Welcome to the North American Subaru Impreza Owners Club Sunday May 27, 2018
Old 03-11-2008, 11:39 AM   #1
nmbwhitey
Member#: 172443
1995 obs to gf8 conv
red
Unhappy help! ej20g swap single turbo or twin?
i thought the ej20g was single turbo if no can someone specify which one is. also the ej20g has forged onternals any other engine have that too?if i were to get a tt swap i can use wrx headers to convert to single turbo?
nmbwhitey is offline   Reply With Quote
Old 03-11-2008, 12:15 PM   #2
shakur45
Member#: 165106
2017 WRX
Gray
^^ It is single turbo
shakur45 is offline   Reply With Quote
Old 03-11-2008, 10:15 PM   #3
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
The EJ20G comes in several varieties all of which are single turbo. Some have a closed deck block and forged internals. Those come from several year STi models. Most of them are just standard open deck block with standard internals. These come from WRX models. Depending on the year and body style the WRXs came with several different turbos including the tdo4 similar to the usdm WRXs, and some came with the awesome td05 16G. The twin turbo motors are from Legacys. They won't fit in LHD cars. The driver side turbo hits our brake booster. These engines are EJ20K or EJ20R. You can convert them to a single turbo setup using WRX stuff but you will have a lot more money in it than its worth unless you just happen to have a single turbo set up laying around.
Ryan
Post #555 WOOHOO! I'm no longer a newbie!!!
FourOnTheFloor65 is offline   Reply With Quote
Volvo Introduce New Single-Turbo & Twin-Turbo Five-Cylinder Diesel Engines AVANTI R5 Non-Subaru News & Rumors 8 02-18-2009 11:58 AM
single 44mm or twin 38mm for external twinscroll setup? petawabit Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 06-16-2006 04:22 AM
Single tip or twin tip? ursine Normally Aspirated Powertrain 8 05-23-2004 10:11 AM
Single Turbo VS. Twin Turbo Cusco Normally Aspirated with bolt-on Forced Induction Powertrain 0 07-30-2002 06:45 PM
Who has swapped to an EJ20 Turbo or Twin Turbo? MY99 2.5GT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-27-2001 07:07 PM
