Welcome to the North American Subaru Impreza Owners Club Friday January 24, 2020
Old 06-13-2017, 12:21 AM   #376
remski
Member#: 151895
Glad you guys are enjoying it.
Old 07-22-2017, 11:19 PM   #377
remski
Member#: 151895
Soo.... First things first...
Flag had to go up.
After getting quite a bit of rain in the car... Lots of things developed a protective coating of rust.
It kind of got me pissed off and I had to clear up the rust and paint the steering column as well as the pedal box.
Next up was time again to unreel the spools.
Driver door was completed with new power locks and power windows wiring and connectors.
Low beam, high beam, front and fender blinkers got wired up.
All neatly run inside the wheel well.
Few more wires appeared in the passenger's seat.
Trunk is not looking bad either.
It would also appear that some new crimp connectors are needed...
Old 07-22-2017, 11:19 PM   #378
remski
Member#: 151895
For ****s and giggles.. I've mocked up the old IC pipe.. and what do you know.. almost fits perfect!!!
Old 08-09-2017, 12:04 AM   #379
remski
Member#: 151895
Sooo here we go again..
I popped in the rear driveshaft on Saturday.
The locking ring is there ... but it didnt take much pry bar to pop it out..
I'll measure the track when time comes around..
So.. since running brake lines pissed me off a bit..
Onto the wiring we go..
Battery + terminal was wired up to the main circuit breaker.
I'd figured since the Aquamist pump is right there it was much easier to just wire it up to the battery. They provided a fused relay so no need to run that to the PDM.
Here is the relay and new DTP plug for the pump.
I believe all wiring from the back has been run...
Started prepping for junctions and heat shrink.
Here it is a bit more tidy.
I decided to make the harness modular so it'd be easier for me to build it.
Things like door wiring and front lights will be joining the harness via a connector.
Front headlight/blinker wiring was taped up and ready for assembly.
On the left is driver's headlight/blinker wiring, middle is passenger's.
And here... is my first attempt at concentric twisting..
I didnt feel like fiddling around with filler wires .. but I think it looks pretty good.
Here is another view of the section.
Old 08-21-2017, 12:23 AM   #380
remski
Member#: 151895
So... more progress..
Started wrapping the harness in Raychem.
This is where few hours of work gets you...
Few more gets you the other side.
End result and front lighting is now complete.
One thing i still cant find, is the plug for the JDM sidemarker...
Old 08-26-2017, 08:29 PM   #381
remski
Member#: 151895
So... Blue car now has his parts on my car !!!
Thanks for your help and damn fast shipping.
Pigtail wiring was removed and new connectors crimped.
Both sidemarkers and the front lighting is now done.
Old 08-27-2017, 03:43 AM   #382
klapasch
Member#: 377772
1992 Legacy RS EDM
Keep up mate, amazing work and love seeing the progress. Cheers from Argentina
klapasch is offline   Reply With Quote
Old 08-27-2017, 08:55 AM   #383
Dr Tumbo
Member#: 413410
2015 WRX Premium
Red
absolutely beautiful - just beautiful
Dr Tumbo is offline   Reply With Quote
Old 08-27-2017, 09:04 AM   #384
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
I <3 wiring. Nice job!
KeithS05RS2.5 is offline   Reply With Quote
Old 08-28-2017, 11:56 AM   #385
bigBADbenny
Member#: 314324
MY07 Lib GTB 6MT Wag
Oh man that detail above showing the guard w/ a highlight... Icecream paint job!
bigBADbenny is offline   Reply With Quote
Old 08-29-2017, 05:58 PM   #386
remski
Member#: 151895
No worries..
Wet sand and polish will be the last part of the build.
Old 09-01-2017, 03:15 PM   #387
remski
Member#: 151895
Started working on the rear harness.
About 1/2" in diameter.
Some twisting progress.
Old 09-02-2017, 02:52 AM   #388
07imprezRS
Member#: 164302
11 STi DGM, 07 WRX
WRB, 02 WRX WRB
Checking in... soon
07imprezRS is offline   Reply With Quote
Old 09-02-2017, 01:27 PM   #389
fuelMuncher
Member#: 301554
2002 WRX Wagon
PSM, 2007 OBP WRX Limited
Radiculous build thread, mate!
fuelMuncher is offline   Reply With Quote
Old 09-10-2017, 12:41 AM   #390
remski
Member#: 151895
... as the hours pass ..
some progress is made...
Harness is back in the car for re-fitting.
Once split locations were confirmed I started working on the tail end.
Must say.. it was a bitch to twist the rest .. as 1/2 of the harness had to be disassembled.
Here is a view of the left tail being completed.
Here is a view of the rear ground point.
Not liking the idea of pop nut but lets hope it holds.
The rear is almost ready. Just need to figure out how to run the 044 connection. Courtesy of Robert.
Since the pump takes about 14A a 12 gauge should suffice.. but was reading that some people had issues and decided to add an 2nd run of 12gauge.
On the right is the run from front harness.
Next up is rear right tail and time to hook up the PDM and merge front with the rear.
Old 09-10-2017, 09:51 PM   #391
remski
Member#: 151895
more progress on the harness.
Rear harness before epoxy.
Tail light part completed with some fuel pump wiring that's not wrapped yet.
Fuel pump transition.
Old 09-11-2017, 02:56 AM   #392
bigBADbenny
Member#: 314324
It's a master class!
Old 09-13-2017, 09:35 PM   #393
MountainSubie
Member#: 474489
looks awesome, can't wait to see the finished project
MountainSubie is offline   Reply With Quote
Old 09-28-2017, 11:23 PM   #394
ride79
Member#: 199828
KEEP GOING! - I only log on to this forum for this build!
ride79 is offline   Reply With Quote
Old 09-29-2017, 01:17 AM   #395
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Welp . . . Starting to re-think that full custom wiring harness. Lol
Jk, I will just power through it. But this really makes me like the idea of doing the absolute minimum to be "road legal".
Scuby04STi is offline   Reply With Quote
Old 09-29-2017, 12:26 PM   #396
TakeFlight138
Member#: 475321
This is amazing! Complete transformation.
TakeFlight138 is offline   Reply With Quote
Old 09-29-2017, 12:53 PM   #397
the good captain
Member#: 470130
Whoa. Amazing!
the good captain is offline   Reply With Quote
Old 09-29-2017, 05:42 PM   #398
webberjames95
Member#: 417695
are the pics not showing up now
webberjames95 is offline   Reply With Quote
Old 09-29-2017, 06:56 PM   #399
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
I can see them just fine.
Old 09-30-2017, 01:48 AM   #400
remski
Member#: 151895
Sometimes the dns dies.. I've updated.. lets see if that helps.
