Welcome to the North American Subaru Impreza Owners Club Monday October 14, 2019
Old 08-21-2019, 11:30 AM   #1
bizzlezx10r
Member#: 439586
2015 WRX
ISM
Default Cleaning exhaust tips? (In/Out)
I bought my WRX a month ago with the SPT exhaust already on it. Sounds great but they look absolutely terrible. Also when I get on it Iím getting a lot of sulfur smell.
Iíve been watching videos on how to clean it but I feel like none of exhausts in the videos are as bad as mine. Has anybody attempted to clean the inside of the exhaust with a wire wheel attached to a drill?
https://imgur.com/GgCBwTx
https://imgur.com/JuP6R07
bizzlezx10r is offline   Reply With Quote
Old 08-21-2019, 03:08 PM   #2
joesstripclub
Member#: 461015
2017 WRX
I would start with some metal polish like mothers. You can also get their powerball or whatever attachments they have now, which is a foam polishing pad that attaches to a drill and is made for polishing wheels, but would work great on the inside of exhaust pipes. A wire wheel will ruin your tips for sure. You may have to step up to steel wool if the polish doesnt cut it.
joesstripclub is offline   Reply With Quote
Old 08-21-2019, 03:15 PM   #3
gfxguy
Member#: 316583
2014 STI Hatch
ISM
My SPT exhaust was also in pretty bad shape when I bought it. I was able to restore it with some Meguiars Ultimate Compound and a Motherís PowerCone.
gfxguy is offline   Reply With Quote
Old 08-21-2019, 03:32 PM   #4
bigbenp
Member#: 216142
'04 & 11 STi's
'10 & 14 Foresters
On my first STi, I used 0000 steel wool to clean up the soot and then shined it up with Nevr-Dull. Took some elbow grease, but it looked nice afterward.
bigbenp is offline   Reply With Quote
Old 08-22-2019, 03:25 AM   #5
brylemr
Member#: 414507
I use Flitz Metal Polish and a Daytona Speedbrush to clean the inside.
brylemr is offline   Reply With Quote
Old 08-22-2019, 09:10 AM   #6
gaugeof12
Member#: 132859
2015 WRX
CWP
Pretty similar. I used a green kitchen scrub pad along with the steel wool and then w/e metal polish i had on the shelf in the garage.
gaugeof12 is offline   Reply With Quote
Old 08-22-2019, 09:13 AM   #7
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
Mother's metal polish.
Be careful of green scotch pads, they can put scratches into polished tips.
jasonwrx86 is offline   Reply With Quote
Old 08-22-2019, 11:00 AM   #8
bizzlezx10r
Member#: 439586
2015 WRX
ISM
Thanks everybody!
I don't think the exhaust is polished. Does anybody know what material it is from the pictures? It almost looks like the same material that exhausts from early 2000's street bikes were made out of. Like that dull, heavy metal.
Old 08-22-2019, 12:45 PM   #9
TifosiWA
Member#: 489993
2019 WRX STI LTD
Pure Red
Originally Posted by bizzlezx10r View Post
Thanks everybody!
IIRC, the SPT exhaust systems are stainless steel with brushed finish, that's why you will never be able to get it to shine like you can with polished SS or chrome exhaust tips.
You can clean it with any of the above mentioned products, personally, I use Blue Magic (https://bluemagicusa.com/) that are readily available at most auto parts stores.
TifosiWA is offline   Reply With Quote
Old 09-09-2019, 02:43 PM   #10
MarcWinkman
Member#: 479018
2018 STi Limited
Crystal White Pearl
I use a little bit of Hoppes No. 9 (bore solvent that can be had from any gun shop or the hunting section of your local sporting goods store) with a green Scotchbrite pad. Get some of the solvent on a shop rag and let it soak onto the surfaces you want to clean for a couple of minutes then scrub clean with the Scotchbrite pad. Simple, inexpensive solution, and a large bottle of bore solvent will do the task many times over. To bring back some luster, I use Adams Metal Polish. Makes my exhaust tips look new again. In full disclosure, I do have polished stainless tips on my Cobb exhaust, but either way, this methodology will also work with the brushed tips on the SPT exhaust.
MarcWinkman is offline   Reply With Quote
Old 09-15-2019, 06:08 PM   #11
seattleslow
Member#: 189722
2003 WRX Wagon
Rally Blue
I wish I thought of that. I kept scrubbing, and scrubbing, and scrubbing with chrome cleaning products. That must shave a lot of time off.
seattleslow is offline   Reply With Quote
Old 09-16-2019, 09:50 AM   #12
bizzlezx10r
Member#: 439586
2015 WRX
ISM
I'm bout to hit it with that 4 Grit if it keeps being so stubborn as it is.
Old 09-17-2019, 11:14 PM   #13
TriAxis 6
Member#: 377862
2017 Z06/Z07 & Fozzy
Admiral Blue & CWP
Superclean @ 3:1 let dwell for a few mins. Agitate with a stiff bristle brush and rinse. That should get the schmutz off. Then Iíd go after it with a higher quality metal polish like angelwax alchemy
TriAxis 6 is online now   Reply With Quote
