Welcome to the North American Subaru Impreza Owners Club Wednesday August 12, 2020
Old 11-19-2008, 12:41 AM   #1
earlvb
Member#: 186613
1997 Impreza OBS
Acadia Green 64C
Default 02 engine and ECU w/ Phase 1 4EAT
Hello, I'm thinking about swapping an engine from an 02 WRX into my 97 OBS with the phase 1 4EAT. Will the new ECU work with the older TCU and trans, or will I get error codes etc. It looks like the 02 ECU has an additional input (AT load signal) for the A/T that the 97 doesn't. Can the new ECU do without this input? What has to be done to make the two work together? Thanks for any help.
earlvb is offline   Reply With Quote
Old 12-01-2008, 07:24 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Is the 02 WRX an auto or manual?
Old 12-04-2008, 06:29 PM   #3
earlvb
Member#: 186613
1997 Impreza OBS
Acadia Green 64C
It's coming from a manual 02, but I was planning to get an auto ECU for it.
Old 12-05-2008, 12:25 AM   #4
Letze
Member#: 143323
1990 Celica Alltrac
Gray
Short story, no
You'll have to search for the pin outs and make an entirely custom harness for the ecu to tcu, if it will read them or not there is no telling.
If you wanna keep auto, find a complete auto swap kit, otherwise its time to go MT5
Letze is offline   Reply With Quote
Old 12-07-2008, 09:18 PM   #5
earlvb
Member#: 186613
1997 Impreza OBS
Acadia Green 64C
Thanks guys, I appreciate the help. That confirms what I was thinking. Now I've also found a 4EAT from an 06 WRX. Does 02 motor/ECU and 06 Trans/TCU sound more like it? I know I'll need to splice the TCU to the ECU, since the MT harness won't have those connections. It seems more likely that the two would communicate. I know the complete swap would be the way to go, but I'm trying to work with what I can find. Maybe adding the turbo to the existing setup would be easier.
Old 02-26-2009, 12:15 PM   #6
turboL
Member#: 111735
97 Impreza L
Rust and White
bumping this. I dont see why this wouldn't work. The inputs are the same just different wires and connectors. the only struggle is finding which wire does what.
edit:
3 of the 7-8 wires are figured out due to their interaction with the TPS, just a matter of finding the pinouts for the rest.
turboL is offline   Reply With Quote
02 wrx engine and ecu, 04 wire harness? Yint Subaru Conversions 4 10-04-2011 01:25 PM
Phase 1 4eats - Some TC shafts have a nipple and some don't ciper Transmission (AT/MT) & Driveline 0 11-17-2009 08:48 PM
Phase 1 4EAT with 02 ECU? earlvb Transmission (AT/MT) & Driveline 4 12-04-2008 06:30 PM
FS ohio: 02 Engine,Tranny,Ecu,etc.. GraffixWB Engine/Power/Exhaust 9 04-17-2007 10:48 AM
2003 WRX engine and ECU Hopper Private 'For Sale' Classifieds 7 04-08-2004 02:11 AM
