Welcome to the North American Subaru Impreza Owners Club Wednesday October 23, 2019
Old 09-17-2019, 02:33 PM   #26
noobultimatum
Member#: 431550
2016 WRX
ALL THE STAGES
Originally Posted by Waddlz View Post
lol wut
you get 24.5 mpg on E70, when the factory car isn't even rated for that high MPG on pump gas?
lol ok.
Cruise control is a helluva tool.
noobultimatum is offline   Reply With Quote
Old 09-17-2019, 02:43 PM   #27
GlarryHoodDIT
Member#: 460907
2016 WRX
It's not a matter of cruise control. It's a matter of thinking the readout on the OEM gas mileage gauge is even close to accurate on an E70 mix.
Theres zero chance the EJ matches the new DIT in gas mileage while running ethanol.
GlarryHoodDIT is offline   Reply With Quote
Old 09-17-2019, 03:02 PM   #28
sifl
Member#: 85006
09 WRX STI
Hey, I'm running a rotated setup on E85. I'm hitting 575 hp and tq on TiC's dyno.
My whole setup was executed by TiC after I tried, twice, to build something myself with a local shop. I started with TiC's closed deck short block, and built from there.
Car runs great, performs amazingly on- track, and I still can daily drive it.
Ask TiC about it.
sifl is offline   Reply With Quote
Old 09-17-2019, 03:07 PM   #29
Waddlz
Member#: 395275
2012 STi
This.
My car says 60 mpg on the readout cause I never scaled the readout in ATR
Waddlz is offline   Reply With Quote
Old 09-17-2019, 08:57 PM   #30
Boxer112
Member#: 78751
2017 Sti
ISM
Originally Posted by Gab0 View Post
Who is your tuner?
Car was built and tuned by M.R. Performance in NY. Then I moved to southern Cali and had to retune for this crappy fuel. Reesetuned retuned the car.
Boxer112 is offline   Reply With Quote
Old 09-17-2019, 08:59 PM   #31
Boxer112
Member#: 78751
2017 Sti
ISM
lol wut
lol ok.
Ok. I know what I see and get. Readout is accurate when compared to the distances I drive.
Next youíre going to tell I didnít get 29mpg
On my Ascent driving from Cali to WA.
Old 09-17-2019, 08:59 PM   #32
Boxer112
Member#: 78751
2017 Sti
ISM
Yes, that 24.5 is on cruise control. Maybe I should have annotated that on my first post.
Old 09-18-2019, 09:05 AM   #33
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Originally Posted by subaru_gc8 View Post
. I have the spec B trans BTW.. Do you think it might have something to do with me having a 2.1 with v9 heads with tomei cams?
Yes your 2.1 vs the 2.5L that KB posted will spool slower. Can you post a lot or 3rd gear pull starting around 2,500rpm?
Old 09-18-2019, 03:39 PM   #34
subaru_gc8
Member#: 29292
2004 WRX wagon
i figured it would spool a little slower but I didnt think it would be that much slower.
I could but I seem to have a probelm with my tactrix cable as I cant seem to find the definitions to get into the ecu.. kinda irritating., actually my tuner had the same problem.. so Im not really sure im the problem
Old 09-19-2019, 11:22 PM   #35
Dieseltechdave
Member#: 506572
2009 Wrx
Steel Silver Metallic
I think with IAG's shortblocks you cant go wrong. That's my next move
Dieseltechdave is offline   Reply With Quote
