Welcome to the North American Subaru Impreza Owners Club Sunday January 19, 2020
Old 11-20-2019, 04:46 PM   #1
Boomstrawberry
Member#: 482313
03 Impreza WRX
Default No start after accident!
Recently i crashed my 03 wrx automatic and after getting it towed home it wouldnt start. I don't believe the problem is electrical because ive tested all my fuses and hooked the car up to an obd2 sensor which brought up no codes and was able to speak to the ecu fine as i got engine temp and other vitals that were correct. I also dont believe the problem is fuel related as you can hear the fuel pump when you first turn the car on and i can hear fuel injectors when turning the key over. We also put some fuel down one of the vacuum lines and it still wouldnt fire. The car is cranking but there seems to be no vacuum on the line we pulled to pour fuel down. Could the timing belt have skipped at tooth durring the accident that is stopping the car from starting? Also the oil fillter neck snapped off could that cause the car to not start for any reason? Any help would be much appreciated i really dont want to give up on this car yet. The car was hit on the drivers side fender and crushed the battery, oil filler neck, and part of the timing belt cover. I can upload pics of the car later when i get home. Edit: it did skip time and unfortunately the engine seems to be toast. So if any one needs parts from a black 03 wrx let me know id be more than happy to sell what i have that still works to someone who could use it.
Boomstrawberry is offline   Reply With Quote
Old 11-21-2019, 01:52 PM   #2
limpingalong
Member#: 508593
2003 2.5 NA OBS
Green/Gold Two Tone
RIP... sorry to hear that man
Goodluck
Mind if i ask if its a wagon or sedan?
limpingalong is offline   Reply With Quote
Old 11-21-2019, 02:07 PM   #3
Boomstrawberry
Member#: 482313
03 Impreza WRX
Default Sedan
Yea its a bummer i still need to take the engine apart to see how bad the valves are bent. But it is a sedan and i have a brand new hood, front bumper cover, and grill.
