Welcome to the North American Subaru Impreza Owners Club Wednesday May 18, 2022
Go Back   NASIOC > NASIOC Technical > FB Series Normally Aspirated Powertrain
Old 01-25-2022, 11:31 PM   #1
second cup
Member#: 508732
2005 9-2x
Default 2019 Crosstrek radiator and fan removal
Anyone know how to remove radiator and fans from 2019 Crosstrek? Can't find anything on YouTube. Thanks!
second cup is offline   Reply With Quote
Old 01-26-2022, 08:24 AM   #2
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
Just like most any Subaru (excepting Tribeca)
Drain coolant, disconnect and/or remove upper/lower radiator hoses, remove overflow tank. Unplug the electrical connectors from fan motors and remove the 10mm bolts from top edge of fan shroud. Tilt back and lift out fans/shroud assembly. Unbolt the two brackets on each side of top of radiator, tilt radiator back and lift out.
Elbert Bass is offline   Reply With Quote
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
