Welcome to the North American Subaru Impreza Owners Club Monday October 14, 2019
Old 06-20-2003, 06:30 PM   #1251
cindergarden
Member#: 21158
94 FWD 2.5
Acardia Green
center vents are in it , as well as all the tubing the top dash is being sold seperately since i have it wrapped in suede
cindergarden is offline   Reply With Quote
Old 06-20-2003, 06:30 PM   #1252
cindergarden
Member#: 21158
94 FWD 2.5
Acardia Green
Old 06-22-2003, 05:45 AM   #1253
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
how much are you selling those parts for?
scoobyimpreza is offline   Reply With Quote
Old 06-22-2003, 09:55 AM   #1254
cindergarden
Member#: 21158
94 FWD 2.5
Acardia Green
i kinda wanna get $175 +shipping for the dash alone, and $250+shipping to for everything i have for teh RS interior plus ill give you a source for the last part
Old 06-22-2003, 11:30 AM   #1255
BrysImpreza
Member#: 3102
2018 Mazda CX-5
Storm Trooper White
Originally posted by Ruh_roh
I just bought a new bumper for my L but don't know how to remove the old one. Can you guys help?
1. Turn your steering wheel to the right, look under your drivers side fender and remove the little pop-clips, try not to break them.
2. Turn your steering wheel to the left and remove the clipson the passenger side.
3. on both sides pull back the plastic panel that covers the fender, feel inside along the bumper, there's going to be a clip on the inside about 1.5 inches from the fender wall. Pop those out, if you can't get them, cut them with a dremel, you can use a bolt later to replace these.
4. Pop the hood, with a thin flat tipped screwdriver push in the clips on your grille and remove it.
5. Next take out the little phillips screw that holds your corner lights in and pop those out gently or else you're going to break the clip.
6. With a 10mm rachet, take out the 4 bolts holding in the headlights, making sure to remember to unplug them (you have no idea how many times I did that!)
7. after all this is off, you're going to see a few 2 piece pop-clips, pop all these out, more then likely if your car is older, they're just going to break, so have some bolt or new clips to replace them.
8. There might be one or two clips or a small bolt holding the bumper on by the bottom or in the airdam... I've never actually removed a 94's bumper.
9. Undo all the electrical like blinkers and fogs and then slide the bumper skin off.
10. to take off the bumper beam, there's 4 HUGE bolts on the front of the engine floor. I think they're 21mm, they're hard to miss... Just make sure you have an extension and breaker bar, I couldn't even get these off with impact tools! So have a strong friend handy!
Good luck... you owe me a beer!
Bry.
BrysImpreza is offline   Reply With Quote
Old 06-22-2003, 03:01 PM   #1256
scoobydrew06
Member#: 32951
Will a WRX 17mm rear sway bar fit my 93 L
scoobydrew06 is offline   Reply With Quote
Old 06-22-2003, 07:05 PM   #1257
scoobydrew06
Member#: 32951
Where do you L owners go for styling and performance parts online???
Old 06-23-2003, 04:11 AM   #1258
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
Only if you car is equiped with a rear swaybar (but yes it fits). If its FWD you have a problem, if it just doesnt have one and its AWD then you need to get new rear control links with the swaybar connections from a more recent GC model with them along with swaybar mounts and endlinks.
Depends on the actual part. I find most of my stuff from other local members or from the private sale/vendor forums. I rarely use the actual online sites.
Old 06-23-2003, 04:12 AM   #1259
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
Hey, anyone here know what Spark Plugs to get for an EJ18? I have no clue if the ones the RS guys recommend for their cars will fit... (some model of NGK's)
Old 06-23-2003, 10:06 AM   #1260
Murray
Member#: 11312
2009 Gray
Legacy 2.5i
i do beleive the spark plugs for the EJ18, EJ22 and EJ25 are all the same.. only the WRX has different plugs that i know of.
Murray
Murray is offline   Reply With Quote
Old 06-23-2003, 11:14 AM   #1261
cindergarden
Member#: 21158
94 FWD 2.5
Acardia Green
yeah murrays right , same sparkplugs , i have EJ25 ones in my ej18 right now
Old 06-23-2003, 08:03 PM   #1262
scoobydrew06
Member#: 32951
Does anyone have pics of their car with the Version 6 Style Front Mesh Grille on their 93-95 L??? The pic that the site shows is on the car but close up, i need to see the whole car to see if i like it.
Gracias
Old 06-23-2003, 08:59 PM   #1263
Murray
Member#: 11312
2009 Gray
Legacy 2.5i
yeah.. my 97 L has EJ25 plugs... and the motor to go with it, haha
Whoa!!! BIG BRAIN!!!! *head uncontrollably tilts back*
Old 06-24-2003, 02:46 AM   #1264
Chewy
Member#: 5917
95 Impreza Type L
That blueish color
I use the NGK plugs. Part # BKR6E-11
Here's a link.
http://ngk.com/results_app.asp?AAIA=1268906
Chewy is offline   Reply With Quote
Old 06-24-2003, 04:36 AM   #1265
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
Thanks Chewy! Ill go see if I can find some tommorow and install them...
Old 06-24-2003, 07:58 AM   #1266
SubaruImpreza_power
Member#: 13910
2005 Legacy GT
blue
I guess you all can add me to this thread now.. I just got a 1995 Impreza L sedan.. I'm pretty sure it's a 1.8L as soon as I opened the hood the first thing I saw was the large amount of free space around the spark plug wires. I'm still trying to figure out that the hell that manual switch is on the gear shifter.. Oh and yea it's FWD.. Boo for Subaru I think the tires are 15 inchs? Anyway the car has to be repainted.. It's that light greenish color.. umm And the car feels way too soft. btw it has 128K miles on it. Oh and yea if it is indeed a ej18 wow what a short stroke it has.. something like 2.25 in.
SubaruImpreza_power is offline   Reply With Quote
Old 06-24-2003, 05:52 PM   #1267
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
boo-ya
Old 06-24-2003, 07:22 PM   #1268
SubaruImpreza_power
Member#: 13910
2005 Legacy GT
blue
here is my 95 L stock.. want to convert it to a 2.5RS bodywise as it has a 1.8l engine I don't plan on having it much longer then a year. But as you see the color is hard to work with..
And on the side note.. I think the heat shield is loose? around 1500 rpms acclerating their is a metal rattleing sound coming from what sounds like under the car like something is loose. I can't put my finger on it. Anyone know what i'm talking about?
should be able to see the pictures
Old 06-24-2003, 07:36 PM   #1269
Murray
Member#: 11312
2009 Gray
Legacy 2.5i
my 97 L had a few exhaust shield rattles when i got it, the real annoying one was actually from the shild over the muffler..all i had to do was bend the edges so it stiffened the whole shield(put a rib of metal on the side so it didnt flex), the 2nd i had was the one almost in the middle of the car, i did the same thing with that one to prevent it from making noise, and the 3rd was the driver side exhaust manifold shield..the support bracket welded to the manifold that the shield bolts onto broke..so all i did was crush the shield in carefully untill it was unable to move, i think i also put a large hose clamp around it too somewhere..
but thats what took care of my rattles..till i got my Stromung..the driver side hanger bracket on the muffle itself was actually rubbing against the body bracket for the hanger..since Stromung didnt design the exhaust perfectly, it has the driver side of it tilted up a tad and it actually squished the hanger..again, i fixed this by bending the little lip of metal the stromung was hitting, lol.
i got alot of bent exhaust stuff under my car.
no more rattles though
Murray
Old 06-24-2003, 07:44 PM   #1270
SubaruImpreza_power
Member#: 13910
2005 Legacy GT
blue
I think I found the rattle.. under the car the left exuast downpipe the metal part that covers under the piping seems to be loose.. I don't know if I can make it any tighter as it's a little rusty with the bolt.
And btw the stock supension on this car sucks! geez just siting in the car causes it to bounce.. way too soft for me.. I wonder if 2.5Rs parts will fit for this department?
Old 06-24-2003, 08:02 PM   #1271
SubaruImpreza_power
Member#: 13910
2005 Legacy GT
blue
Well I found the rev limiter.. 6,000 rpms no more rattle from the heat shield after I tightened the bolt. Is it just me Or this fuel guage really slow to move up?
It takes FOREVER to move all the way to a full tank.. it took me about 3 min to drive back from the gas station and it's just about 3 marks from full..
Old 06-25-2003, 01:47 AM   #1272
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
more info on your car jaxx. ever timed it? what other mods are you running?
Old 06-25-2003, 02:49 AM   #1273
Hawk296
Member#: 14555
1995 Impreza L
Baja
subaru impreza power- congrats on FINALLY getting an impreza, yours is more base model than mine! ill bet the struts are pretty bad, mine were leaky at around 100,000 miles as well. bummer about the FWD though i always got rocks in my heat sheilds that would bounce around. you might have some trouble upgrading suspension being FWD, i dont have much experiance in this area though.
Hawk296 is offline   Reply With Quote
Old 06-25-2003, 03:07 AM   #1274
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
Got the plugs and installed them today, easy as pie
I also did something a few of you L folks might want to consider if you have a leak in your Power Steering resevoir. I just got that leak for the 2nd time after having the whole pump assembly replaced a year and a half ago. Its a common problem aparently, so I figured out a way to fix it I hope...
http://forums.nasioc.com/forums/show...hreadid=382198
Old 06-25-2003, 08:11 AM   #1275
SubaruImpreza_power
Member#: 13910
2005 Legacy GT
blue
Thumbs up
LMAO!! yes Finally.. For one thing it's harder to find this body style.. And I really wanted a 98 2.5 RS but that turned up no good.. I would of had a less harder time looking for a used wrx then that car.
I don't know what to do suspension wise.. And did you keep stock tire size?? I can't find any tires this small..
Oh yea i think i'm going to change the exhaust will a soobysport fit? I know it's pricey but I think it sounds a little better then some of the others.. I just don't know if it will fit.
And I don't think borla has any headers for the 1.8L just the 2.2 & 2.5 I think.
The OFFICAL Sarah Palin THREAD, Post it here!, Enough with all the threads!! THE-95-STi Political Playground - Chaotic Neutral Edition 57 07-21-2010 09:09 AM
The 2008 Impreza Photoshop thread...post them here adizon Member's Car Gallery 307 09-19-2007 11:36 PM
Wallpaper Sized Pics - Post em here plz! ElTorrente Member's Car Gallery 9 02-05-2004 10:54 AM
WCSS Picture Thread... Post Em! Unsung EM1 North West Impreza Club Forum -- NWIC 16 07-07-2003 12:41 PM
Calling all Gunmetal Subzero's - post em here! RallyOttawa Member's Car Gallery 1 06-02-2002 11:56 AM
