Welcome to the North American Subaru Impreza Owners Club Monday January 20, 2020
Old 12-02-2009, 11:52 AM   #2551
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
Originally Posted by Slimsti View Post
I have the new HFS-6 kit and every 3 or 4 days while driving ill stop at a light and i hear a VERY loud repeated clicking noise coming from behind my guages.AFter further inspection it seem the black box mounted against the firewall is clicking.Even after i stop the car,turn off the ignition and turn the key to accessory it starts click again. Any ideas? After sitting overnight though the problem disappears.
Can you check where the +12V (red) and ground (white and black) is connected to. I am referring the the 4-way molex connector. Make certain they are all firmly terminated and bolted down respectively.
Did you install the system yourself?
Richard
Aquamist is offline   Reply With Quote
Old 12-02-2009, 11:55 AM   #2552
Aquamist
NASIOC Manufacturer
Member#: 110029
Originally Posted by LittleBlueGT View Post
My buddy just decided to get the HFS-6 (looks like I was finally a positive influence on him!), what I need is the wiring schematics of an 09 WRX.
(injector negative, MAP wire, but even a positive ignition wire, and a headlamp switch would be nice too!)
Does anyone have the ECU pinout for the 09wrx? If so, I would be grateful if you can email them to me [email protected] Thanks in advance.
LittleBlueGT,
Thanks very much for your constant support for the aquamist product
Richard
Old 12-03-2009, 12:49 PM   #2553
LittleBlueGT
Member#: 96204
2013 STI GR
LittleBlueGT,
Richard
I will always support good manufacturers that come up with the best products!
LittleBlueGT is offline   Reply With Quote
Old 12-03-2009, 01:12 PM   #2554
Edo Performance
Member#: 70537
Hey Richard, sent you a message
Hey Guys, we have this system HSF 6 in stock and please call us if you need to inquire about this product
regards,
Edwin
Edo Performance is offline   Reply With Quote
Old 12-10-2009, 05:35 PM   #2555
underpowerd
Member#: 118442
05 LGT+PE1818+HFS6
+1, not to mention outstanding customer support -- Richard, thanks again for the help with the fittings, you are the tops
I need a .9 nozzle/4mm; could you please direct me to the quickest way could I buy one?
thanks in advance.
underpowerd is offline   Reply With Quote
Old 12-10-2009, 05:54 PM   #2556
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
I agree with everyone else, Aquamists customer service to Customers as well as Dealers is top notch!
We have 0.9mm/4mm hose jets ready to ship. $21.95 + $6.50 ship (assuming Maryland). We can have 1 in your hands early next week. More information available here:
http://www.iaperformance.com/product...oducts_id=2173
Please let us know how else to help.
[email protected]
Aquamist Dealer
IA Performance is offline   Reply With Quote
Old 12-11-2009, 08:18 PM   #2557
666stars
Member#: 221364
2002 Wrx EJ207 Ver 8
Wrb Dccd jdm 6 speed now!
thanks in advance.
i have one. let me know
666stars is offline   Reply With Quote
Old 12-14-2009, 09:13 AM   #2558
triniscoob
Member#: 143225
2004 JDM Sti
quick question, imn plannign to mount the pump behind the front bumper for the HSF-5 kit- does ti make a difference if i mount the pump vertically or horizontally?
if i would like to mount it Vertically which side should face upwards?- The side of the pump with the Motor or the side with the inlet and outlets for the hoses?
Thanks!
triniscoob is offline   Reply With Quote
Old 12-14-2009, 09:37 PM   #2559
Aquamist
NASIOC Manufacturer
Member#: 110029
Thanks!
The pump can run in all orientations. We normally ask user to install it vertically, pump head down. (motor on the top).
Old 12-14-2009, 10:08 PM   #2560
Aquamist
NASIOC Manufacturer
Member#: 110029
thanks in advance.
Did you managed to get your jet? Many thanks for your support.
Old 12-14-2009, 11:42 PM   #2561
Murphdog
Member#: 75414
2004 STi
Its the Blue one
I have the HSF-6. I started to do my prechecks. When I try to simulate 100% injection I hear the pump turn on and the flow control module clicks but no spray. I removed the large in line off the flow module and tried it and it is pumping out fluid. The first time I tried a small amount filled the out line but no spray. Is there anything I missed.
Murphdog is offline   Reply With Quote
Old 12-15-2009, 06:13 AM   #2562
Aquamist
NASIOC Manufacturer
Member#: 110029
Can you remove the small line (4mm) off the FCM and tell me if the liquid is coming out. (remove the inline restrictor first)
Richard
Old 12-15-2009, 12:14 PM   #2563
Murphdog
Member#: 75414
2004 STi
Its the Blue one
I'll will check later today. When I first started to prime it the small line filled with fluid for a second than nothing. I tried putting a little vacume to the small out line but it seems like it is closed off.
Old 12-15-2009, 12:48 PM   #2564
Aquamist
NASIOC Manufacturer
Member#: 110029
pm me your phone number so that we can do the test together, might help.
Richard
Old 12-15-2009, 01:02 PM   #2565
AkumaMotorsports
Member#: 214570
Bump for hands down the best meth injection unit on the market! The guys and girls over at Aquamist is top notch, we've been working closely with them to develop the meth kits for the Nissan R35 GT-R's. We have nothing but excellent things about them!
Cheers!
-Alex
AkumaMotorsports is offline   Reply With Quote
Old 12-15-2009, 06:10 PM   #2566
Murphdog
Member#: 75414
2004 STi
Its the Blue one
Figured it out. I had the restrictor in backwards. I'm an idiot. Thanks again for the help. This is why Aquamist is the best; amazing product and beyond top notch customer service. Richard I hope you get paid well. You deserve it.
Old 12-18-2009, 05:30 PM   #2567
Aquamist
NASIOC Manufacturer
Member#: 110029
Alex, welcome. Thanks for the ECU information for the R35 - without it, I would not be able to work on the kit.
Old 12-21-2009, 01:42 PM   #2568
dailo13
Member#: 39083
2002 Impreza WRX
Hi Richard,
If you answered this question before, I'm apologize, but I didn't want to search through 105 pages of this thread since the search function didn't really give me an answer.
I'm trying to import my US 02 WRX to Taiwan as I miss my car dearly. Over here, on top of smog and noise tests, there is a gas mileage test. In my current state of tune with a Cobb Protune of a 2.5l (EJ255) longblock and pink STi injectors (560cc?), I average about 22mpg(US) or about 9.3km/liter. The local guidebook states that my car has to run at least 10.5km/liter or about 25mpg(US). My question is, I understand you have a product that will allow injection starting from idle all the way up to full boost. The car will be tested on a dyno running very conservatively. I checked and the test will only run the car at low to mid rpm only up to 90kmph, so doubtful it will see a large amount of boost. Do you see any way for your product, given the right tuner and amount of time, allow me to gain an extra 3mpg(US) from injecting starting at idle on a very economical tune? This seems to be the only stumbling block preventing me from legally importing my car over here. I thank you in advance for any advice you can give.
dailo13 is offline   Reply With Quote
Old 12-22-2009, 04:51 AM   #2569
Aquamist
NASIOC Manufacturer
Member#: 110029
There are other simplier methods you can consider before using water injection.
- Using higher octane fuel
- You can run leaner AFR outside the boost range (Cobb)
The above methods will get you there.
Or you can use the Aquamist to get you there without standard octane pump fuel. There is no problem covering the range from idle to full boost. Knock resistance and advanced timing is the one of the way forward.
Old 12-22-2009, 10:03 AM   #2570
dailo13
Member#: 39083
2002 Impreza WRX
Thanks for your response, Richard. I was hoping that an aquamist controller will help me keep the car running safely as I lean out the AFR for more mpg all the while being off of boost. I will once again be united with my car. Thanks, again!
Old 01-04-2010, 03:46 PM   #2571
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
hm..
with my system rewired, and FIA disconnected I get the warning orange light bleep dim time to time under load
is there a shortage somewhere?
Hyper is offline   Reply With Quote
Old 01-04-2010, 04:04 PM   #2572
Aquamist
NASIOC Manufacturer
Member#: 110029
Can you remind me your system details and setup... saving me looking up old mails.
Old 01-04-2010, 04:16 PM   #2573
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
oh sure, my bad
2d system w/optionary accumulator
engine bay mounted, boost failsafe connected
from the main 40A relay red goes straight to battery, black to ground, purple goes inside the cabin and hooks up to switched 12v source
the whole system is currently disconnected, which is what surprised me
pump is off (through aux button I hooked up), FIA2 is disconnected, MPS is not connected to a boost source
I assume it might be feeding off injector pulse or boost controller since it only lights up under load
odd)
Old 01-04-2010, 04:47 PM   #2574
Aquamist
NASIOC Manufacturer
Member#: 110029
Thanks for the reminder.
The 2d sytem will not without the FIA2. The 2d has under gone many electronic/mechanical updates, with know the exact version, the yellow LED is responsible to indicate low tank level?
The please check the wire that goes to the water level sensor is not grounded.
Richard
Old 01-04-2010, 05:17 PM   #2575
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
I don't have the low tank level hooked up yet, only boost cutting when failsafe is enabled
I can check the exact version if you tell me how I believe it's the older generation with the wiring harness that doesn't have a pre out for tank low level
Passing the NEW required OBDII Emissions test in PA Questions and Answers!! mrtrex Mid Atlantic Impreza Club -- MAIC 29 03-10-2013 08:23 PM
Snow Performance questions and answers... Ultimate Collision Center Water/Methanol Injection, Nitrous & Intercooler Cooling 374 09-23-2008 05:36 PM
Motörhead Guidlines, questions and answers here: GO LEMMY!! El Camino Off-Topic 9 01-20-2006 03:39 PM
Roll Center, questions and answers Arnie Brakes, Steering & Suspension 5 12-21-2004 04:26 PM
