gas mileage has been the same. I would think if this were to screw up you a/f ratios then that would be a sign ( i could be wrong) that something is wrong but nothing is diff. still getting 23 mpg which is the same as before the install.
