Welcome to the North American Subaru Impreza Owners Club Wednesday January 23, 2019
Old 12-24-2005, 11:04 AM   #1
EricClouser
Member#: 103567
95 Impreza
Red
Default 95 Impreza Blues
ok here it is, a 1995 impreza 2.2l. 170,000 miles. automatic, all wheel drive. timing belt idler pulley blew apart on highway. Got new pully, timing belt and crank sensor and cam sensor from local dealer. Installed new parts, car turns over fine but will not start. Pulled codes, p0201, po202, p0203, p0204.. Fuel injector circuits open. hooked up noid light set.. i have injector pulses. Tried starting fluid, no luck. checked for spark, got that. checked compression, 120psi in all cylinders. checked and rechecked timing, it is dead on. I know that this 2.2 is not an interference engine. or so i have been told. Any Ideas??????? i am ready to junk this car
EricClouser is offline   Reply With Quote
Old 12-24-2005, 12:17 PM   #2
avk
Member#: 17252
'06 WX8
59E
Want wiring diagram?
avk is offline   Reply With Quote
Old 12-24-2005, 12:21 PM   #3
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Just a thought, but make sure your crank sprocket is in good condition. With all those parts flying around, you could have damaged a Crank Sprocket ear that the Crank Sensor uses to detect revolutions. Here is a pic:
I take it that the timing belt came off the car? Are all the pistons in the middle of the cylinder when the timing marks are lined up? If so, the white arrow on the crank sprocket will be pointing to the driver's side of the car.
-Charles-
edit: New photo
ImprezaVA is offline   Reply With Quote
Old 12-24-2005, 02:26 PM   #4
EricClouser
Member#: 103567
95 Impreza
Red
Charles,
your picture showed me something I did not know.. I had the arrow on the crank pointed up to the timing mark on the block. I fixed that and the car started first try. Thanks alot for the help.
Eric
Old 12-24-2005, 03:50 PM   #5
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Glad you didn't have to junk your car
-Charles-
95 aegean blue impreza l hood voteforpedro18 Exterior/Styling 1 06-01-2010 07:55 PM
WTT or WTS: (MA) 95 Aegean Blue Impreza AWD. 2100 FIRM voteforpedro18 Private Vehicle 'For Sale' Classifieds 24 05-04-2010 12:01 PM
WTB: 95-95 Impreza Heater Core Pakin NWIC Private Classifieds 7 01-26-2010 02:14 PM
WTT: 95 Impreza Coupe for 95 Impreza Sedan bigboss MWSOC Private Classifieds 9 02-18-2007 05:40 AM
will 93 legacy 5spd ecu work on 95 impreza after swapping 5spd into impreza? 2slofouru Subaru Conversions 7 01-28-2006 08:34 PM
