Welcome to the North American Subaru Impreza Owners Club Sunday October 20, 2019
Old 05-17-2006, 04:21 PM   #1
DZnutz
Member#: 91837
Default what it takes to turbo an 05 2.5RS
... in regrads to getting the motor mechanically ready.
ill assume an sti shortblock... will the stock RS SOHC heads bolt onto the block?
sti subframe... stock manifold, up-pipe, turbo/lines/plumbing, downpipe, catback. other than trying to figure out where from and where to feed the turbo lines is there anything else im missing?
how will the motor run with the RS heads?
DZnutz is offline   Reply With Quote
Old 05-17-2006, 04:26 PM   #2
AWD>FWD
Member#: 107027
2007 SWP WRX STi
w/MPS-built 2.34l
Trade it in for an 04-05 WRX?
Seriously, you will save money in the long run (other than insurance). A lot of the people that do the swap say they wished they would have just bought a WRX in the first place.
AWD>FWD is offline   Reply With Quote
Old 05-17-2006, 04:55 PM   #3
DZnutz
Member#: 91837
that is not a option... the loss on the RS would be in the thousands
Old 05-17-2006, 05:21 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Doing a search in the AFI forum will yield much results...
Old 05-17-2006, 05:29 PM   #5
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
Mm, turbo
scoobyimpreza is offline   Reply With Quote
Old 05-17-2006, 06:30 PM   #6
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
A good turbo kit alone would cost you close to 5000 dollars if you got proper engine management with it. And that would allow you to run maybe 6PSI reliably, 9PSI with some reliability, and at maybe 10 - 12PSI your engine would blow up.
6PSI will net something marginally faster than a WRX. Would you lose 5000 dollars trading your car in for a WRX?
To run more boost you would need some better internals at the very least. A shortblock would be a better idea. Add $1600 for an STI shortblock to the $5000 turbo kit, then add the cost of installing it ($2500 at a dealership, if you're wondering), add the cost of dyno tuning it ($500 and up) and you will have 10000 dollars+ invested in a plain looking car with low reving heads that were never designed for turbocharging.
A pretty pointless idea, IMHO.
Mind you, this is comming from someone who has a full engine swap on my RS. I definitely spent more than I would have if I bought a WRX, but at least I drive the chassis I find most attractive, and it weights a good 300 pounds less than a rex.
powerlabs is offline   Reply With Quote
Old 05-17-2006, 07:50 PM   #7
DZnutz
Member#: 91837
AFI forum?
Old 05-17-2006, 07:54 PM   #8
DZnutz
Member#: 91837
ive already factored in the sti short block... my question is will the RS heads bolt directly to the sti block? what combination will this yield?
Will the block directly swap in or will i need additional sensors/components?
will an sti manifold bolt directly and properly to the RS heads?... will the stock RS heads hold say 300hp at the crank?
if i was to trade in my RS for a WRX id lose right at about $5-$6K right now... keep in mind we have slightly different prices here in canada
all labour is me, pulling a motor is a few hours
Old 05-18-2006, 12:34 AM   #9
moss
Member#: 10197
Originally Posted by DZnutz
AFI forum?
Aftermarket Forced Induction forum
http://forums.nasioc.com/forums/forumdisplay.php?f=50
the STi shortblock will NOT be a direct swap in. There's a few issues with doing that swap... I'd would suggesting asking over in the AFI forum, as they have a better understanding and many people have done the SOHC EJ253 to EJ257 shortblock conversion, etc.
However, it will cost you MORE to go this way, I'd say $6000 or more. For that price you can get a USDM 04-05 STi motor, wiring harness, turbo, STi top mount, and probably installed. In addition, AVCS, better heads and a more a solid motor (and more boost friendly)
Hell, for $6k you can find a full wrecked 04 STi at an insurance auction (with the right connections) and swap everything in so that it would be a direct bolt in.
(for example... http://forums.nasioc.com/forums/show....php?t=1005121, 04 STi part out )
Keith
moss is offline   Reply With Quote
Old 05-18-2006, 11:43 AM   #10
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
isn't the 05 RS drive by wire ...making the whole thing 5.46x times worse
Old 05-18-2006, 12:15 PM   #11
LastResort
Member#: 99289
I don't think so, the 05 WRX is not.
LastResort is offline   Reply With Quote
Old 05-18-2006, 12:27 PM   #12
DZnutz
Member#: 91837
Keith
great info, thanks ill look into it further there
Old 05-18-2006, 12:28 PM   #13
DZnutz
Member#: 91837
yes, the 05 RS is drive by wire... im hoping i can retain use of the RS throttle body
Old 05-18-2006, 09:26 PM   #14
crazyGC8
Member#: 107421
MY00 RSTi-SOLD BUILT
MY04 STi-SOLD AG2 S13-DD
Cool
If I were you, I wouldn't go that rought with the motor. You would spend to much money for what your going to end up with in the long run. Like mentioned before, you can find a usdm Sti motor and swap it in for around the same amount your going to spend to build the hybrid motor.
Also, since your car is already DBW, the swap is even easier. You would be more satisfied with the swap with the MUCH better flowing heads and quicker spool. IMPO
crazyGC8 is offline   Reply With Quote
Old 05-19-2006, 10:57 AM   #15
steve_d
Member#: 315
so you've got a car that you've 5-6 grand over your head in (you said you'd lose 5-6 if you traded for a WRX), but you've got the money to do an engine swap?
are we making sound financial decisions with our lives?
sjd
steve_d is offline   Reply With Quote
Old 05-19-2006, 09:24 PM   #16
DZnutz
Member#: 91837
sjd
thanks for your concern, but id have to swallow another $20K on top of the $5K i lose to get an sti... or another $12k for the wrx. thanks anyways
Old 05-19-2006, 09:39 PM   #17
steve_d
Member#: 315
just looking out for ya. seriously...I've been out of dumb debt (credit cards, frivolous things) for about 4 years, and it feels great. the mrs and I have two payments in our lives. house, and one car at a time. I'm saving 35% of my paycheck between 401k and investments.
sjd
Will 2.5i front rotors and pads swap to an 05 2.5RS? flatlander4510 Brakes, Steering & Suspension 1 05-27-2008 11:22 AM
does an 06 sti axleback bolt up to an 05 2.5rs? DZnutz Normally Aspirated Powertrain 10 10-23-2006 11:30 PM
what does it take to be an IT recruiter besides a pulse? AC Lerok Off-Topic 33 03-31-2006 11:58 AM
What would it take to get a 2004 2.5RS w/4EAT to do 0-60 in 7 seconds? driver Normally Aspirated Powertrain 43 12-19-2003 11:40 AM
What mods would it take to beat an Eclipse GSX? jImp Normally Aspirated Powertrain 18 02-13-2001 07:32 PM
