Welcome to the North American Subaru Impreza Owners Club Tuesday October 15, 2019
Old 09-17-2019, 02:17 PM   #1
PyroguyFTW
Member#: 473226
2012 Outback
Default Clutch slipping. What do?
So my new to me '16 is beginning to experience some major clutch slip. I really hope the clutch isn't toast, because I don't feel like spending $1500 on a replacement right now.
I really hope this just a glazed clutch, but I fear that it's worse than that. I have done 6 launches at 4500rpm, 5 with flat foot shifting set at 5500 when I would shift at 6500. Last run had a very clutch-y smell to it for a few seconds after parking. The car is Cobb stage 2. There is just over 30k on the car, and I have driven manuals before, just not an AWD turbo manual so I definitely could be doing something wrong. AFAIK I don't slip the clutch when shifting hard or when driving on the road, only when starting from a stop, which is only about 1.5k-2k fir half a second. I keep my foot on the dead pedal and use neutral at lights, so I am not particularly sure if it's my accelerating technique, the track launches, faulty clutch, or a combination of the three.
The symptoms are as follows:
5 days ago: Started on the highway in 4th at about 3200, slow roll on the gas to pass resulted in some minor slip, about 500rpm.
3 days ago: Driving casually, had some slip in 5th at about 3k. Also happened later in 4th, but about 700rpm this time. Decided to test to ensure I wasn't imagining things, used 4th to test on an uphill incline. Same result.
Yesterday: Slip in 3rd, about 500rpm worth, even at WOT. It is nearly 1k over what it should be at WOT.
Today: Slipped maybe 200rpm in second climbing a hill at part throttle.
How can I find out if it's a glazed clutch or just one that's done for? If the track launches killed it, is there a stock-like clutch that can take a few launches one night a month, such as maybe the South Bend Stage 2 Daily? Thank you guys for the help.
PyroguyFTW is offline   Reply With Quote
Old 09-17-2019, 07:37 PM   #2
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
the track launches will kill your clutch due to slipping it. its normal . the OE clutch is not suppose to handle that. your clutch is gone. Get a new one and have it installed. if you want to launch your car get a twin disc to help with slipping.
bmxhotsauce is offline   Reply With Quote
Old 09-17-2019, 07:45 PM   #3
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
You are abusing your clutch like that and you don't think it's gonna fail?
A glazed clutch will become normal after you drive it for a while. I think your is toast. Get something that can actually handle your abuse.
jasonwrx86 is offline   Reply With Quote
Old 09-18-2019, 12:15 AM   #4
PyroguyFTW
Member#: 473226
2012 Outback
Maybe I just have a different definition of abuse, but I really dont think a handful of launches at low rpm should kill a clutch, and I didn't say that being abusive won't damage it. If it is, then I guess I need to find a sturdier clutch. I dont plan on hitting the track weekly or anything, but maybe once every other month in the nicer seasons, and I don't wanna end up replacing a clutch multiple times if it can be avoided.
Old 09-18-2019, 07:59 PM   #5
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
Since you bought it used, you never knew how the previous owner treated it.
4500rpm launches I wouldn't call low rpm and being AWD it's not that hard to slip the clutch too much and wear it down quickly.
Old 09-19-2019, 07:27 PM   #6
the_saintusa
Member#: 171486
2004 WRX STI
As mentioned, the previous owner likely did much more damage than you. What you described is tough on the clutch, but I would expect that any clutch would be able to hold up after what you have done. However, with that type of driving since 2016 (previous owner), than I would expect the clutch to be on its death bed.
the_saintusa is offline   Reply With Quote
