Welcome to the North American Subaru Impreza Owners Club Sunday January 26, 2020
Old 06-23-2011, 10:15 PM   #1
Clutch920
Member#: 235324
Default Crank pulley wobbling...
So I replaced my belt alternator belt not too long ago because it was consistently squealing and just driving me nuts. Replacing it fixed the squealing for a few days, but it soon came back, and worse than ever. Upon popping the hood i noticed the crank pulley wobbling just a little bit, enough to make the belt squeak, and I noticed there's black dust all over from the belt.
My question is how I go about fixing this. I've tried doing searches but can't seem to find any walkthroughs or explanations. Is this something I can do in my garage? I know that some pulleys have bearings, is this one any different? Thanks for any and all help. I am still a noob and I'm still learning everything about my Subie. Thanks.
Clutch920 is offline   Reply With Quote
Old 06-23-2011, 11:38 PM   #2
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
There is no pulley bearing. Odds are it is NOT wobbling and you are seeing the timing mark play illusion tricks with your eyes.
Old 06-24-2011, 12:51 PM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
tighten crank pulley bolt..
Old 06-24-2011, 02:06 PM   #4
Clutch920
Member#: 235324
I already tried tightening the bolt, it seems to be tight enough. Is there anything else that could be making this noise from that pulley? i know it's that particular pulley, because if I spray something like wd-40 in between the block and the pulley it immediately stops squealing...
Old 06-24-2011, 02:12 PM   #5
02redwagone
Member#: 87067
02 Old but tasty
SRP
http://forums.nasioc.com/forums/show....php?t=2195400
Take it off. Find out why. Replace worn key or whatever is causing it. It may wobble slightly forever and never get worse. Or...It will mill out the entire inside of the pulley with the remnants of the key, take the face off the sprocket and make a huge ****ing mess. Which was my case.
My pulley doesn't even have the illusion of wobbling from any angle. But its now a kartboy pulley with custom hardware.
02redwagone is offline   Reply With Quote
Old 06-24-2011, 10:04 PM   #6
verendia
Member#: 54550
1995 LX
graphite grey
Torque crank bolt to 85ft lbs by removing all drive belts, hold pulley with a chain type vise grip, i used an old cut up timing belt to wrap the crank pulley before i lock the chain vise grip. It would help to get somebody to hold pulley while you torque. Good luck!
verendia is offline   Reply With Quote
Old 06-25-2011, 01:23 PM   #7
Clutch920
Member#: 235324
Thanks Verendia, i'll have to try this. I'm going to take the pulley off first to make sure it's not warped or anything, and to make sure the keyway was installed properly (these pulleys were already on the car when I bought it, so I have no idea).
Old 03-15-2012, 09:47 PM   #8
leach0789
Member#: 210903
2013 MS3/Turbo Miata
Nitrous Rhodes
Sorry to bump an old thread...but what was the result of this?
leach0789 is offline   Reply With Quote
Old 03-15-2012, 10:56 PM   #9
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
I don't know about him specifically, but the crank pulley is made out of multiple pieces - inner steel, rubber isolator, and outer steel. With age, or sometimes contamination or defect, the layers can come unglued (so to speak) and the outer chunk can move around on the inner chunk. The purpose of this pulley is to dampen harmonic vibrations in your motor as well as run your accessories, so if the pulley itself is coming apart it's not doing either of its jobs very well. Replace the pulley if this is the case.
CosmoTheCat is offline   Reply With Quote
Old 03-15-2012, 11:19 PM   #10
leach0789
Member#: 210903
Nitrous Rhodes
Thanks. Exactly what I was looking for.
Old 03-16-2012, 03:16 AM   #11
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
The crank bolt should be tightened to 110. 100 is the specification.
ciper is offline   Reply With Quote
Old 03-19-2012, 01:23 AM   #12
lowwill
Member#: 263598
Just changed mine cause of the delaminating. Rubber completely worn away. $227 for a crank pulley from Subaru
lowwill is offline   Reply With Quote
Old 03-19-2012, 02:04 AM   #13
02redwagone
Member#: 87067
02 Old but tasty
SRP
Could have had a kartboy.
Old 03-19-2012, 02:11 AM   #14
scandiflick
Member#: 297798
2011 WRX Stage 1
WR Blue
throw on a perrin and save 4 pounds they cost about 100 bucks i think
scandiflick is offline   Reply With Quote
Old 09-15-2012, 07:00 PM   #15
SubaruImpreza_power
Member#: 13910
2005 Legacy GT
blue
This just happened to me getting on the highway with my EJ25 in my outback, first clue was I lost my belt for the Alt & PS pump, so I found a safe place to pull over and the crank pulley is wobbling, and just as I was slowing down I heard something fly under the car which I expect is the pieces of rubber from the crank pulley?
Because I thought the bolt was loose but it was not.
I was about 8 or so miles from home. I think I'm going to go with a lightweight one now, However I don't know if the key got messed up? I don't think it did since the bolt did not move? I will say I started getting misfires on all 4 cylinders a day before it happened.
SubaruImpreza_power is offline   Reply With Quote
Old 11-18-2019, 11:47 AM   #16
pcampbell
Member#: 437670
2005 2.5 SC OB
I noticed my crank pulley was wobbling yesterday. I took it off and re-tightened it. It was not loose at all to begin with, but I re-cleaned threads and oil soaked the 22mm bolt. The key slot in the pulley was totally fine (undamaged).
It was still wobbling after re-tightening so I threw on a new pulley I happened to have sitting here, and the wobble is gone. So I believe in my case the wobble was in the pulley itself, not in the crank, the woodruff key or anything like that.
I will add that my pulley is 200k+ miles old and I tighten my PS/alt belt very tight because it has a Supercharger on it. This would certainly add stress to the entire setup.
One thing... I could not for the lift of me figure out how to loosen the crank bolt even with a company23 tool. I just didn't have the strength or leverage. Finally I used my longest breaker bar and I rested the bar on my shoulder, with a 2x4 between the bar and my shoulder to spread the load out on my body, then put my entire body into the bar and it broke open. Another thing. A mid depth 22mm would help. I have a shallow and a deep but with the company23 tool on there, a mid depth is desirable.
pcampbell is offline   Reply With Quote
Old 11-21-2019, 04:12 AM   #17
CosmoTheCat
Member#: 3409
98 My FMIC
Socket + breaker bar braced against something solid - chassis, floor, etc + blip the starter. It almost always works.
Crank pulley wobble WRXislander Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 12-04-2007 10:57 PM
bad crank pulley wobble JaMes W Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 06-22-2004 11:02 AM
Wobbling L/W Crank Pulley? DrBoy01 Normally Aspirated Powertrain 12 08-05-2003 10:18 AM
Crank pulley wobbly, grinding--Not Good! Max Umbarger Service & Maintenance 2 06-10-2002 10:36 AM
Crank Pulley Wobble rexxman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-23-2001 11:04 PM
