Welcome to the North American Subaru Impreza Owners Club Sunday October 13, 2019
Old 08-02-2005, 03:30 PM   #1
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Default Another swap
So I got my car running last night.
Right now I have a EJ205 engine (out of my 02 WRX) in a 1998 Impreza.
Instead of finding a WRX harness somewhere and splicing it into the existing harness, I just bought the ECU connectors, the engine harness connectors, and the other accessory plugs like the boost solenoid, front o2, etc.
I think I paid $50 or maybe $75 for the connectors, and then about $100 or so on wiring supplies and built the harness myself. I spent about 3 hours labelling all the wires on each connector and the wires I needed from the RS harness. I spent about another 8 hours or so connecting things together to build the harness and then connecting the RS stuff to the harness. I spent some more time wiring in the fuel pump controller. I haven't really cleaned up much of the wiring inside the car and I still need to put all of it in some split loom.
The car started perfectly the first try. What made the wiring so easy were these solder splice connectors from Tyco. They are inline connectors that have a ring of solder in the middle, with a sealing ring outside of that, and then heatshrink after that. With a heat gun and about 30 seconds you have a soldered, heat shrunk, sealed connection. And once things are shrunk, the size is virtually the same size as the wire, no need to splice things staggered, etc due to bulk.
The car is being built purely for autocross, there are lots of other things going into the car, at some point when it's done I'll document everything.
The car:
Engine bay:
The harness:
Inside the car:
The engine that will eventually occupy the engine bay:
Old 08-02-2005, 04:05 PM   #2
Sharmin7
Member#: 59929
2002 2.5rs
Platinum Silver
Phil, what motor do you now have in your wrx?
Sharmin7 is offline   Reply With Quote
Old 08-02-2005, 04:27 PM   #3
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Right now it has no motor, that's why it's just sitting out in the parking lot and I'm driving my truck.
I will hopefully be swapping the engine back into the WRX this weekend, so I can start daily driving it again.
Old 08-02-2005, 04:42 PM   #4
RS25Tuner
Member#: 59920
2004 STI
What that a 98 RS you started with? I think I saw some ABS lines in there.
RS25Tuner is offline   Reply With Quote
Old 08-02-2005, 05:54 PM   #5
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Yes a red 98 RS, repainted white.
Old 08-02-2005, 11:16 PM   #6
hail2theTheif
Member#: 42548
1999 GF8 V7 STi Swap
how much was the paint job?
hail2theTheif is offline   Reply With Quote
Old 08-03-2005, 09:19 AM   #7
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Why did you do that? There were so few Brilliant Red RSs to start with.
jamesfacts is offline   Reply With Quote
Old 08-03-2005, 10:27 AM   #8
RS25Tuner
Member#: 59920
2004 STI
I can understand your pain since I use to own a green Unicorn myself. I have never even seen a Brilliant Red 98 RS even for sale.
Old 08-03-2005, 10:36 AM   #9
RS25Tuner
Member#: 59920
2004 STI
Question
solder splice connectors from Tyco - inline connectors that have a ring of solder in the middle, with a sealing ring outside of that, and then heatshrink after that. With a heat gun and about 30 seconds you have a soldered, heat shrunk, sealed connection. And once things are shrunk, the size is virtually the same size as the wire, no need to splice things staggered, etc due to bulk.
Where did you get the Tyco connecters from? Sounds like you had a good idea. Can you take a picture of a connector and of a soldered connection so I can get a good idea of what it looks like and what I might be looking for in the future?
Thanks
Old 08-03-2005, 10:41 AM   #10
Randoramma
Member#: 60649
00RS EJ205 swap
Wow, where did you get the connectors from? An individual party or a business? If you found a way to locate connectors, that could be a real tool for those who are having a hard time locating harnesses. I would have considered that myself when I was looking for my harness. Which connectors did you buy, B134-B137, B84, F60, 62, and B2, wastegate plug, o2 plugs, and did you find the FMU plug? I bet others would really like to get this info!
Thanks for sharing!
Randy
Randoramma is offline   Reply With Quote
Old 08-03-2005, 11:22 AM   #11
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
word. looks nice. i like your abundance in workspace :P
supermoose is offline   Reply With Quote
Old 08-03-2005, 11:33 AM   #12
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Well I got them from IA Performance, they are from a V8 JDM STI. When an importer gets engines, they get cut harnesses, which include the connectors most of the time. Either that or they have leftover JDM bulkhead harnesses which have everything attached. All the connectors you need are the ECU plugs, bulkhead-to- engine harness connectors, MAF, Front/rear O2, EGT (if your really want it), and boost solenoid.
I didn't have the FPC connectors, I just soldered the connections directly to the FPC pins.
I agree it would be great if someone could source the actual plugs and pins, but I have no idea about getting bare plugs, etc.
The car was salvage car that had been stolen. The front fenders, rear quarter panels, etc. had been bashed in with a bat or something. The replacement front fenders and hood were already white. The guy who painted it kind of wished I'd left it red, but I like white. It's not a great paint job, it's a race car, I got the car fixed and painted for a lot less than what you'd pay for a good paint job. The car has a junk title and as such can not be driven on the street...legally.
http://www.raychem.com/US/datasheets...lderSleeve.pdf is the datasheet for the connectors, they have pictures. I originally got them from newark.com but later got them from allied electronics.
Old 08-03-2005, 11:36 AM   #13
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
cool
do you have a link to the tyco connectors?
Old 08-03-2005, 11:58 PM   #14
RS25Tuner
Member#: 59920
2004 STI
Thanks for the PDF!
Old 08-09-2005, 09:51 AM   #15
projectrally
Member#: 53916
16 WRX LTD / 818s
WRB/ Gel coat red
wow. great info. I'm going to have to track these down...
projectrally is offline   Reply With Quote
Old 08-09-2005, 06:05 PM   #16
legacy2003
Member#: 38338
2003 Outback Sdn H6
hey quick ot question... what brand of radiator hoses and other hoses are you using? that looks like you have a perrin short ram intake (like i have). i'm trying to match my engine bay to that color; are those all perrin hoses, and if not what are they and where did you get them from?
legacy2003 is offline   Reply With Quote
Old 08-09-2005, 11:29 PM   #17
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Those are samco radiator hoses, Perrin intake.
As sort of an update, I've decided to mount the ECU under the passenger seat. The wiring is just a little too long to coil around and stick under the ECU kick panel. I'm running a Hydra ECU which is a bit larger than the stock ECU (and has its own extension harness), so it'll just work better that way.
Old 09-01-2005, 03:15 PM   #18
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Some updated pictures:
Yet another swapped RS. IMPREZive 02 WRX Proven Power Bragging 18 07-02-2007 01:40 PM
Yet another swap question.... MomoWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-10-2005 07:26 PM
Another Swap question Impreza4ever Subaru Conversions 3 05-23-2004 09:59 PM
Another swap!! geronimo66 Member's Car Gallery 13 08-11-2003 09:38 PM
Yet another swap trunklids thread Tex-WReX Texas Impreza Club Forum -- TXIC 5 10-30-2002 02:43 PM
