Welcome to the North American Subaru Impreza Owners Club Friday January 17, 2020
Old 03-28-2009, 04:07 PM   #1
gero704
Member#: 156883
15 Outback CWP
07 WRX WRB
Default How to make your intercooler look brand new DIY
my tmic is real dirty, is there a cleaner that will break up the dust dirt and grime on the intercooler and make it look newer? best way of cleaning it?
Tried:
1.Engine degreaser+detailer
2.P21s TAW
3.Simple green
4.duragloss aluminum cleaner (success)
I used maybe 1/2-2/3 of the bottle, i saw noticable difference after the second time i sprayed it on. I maybe did it 5 more times just to be sure i got in every row. Let it set for 2 minutes and hosed it off. last pic doesnt do it any justice, looks 10x cleaner and shiner, cant wait for a sunny day to make a good picture.
Before:
After:
Mounted
gero704 is offline   Reply With Quote
Old 03-28-2009, 04:33 PM   #2
oRenj9
Member#: 164352
2007 Impreza WRX
A tire scrub brush and a power washer will do wonders for it. If regular soap doesn't work, try brake cleaner.
oRenj9 is offline   Reply With Quote
Old 03-28-2009, 08:46 PM   #3
Misanthrope789
Member#: 174595
2005 STi
Frank Dux Edition
I keep my engine bay spotless, doesn't much to maintain and keep it that way. Spray the intercooler and the rest of the engine bay with Simple Green and let it it for about 10-15 minutes and spray it off.
Your welcome
Misanthrope789 is online now   Reply With Quote
Old 03-28-2009, 08:59 PM   #4
gero704
Member#: 156883
15 Outback CWP
07 WRX WRB
yeah but i bought it off a guy that didnt take care of the engine bay...
Old 03-29-2009, 11:28 PM   #5
wrx tekker
Member#: 162824
2002 WRX Wagon
you could try some engine degreaser. kinda the same as the simple green. but ive never tried simple green and i have used engine degreaser and it works very well
wrx tekker is offline   Reply With Quote
Old 03-31-2009, 04:10 PM   #6
gero704
Member#: 156883
15 Outback CWP
07 WRX WRB
i tried that it didnt help...
Old 03-31-2009, 04:15 PM   #7
Admission_Regret
Member#: 131246
2004 STi Snow White
eighteen x ten + thirty
try some P21s I think its called?? I use the P100s motorcycle cleaner which is the exact same thing (bought it from a harley store) I let that sit for maybe 15 mins then took a boars hair and then a more rigid brush too it, worked great! Then I pressure washed it to finish it off. Be careful though you can bend fins if you get to close or scrub to violently.
Admission_Regret is offline   Reply With Quote
Old 03-31-2009, 06:23 PM   #8
gero704
Member#: 156883
15 Outback CWP
07 WRX WRB
yeah i see that product being used a lot around here.
ordered total auto wash, ill post pics if it actually work *fingers crossed*
Old 04-01-2009, 10:05 PM   #9
furryfootstool
Member#: 200526
i tried a engine degreaser to clean up my motor and it ended up taking the paint off my new fuel filter! but the engine was a lot cleaner....
furryfootstool is offline   Reply With Quote
Old 04-01-2009, 11:39 PM   #10
gero704
Member#: 156883
15 Outback CWP
07 WRX WRB
if you read the back of the degreaser it says to wipe it off any painted surface+ wax it after because it will eat the finish.
Old 04-02-2009, 12:05 AM   #11
ctrent86
Member#: 129199
Make sure to give it some soak time.
ctrent86 is offline   Reply With Quote
Old 04-04-2009, 02:07 AM   #12
gero704
Member#: 156883
15 Outback CWP
07 WRX WRB
* update: p21s taw did not make it any better *
Old 04-05-2009, 11:05 PM   #13
mugenXP
Member#: 155272
2006 WRX
Panda AE86
engine degreaser. put it in a little spray bottle and spray it on, so you won't splash it all over your engine bays paint
mugenXP is offline   Reply With Quote
Old 04-07-2009, 07:03 PM   #14
gero704
Member#: 156883
15 Outback CWP
07 WRX WRB
tried it... no good.
Old 04-07-2009, 07:09 PM   #15
AcquaCow
Member#: 36838
2001 B50 RSTi Sedan
2011 DGM WRX hatch
How about trying a cleaner specific to cleaning aluminum and oxidation on aluminum, instead of trying products that are designed for completely other purposes?
You need to acid wash it.
http://www.google.com/products?q=alu...num=1&ct=title
Diluted hydrochloric acid will do it as well.
And please take it off of the car before you do so, and wear protective gloves/respirator/etc.
-- Dave
AcquaCow is offline   Reply With Quote
Old 04-07-2009, 07:32 PM   #16
gero704
Member#: 156883
15 Outback CWP
07 WRX WRB
will it damage the sti logo on the ic?
thanks for the goood advise
Old 04-07-2009, 08:42 PM   #17
mellott73
Member#: 202233
2005 WRX STi
Platinum Silver Metallic
i would imagine it would probably eat it off :x
mellott73 is offline   Reply With Quote
Old 04-07-2009, 09:46 PM   #18
2:43AM
Member#: 190273
05 WRX evoIII-16G
Dude, stay away from the acid...unless you take it out of your engine bay like the poster of the acid-technique stated!!!
2:43AM is offline   Reply With Quote
Old 04-07-2009, 10:39 PM   #19
AcquaCow
Member#: 36838
2001 B50 RSTi Sedan
2011 DGM WRX hatch
Depends on if you soak it in the acid, and for how long...It's perfectly acceptable to brush it on and control where it goes on the IC...
You can just dip a toothbrush in the diluted solution and lightly scrub away and the oxidation should just basically vanish.
But yes, do this with the IC off of the car please.
-- Dave
Old 04-07-2009, 11:43 PM   #20
gero704
Member#: 156883
15 Outback CWP
07 WRX WRB
i ordered a bottle of duragloss aluminum brightener
and yes i will take off the ic when ill clean it. i have to get an sti tb to ic coupler because the wrx one is too long.(also on the way)
ill post results, if any.
Old 04-07-2009, 11:45 PM   #21
AcquaCow
Member#: 36838
2001 B50 RSTi Sedan
2011 DGM WRX hatch
Take before pics as well.
And do use a toothbrush or similar to aid the process.
-- Dave
Old 04-08-2009, 12:14 AM   #22
gero704
Member#: 156883
15 Outback CWP
07 WRX WRB
will do!
Old 04-08-2009, 05:42 AM   #23
NightHawk
Member#: 175181
Simple green and a tooth brush (i use a crest spinbrush for added oontz)
keep up with it every 2 weeks (more during the winter)
my engine bay is spotless.
NightHawk is offline   Reply With Quote
Old 04-08-2009, 08:47 AM   #24
rudeboy_sti
Member#: 124829
2005 STI
WRB/Gold
A guy I know uses cleaner for the fins on air conditioning units. His STI logo is still there and his intercooler is nice and clean. I keep my engine bay clean so never needed to try this.
rudeboy_sti is offline   Reply With Quote
Old 04-08-2009, 07:28 PM   #25
hoffmanEstates
Member#: 122043
04 wagonier
psm
yes alum. acid. the stuff they use to wash fuel tanks on rigs. and rims and after the wash( i would remove the IC and any other alum. peices you want washed) it WILL kick butt. and after all the cleaning put some polish on it. it will be shiny
-- Dave
hoffmanEstates is offline   Reply With Quote
How to make dull rims look new again? Jordanz3 Interior & Exterior Modification 1 09-29-2007 12:27 AM
How To Make Your Old Cd Player Look Like New Again Screamingdogbox Car Audio, Video & Security 14 05-03-2007 07:35 AM
How to make your wife sigh every time she looks in the backyard kaisersouse Off-Topic 13 02-20-2007 11:49 AM
How-to make your car look perfect (polish, wax, etc)!! Phil Jr. Car Care & Detailing 187 07-24-2006 10:18 PM
Any DIY on how to make your own speaker spacers?? Alan l. Car Audio, Video & Security 7 05-12-2006 01:17 PM
