Welcome to the North American Subaru Impreza Owners Club Wednesday January 22, 2020
Old 02-24-2009, 12:48 PM   #1
NicFunkadelic
Member#: 35330
1999 RSTi + 4.44 = )
Silverthorn... for now
Default STi swap done and runnig BUT clutch/flywheel dust shield issue
I just got my 07 sti swap running this past week, but discovered the horribly inconvenient fact that I bent the dust shield that covers the opening underneath the clutch and flywheel. I used a pry-bar to bend it out of the way of the rotating assembly, but I'm not happy having an exposed clutch and flywheel, and worrying that a little pebble could disable my car and cause damage. I'd hate to pull the motor for a stupid dust shield, but...
Is this shield replaceable? Should I replace it? Anyone know the part #?
Should I ghetto rig some home-made dust shield?
Any suggestions?
NicFunkadelic is offline   Reply With Quote
Old 02-24-2009, 01:42 PM   #2
NicFunkadelic
Member#: 35330
I know I'm not the first to do this, anybody have any input?
Old 02-24-2009, 02:37 PM   #3
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
I would probably replace it for running in the wet, debris, etc as you mentioned. It's probably not critical but...............a wet clutch disc. I know it has a slit in it.
Is it possible to salvage the one you have? Beat it into shape?
I forgot to put mine back on . I looked and thought it would be difficult but doable with everything assembled. I know the 10mm head bolts are back above the crossmember, but I still think it's possible. gearwrench. I'll try tonight as I'm bored with other things on the car.
I may have an extra one, I'd have to look when I get home. Assuming they're identical.
It is replacable, I do not know a part #
If all else fails......duct tape.
I'm sure in this forum alone you could find a spare. I'm putting mine on and I don't even really DD the car.
mccanixx is offline   Reply With Quote
Old 02-24-2009, 03:08 PM   #4
NicFunkadelic
Member#: 35330
Thanks for the reply mccainxx. I actually just ran to the local suby dealership and ordered a new shield for around 20 bux. I probably could have just bent it back, but i doubt it would still do its job properly, because I think I mangled it pretty good. My RSTi is my daily driver, so I don't want to take any chances...
I'm going to attempt to just undo the motor mounts and hoist the motor and tranny an inch or two to install the new shield. I refuse to pull the whole motor out to replace that cheap little bastard piece of sheet metal. I don't think the new part will arrive till the end of the week, but I'll post an update this weekend when I attempt to slap it in.
Nick
Old 06-06-2012, 01:47 PM   #5
triniscoob
Member#: 143225
2004 JDM Sti
Nick
ANY CHANCE you got the OEM part NUmber on that sheild?????
thanks
triniscoob is offline   Reply With Quote
Old 06-07-2012, 01:13 PM   #6
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
You just bumped a 3 year old thread so the OP probably won't see this. What year, make, model do you have?
The part number for the Impreza is: 30216AA020 For the following dates:
'00, September — '02, May
'02, April — '02, December
'02, October — '04, March
geronimo81 is offline   Reply With Quote
Old 06-07-2012, 01:55 PM   #7
bisonjr
Member#: 102714
But, if you put in a 6-speed make sure you get one for an STi. The 5-speed shield will rub the flywheel.
bisonjr is online now   Reply With Quote
Old 06-07-2012, 03:47 PM   #8
69subaru360
Member#: 159682
1995 WRX
2015 F150
Seriously? A 3 year old thread about a stupid useless part? I throw those things in the trash, they are pain in the ass.
Old 06-07-2012, 04:14 PM   #9
bisonjr
Member#: 102714
lol... thats where mine is too.
Old 02-25-2018, 04:25 AM   #10
SubieDuper
Member#: 473634
2003 WRX Wagon
Sorry to resurrect this thread, but I forgot to install my flywheel dust cover on my engine when it was out. doh! now its installed and close to starting.
Did jacking the engine up by the trans work?
Is this really a useless part and I should just forget about it? (I have a hard time believing that one.)
thanks.
SubieDuper is offline   Reply With Quote
Old 12-28-2018, 09:38 PM   #11
EngineHacker
Member#: 462060
2011 WRX STI
Originally Posted by SubieDuper View Post
Sorry to resurrect this thread, but I forgot to install my flywheel dust cover on my engine when it was out. doh! now its installed and close to staring.
thanks.
It is not a useless part. Anyone that tells you that is a lazy asshat that forgot to install it and wants to feel better about themselves by misleading others. I have seen someone suffer the misery of having a pebble or some other debris go up in there and wreak havok. Happened at an amateur rally course. Clutch, tranny splines, starter motor gear and some other stuff got ripped to **** because of a stone or something. Although the cover does have a intentional slot in it, that is to allow the evacuation of debris and should not be "sealed" or covered. If you cant get it reinstalled, I hope you are running a good lower skid plate or something.
EngineHacker is offline   Reply With Quote
Old 12-29-2018, 06:14 PM   #12
SubieDuper
Member#: 473634
2003 WRX Wagon
Thanks for the reply, even though its about 10 months late.
I am happy to report I did install the dust cover.
I do not remember 100%, but I believe I got it on by loosening or removing the motor mount bolts and jacking up on the trans. I know I didn't take the engine back out. I must have been pretty far along on the install when I realized I missed the dust cover.
I remember very clearly struggling for what felt like a couple hours and really tearing up my hands on this effort. Starting those bolts sucked! Some were easier from above, some from below. Getting a decent bite on the bolt heads for final torque required a lot of messing around too. I hope I used loc-tite but cant recall for sure.
I would recommend loc-tite if you get stuck in the situation I was in. Maybe a swivel / hinged head ratchet wrench would have helped. I know I don't have one and it would have been worth buying just for the pain and suffering it could have saved.
next time;
DON'T FORGET THE DUST COVER.
Old 12-31-2018, 01:08 AM   #13
slow.wagon
Member#: 484841
2008 WRX STI
Lightning Red
+1 to EngineHacker. I actually forgot to put this part on once (mine rusted out and broke). The car picked up some road debris and it messed up my clutch really badly. I had to replace the whole assembly because the pressure plate got scratched really deep and the friction disk actually broke. Never gonna make that mistake again. $10 part ended up costing me over $400.
slow.wagon is offline   Reply With Quote
NJ - Factory Sti Short shifter and AP Braided clutch line wrx/sti BuggeyEYED Drivetrain 20 04-20-2008 02:53 PM
Where to get an Sti swap done? 2000bluegts Subaru Conversions 2 11-16-2006 06:42 PM
2004 STi swap, CEL and limp mode with no codes stored!? AcquaCow Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 07-27-2006 01:29 PM
I want an STi hood scoop and spolier..but where?? The Chef General Community 24 02-24-2006 09:12 AM
HELP!. swap done, and fuel pump wont fire supermoose Subaru Conversions 5 08-01-2005 07:39 AM
