Welcome to the North American Subaru Impreza Owners Club Friday October 18, 2019
Old 09-02-2019, 01:44 AM   #26
jeff6666p
Member#: 400078
1998 impreza 2.5rs
black
Originally Posted by lphthephunk View Post
Also, it is probably worth noting that all cylinders plugs are fouling out equally
Where any of them wet from gas what's the gap? Check the compression maybe the rebuild was off.
jeff6666p is offline   Reply With Quote
Old 09-02-2019, 09:39 AM   #27
lphthephunk
Member#: 505232
I have a guage from AutoZone that I suspect to be off. I read 60 psi on all cylinders when doing a compression test yesterday. It was with the car a good ways below operating temp, but not ice cold. All plugs were out and pedal was to the floor. Also used a brand new battery.
lphthephunk is offline   Reply With Quote
Old 09-02-2019, 10:12 AM   #28
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
Hm - that seems low. The lowest I've seen is 85, but if you haven't sealed the rings yet that could be the cause.
Can you take pictures of what the plug(s) look like? Might give us a clue.
BeastianSTI is offline   Reply With Quote
Old 09-02-2019, 02:49 PM   #29
lphthephunk
Member#: 505232
I don't have time to take them out today, but trust me they are fouled with fuel; black and sooty. If taken out directly after idling they are wet with fuel.
I went ahead and put some air through the system to see if I could find anything blatantly obvious, but no dice. It does not appear that I have any leaks.
I guess that just leaves timing again. However, I have checked the timing countless times already.
When the car has been left with plugs out for a while to evaporate the fuel, and the plugs have been torched, it starts right up without needing to be in fuel cut out. It starts out at a very low rpm though and eventually (like 3 seconds) quickly works its way up to about 1500 rpm to warm up and then the idle kind of adjusts to about 1000rpm. You can feel it occasionally miss, probably because all of the fuel.
I think my next step will be to remove the intake manifold again and actually see where the valves are when the timing marks are lined up.
Old 09-02-2019, 09:16 PM   #30
jeff6666p
Member#: 400078
1998 impreza 2.5rs
black
Try to get another gauge. That compression is way too low. Your injectors may be sticking cause excess fuel to flood the engine. Also Try new plugs I would get copper ones since they are cheap and your just testing.
Old 09-05-2019, 07:46 AM   #31
lphthephunk
Member#: 505232
Going to send my injectors in to be cleaned and flow tested.
Old 09-17-2019, 09:09 PM   #32
jeff6666p
Member#: 400078
1998 impreza 2.5rs
black
You get it running yet?
Old 09-17-2019, 10:03 PM   #33
lphthephunk
Member#: 505232
Haha, nope. Thankfully it's just a project.
I replaced the camshaft position sensors and the fuel trims actually look pretty normal now. I didn't end up sending the injectors in because better judgement tells me it's pretty unlikely for them all to fail.
I tore one of the o rings from my endless fiddling with the intake. Once I replace the o ring I'm going to run through the fuel system again. I feel like it's pretty close.
Old 09-21-2019, 12:38 PM   #34
lphthephunk
Member#: 505232
Quick question, might be a dumb one: I'm running through the fuel system again and am testing fuel pressure. I get no fuel pressure with key on and engine off.
Is the fuel pressure regulator supposed to not hold pressure unless the engine is running? I would think it would, but the middle fuel line(under the main feed) just squirts the fuel back out.
Old 09-21-2019, 04:33 PM   #35
jeff6666p
Member#: 400078
1998 impreza 2.5rs
black
Your supposed to have fuel pressure with the engine off key and in the on position. Your pump isn't priming if you aren't.
Old 09-21-2019, 05:02 PM   #36
lphthephunk
Member#: 505232
Sweet, I figured as much. I'm getting fuel to the rail, but it's immediately being sent back to the tank. I'm thinking the fuel pressure regulator is stuck open.
Old 09-26-2019, 06:43 PM   #37
lphthephunk
Member#: 505232
Well turns out it was just a faulty fuel pressure gauge. Fuel pressure is fine and it doesn't bleed off after running, so I don't think any injectors are stuck open.
Looks like I'm pulling the motor to double check valve clearance.
Edit: also, I noticed that fuel pressure drops when blipping the throttle. It drops to about 30psi then the car dies. Is it normal for fuel pressure to drop when tapping the throttle?
Old 09-29-2019, 09:28 PM   #38
lphthephunk
Member#: 505232
Small update
Been pretty busy so I haven't had the time to fully pull the motor out yet. However, I did get it undressed and I'll hopefully have time to pull it tomorrow.
Also found that while turning engine by hand, air was escaping through all intake valves on compression stroke. I had the intake manifold off during this, so I was able to feel the air escaping. This is probably a good indicator that my original lash was very incorrect.
