Welcome to the North American Subaru Impreza Owners Club Tuesday October 22, 2019
Old 11-08-2007, 01:58 PM   #1
E6V6I6L
Member#: 123710
Default 00 rs swap question
I have a 2000 rs and want to swap in a turbo motor. I would like to use the stock trans for a little while. I know I need the cross member and an ecu and a wiring harness and obviously a complete longblock. I can get a complete 05 wrx wiring harness for free. my question is, What motor do I need to get and and what ecu? Iam not sure if the wiring harness is the same from 02-05.
E6V6I6L is offline   Reply With Quote
Old 11-08-2007, 02:37 PM   #2
ovedrivex
Member#: 116774
1997 Project GC8
does IL even have emissions? or ODII? cause if you dont go jdm its cheaper and beter and since your dropping it into a rs it will be equally a PITA. ive noticed that complete engines /w harness/ecu minus trannies arnt much more that ones without. might as well get one that comes with ecu/harness cause you will probably spend that much on just an ecu.
ovedrivex is offline   Reply With Quote
Old 11-08-2007, 04:28 PM   #3
sidewayz
Member#: 5810
2001 S366 2.5RS
all WRX harness's and engines are the same from 02-05. ECUs change slightly but nothing that you would notice.
buy whatever you can afford
honestly? post this on RS25.com
sidewayz is offline   Reply With Quote
Old 11-08-2007, 04:54 PM   #4
E6V6I6L
Member#: 123710
Thanks for the responses! I am going to start pricing some things out. IL does have emissions test and being that it is 00 I have to keep it obd2. Plus I like going the usdm route for ease of getting anything for that motor plus engine management.
Old 11-10-2007, 02:10 PM   #5
tverdek
Member#: 52525
2000 RS/WRX swap
***SOLD***
Default Il
I recently did a swap in my '00RS ('02 WRX USDM engine). I'd definately do a USDM swap. Keeping the stock tranny is no big deal. I put 30k miles on my swap w/o any problems and I drive it pretty hard. Having an emissions ready car is a must in IL; ask me how I know
If you need some help from someone close by PM me. Good luck nad the best advice I can give is to take your time.
tverdek is offline   Reply With Quote
Old 11-12-2007, 11:09 AM   #6
E6V6I6L
Member#: 123710
Thank you I may take you up on that offer tverdek. I actually have a friend who swapped his 05 wrx to an sti setup so He has the engine and ecu from the same car and it only has 20k on it. so I may be getting that. plus I have a free 05 wiring harness. This thing should be pretty fun to drive.
Old 11-13-2007, 12:40 AM   #7
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Default impreza 95
yeah im trying to convert my ej18 which came in my impreza 95, and im puttting a ej20g motor in it.. with tranny
azn0boi04 is offline   Reply With Quote
Old 11-14-2007, 12:46 PM   #8
E6V6I6L
Member#: 123710
If everything I have for the swap is 05, can I use a cobb ap or is the plug under the dash different? I wouldn't think it is different because it's obd2, but you never know.
00 RS swap to 2.0WRX. WHAT CLUTCH/FLY COMBO? Rallly2000 Subaru Conversions 6 10-15-2008 04:32 PM
2002 WRX swap into 2001 RS swap question dtl1218 Subaru Conversions 14 08-13-2008 01:58 PM
More L to RS Swap Questions Mk3Design Subaru Conversions 9 03-17-2007 08:56 PM
ej205 rs swap question beaun-nus Subaru Conversions 2 02-24-2007 09:32 PM
00 RS swap u6t9 General Community 10 03-31-2005 10:53 PM
