Welcome to the North American Subaru Impreza Owners Club Sunday January 19, 2020
Old 07-15-2018, 10:16 PM   #526
remski
Member#: 151895
And the winner is ...
Scuby04STi .. Still 42 lbs off with his Price is right move..
Old 07-15-2018, 11:31 PM   #527
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Boom . . . Lol!!!
Scuby04STi is offline   Reply With Quote
Old 07-18-2018, 10:09 PM   #528
remski
Member#: 151895
Moar parts came in today so it was time to finally put the power steering issue to rest.
Rack cross line that I cracked while replacing the subframe came as well.
After about 30 min I finally figured out where to mount the PS reservoir.
This required the alternator bracket removal
There it is.. a clean install.
Was this close to drive with PS ... but since the tank is mounted in a different position the pump feed has to be turned 180 to work..
But it cant work since there is no way to secure it.
So.. I have a AN fitting conversion and will need to wait for -10AN 90...
Drivers seat with new brackets and belts has also been installed.
I had to re-drill the mounting brackets and push it back about an 1".
Now I feel like its too far...
Last but not least.. I am sure most of you mark your bolts once they are torqued.
If not here is a handy marker that I use to mark all the bolts that have a final torque. A sharpie is used when the bolt is removed.
Old 07-18-2018, 11:02 PM   #529
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
When your car is up and driving, let us know how that reservoir works.
Im running the Case Bays one as well and at idle the fluid flows through looking perfect, but after taking the car down the street two houses and back, I popped the cap off and the fluid is super aerated.
Trying to figure out if Ive got somewhere that is pulling in some air or if its just a characteristic of the reservoir.
KeithS05RS2.5 is offline   Reply With Quote
Old 07-18-2018, 11:43 PM   #530
Awpturbo
Member#: 488504
Awesome build.
Awpturbo is offline   Reply With Quote
Old 07-22-2018, 12:25 AM   #531
remski
Member#: 151895
So.. Power steering is done and works like a charm.
Thank you Amazon Saturday delivery.
Up next was coolant tank install.
Here is the bracket with supplied bolt.
Why Mishimoto ? why ?
You could say there is lots of room in the engine bay...
Here it is installed.
Went ahead and changed the tranny fluid.
What came out wasnt amusing.
Put some crappy one to flush before Motul goes in.
Also I've noticed that I cant put 5th and 6th gear in.
It was then time to put on them stickers..
Last but not least.. Rear sti sticker has been applied.
As some of you know.. this build wasn't really my idea.
I got talked into it..
It only took few minutes before my mind was made up.
Nonetheless I came up with an idea.
Since Robert's and mine names both start with R, I made a little sticker honoring his involvement with the build.
Pic is a bit blurry but...
It says "Я2 Production"
Old 07-22-2018, 01:23 AM   #532
Shipman
Member#: 312847
2006 WRX STi
2008 Legacy/2003 Forester
Bruh.
Shipman is offline   Reply With Quote
Old 07-23-2018, 01:27 AM   #533
BBY_Hero
Member#: 234236
06 STI
AW
I'm gonna need at least 50 more high res photos..
BBY_Hero is offline   Reply With Quote
Old 07-23-2018, 12:16 PM   #534
remski
Member#: 151895
So far all good here.
Fluid looks "calm". Just drove it easy.
Old 07-23-2018, 12:16 PM   #535
remski
Member#: 151895
Once I give it a wash, I'll do a small photo shoot.
Old 07-23-2018, 09:56 PM   #536
remski
Member#: 151895
The tale of invisible string.
It was time to do one of them alignments.
I had to somehow square the adjustable lateral links.
There was a bit of toe on the rear and the front right was out qute a bit.
Seems to drive a bit better.
Scales came in handy as they lifted up the car.
After that was a time for a first wash...
Thus finally some better pics.
Old 07-23-2018, 11:22 PM   #537
91 RS RA
Member#: 457410
1991 Legacy RS RA
Damn that looks good.
91 RS RA is offline   Reply With Quote
Old 07-24-2018, 10:04 AM   #538
honestabe
Member#: 261730
17' GTI
Amazing. This build thread alone makes it worth checking out nasioc every so often.
honestabe is offline   Reply With Quote
Old 07-24-2018, 02:11 PM   #539
remski
Member#: 151895
Glad you guys are enjoying.
Old 07-25-2018, 02:56 AM   #540
AWD BRO
Member#: 488722
2000 2.5rs w/EJ20K
& (now) 3 other GCs
Just lurking around trying to gain inspiration for my next build and oh man did your car do it for me. Beautiful man.
AWD BRO is offline   Reply With Quote
Old 07-27-2018, 11:45 PM   #541
remski
Member#: 151895
And tonight .. on "wtf did you do in 5hrs.."
Finally got around to completing the steering wheel wiring.
Wheel is much smaller than stock and it covers the cluster a bit.
But on the plus side .. with the quick release it moved the wheel towards the driver.
Last but not least got tired of looking at the beat-up charge pipe...
It now has a brushed finish.
Old 07-28-2018, 10:25 AM   #542
Smurftastic
Member#: 243697
17.4 PSI ECUtuned 02
BLOD Cofounder|TopScoob31
Looks phenomenal man, amazing work!
Smurftastic is offline   Reply With Quote
Old 08-02-2018, 09:03 PM   #543
remski
Member#: 151895
Debate, measure, debate, measure, cut, epoxy, wait, sand, epoxy, wait, wrap.
This "only" took few hours....
And here it is installed.
Old 08-06-2018, 04:32 AM   #544
bigBADbenny
Member#: 314324
MY07 Lib GTB 6MT Wag
Soooo many DROOOOLZ!
Let your (future) sponsors know we’re all following intently :P
bigBADbenny is offline   Reply With Quote
Old 08-06-2018, 04:05 PM   #545
remski
Member#: 151895
I tried and gave up on sponsors.
I guess they've seen many builds but few ever got completed?
Thus no stickers on the car.
Garage cabinet doors host them all.
Old 08-06-2018, 05:31 PM   #546
06lgtsubie
Member#: 489764
Nice job...
06lgtsubie is offline   Reply With Quote
Old 08-06-2018, 05:32 PM   #547
06lgtsubie
Member#: 489764
One of these days I will learn patience enough to do this
Old 08-06-2018, 08:26 PM   #548
remski
Member#: 151895
I've done s**t 1/2 assed before...
And I had to redo it.
Thus.. do it once, do it right.
Old 08-07-2018, 03:25 AM   #549
07imprezRS
Member#: 164302
11 STi DGM, 07 WRX
WRB, 02 WRX WRB
This project truly came out amazing, I know you still have a few final touches to do but wow
07imprezRS is offline   Reply With Quote
Old 08-08-2018, 11:12 AM   #550
seventune
Member#: 488863
'99 Impreza STI
As everyone has already said amazing build. The whole thing has come together very nicely. Mega Subaru.
seventune is offline   Reply With Quote
