Welcome to the North American Subaru Impreza Owners Club Thursday April 26, 2018
Old 01-21-2007, 08:37 AM   #1
bulgarianfreak55
Member#: 135691
2004 Subaru WRX STi
333 WHP, 325 WTQ AGILE!
Default Removing rear door panels on 04 Subaru STi
I am trying to put speakers/check if my car is wired for them in the back doors. I tried, but I can't find anywhere how to remove the rear door panels on 2004 Subaru STis. Anyone know?
bulgarianfreak55 is offline   Reply With Quote
Old 01-21-2007, 09:55 AM   #2
Daishi00
Member#: 78952
2005 WRX
CGM
Simple. Remove screws, pop bezel off of handle, remove window control unit, pop door clips, lift panel, revel in all the glory of removing a door panel in under 3 minutes.
Daishi00 is offline   Reply With Quote
Old 01-21-2007, 11:27 AM   #3
CLR4ILS
Member#: 107320
2009 Legacy
Grey
i foudn the easiest part to start with the door clips is the bottom front there is a little opening that I can get my fingertips into and it just pops right out
CLR4ILS is offline   Reply With Quote
Old 01-25-2007, 07:55 PM   #4
bulgarianfreak55
Member#: 135691
2004 Subaru WRX STi
My problem is the handle, how do i pop the bezel off?
Old 01-25-2007, 08:51 PM   #5
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
Firmly pull on the door card starting at the bottom. The bezel will just pop off when you pull hard enough. I've done this numerous times without breaking it. The handle stays attached to the door, no need to remove it.
khail19 is offline   Reply With Quote
2008 Subaru Impreza Hatch Front/Rear Door Panel Removal J_Bird Car Audio, Video & Security 47 12-12-2012 03:07 PM
Removing rear door panels on 05 Legacy sedan brad_in_denver Legacy Forum 2 01-30-2005 09:46 AM
How do I remove the door panels on an L (manual windows)? ilmaestro Interior & Exterior Modification 9 07-02-2004 01:23 AM
How do I remove the door panels on an L (manual windows)? ilmaestro Service & Maintenance 2 04-13-2004 10:52 PM
Taking off rear door panels on an outback Sobelizard109 Legacy Forum 2 06-17-2002 01:48 PM
