02-11-2014, 07:50 PM | #551 |
Member#: 163672
Vehicle:GV Same color as veneers |
The STi badge will be on the lip. Expect to spend another 20% in price to ship because of box size, shipping charges always change.
The 6266 is a common choice.
02-11-2014, 08:57 PM | #552 |
Member#: 381172
Vehicle:09 Fozzy Red |
Super clean man!
02-20-2014, 11:17 PM | #553 |
Member#: 187179
Vehicle:14 STi Cocain |
well i got a little tipsy last night and got the courage to buy the extended STi lip and side STi lips from Japanparts. I just hope I got the right lip it was this one http://www.japanparts.com/images/Ima...ase=1&no=43953
it says extended 31 mm |
02-21-2014, 01:00 AM | #554 |
Member#: 163672
Very nice buy. I was very excited opening the box. There should be no issues with that part order, looks like the correct image. If youre uncertain, send me the part number on the invoice to verify.
Update Anything from this thread can be discussed in the next edition, thread: http://forums.nasioc.com/forums/show....php?t=2601726 Keeps from having (2) threads bumping. |
02-27-2014, 11:51 AM | #555 |
Member#: 331753
Hey Flex,
Did you roll your fenders to fit your Wedsport setup? I don't recall seeing that info in your thread. Thanks! |
02-27-2014, 12:11 PM | #556 | |
Member#: 130368
02-27-2014, 04:11 PM | #557 |
Member#: 228719
NWIC
Vehicle:2013 STi Satin White Pearl |
03-08-2014, 10:29 AM | #558 |
Member#: 312938
Vehicle:2012 STi Hatch SWP |
Your car is perfect man, you have excellent taste! I am extremely interested in going with the same wheels as you but was wondering what kind of camber you were running from and rear to make it work. I also assume you had to roll the front and rear fenders? Any pulling?
Thanks! |
03-08-2014, 08:33 PM | #559 | ||
Member#: 163672
Be sure to check: http://forums.nasioc.com/forums/show....php?t=2601726 All discussion is still relevant there. :] Rear fenders are rolled. Front is not touched. Natural camber from lower ride height just allowed the rears to squeeze in with stock RCAs. ~ -2* in the rear and front is ~ -3*. A +35 offset and a thick 265 tire look to be the limit for functionality without front liner removal and fender pulling (neither recommended). |
03-08-2014, 11:16 PM | #560 |
Member#: 312938
Damn I was hoping to be able to pull this off without exceeding -2 in the front. Thanks for the info!
01-24-2015, 07:44 PM | #561 |
Member#: 366438
Vehicle:2013 WRX World Rally Blue |
Hey FLEX, c
Can you tell us what tires you have mounted on those Rays wheels In post 142? I just had a set of Continental DWS mounted on mine and I'm disappointed that the tires looks stretched. ie the wheel is wider then the tire buy a noticeable amount. |
