Welcome to the North American Subaru Impreza Owners Club Tuesday January 15, 2019
Old 02-07-2009, 01:41 AM   #1
ckcadavona
Member#: 135730
93 L
Default Version 5/6 EJ207 OBD-II
Are the 1999-2000 V5/6 EJ207's OBD-II? If so, can someone help me find the wiring for the OBD-II port in the following wiring diagram? If not, how do I pull the check engine light codes off the ecu?
Background: Recently swaped V5 EJ207 in place of 93 1.8L. I'm getting intermittent check engine lights. I've tried connecting the black connectors under the dash to pull the code off the ecu but the check engine light doesn't flash. I even tried the green connectors and both, but still no flash. I was under the assumption the V5 EJ207 was OBD-II because Ecutek supports my ecu code (AE481). I think when they pulled the wiring harness in japan they may have unplugged the wiring from the back of the OBD-II port.
Here's the link to the wiring diagram(thanks Jaxx):
scroll to pages 31-36
http://www.linkecu.com/support/dland...Y99Manual/view
Here's few pictures of the plugs under the dash I'm talking about:
black/green connectors mentioned
2 connectors on the left are in addition to above
better shot of yellow connnetor wiring
ckcadavona is offline   Reply With Quote
Old 02-07-2009, 01:33 PM   #2
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
Looks like you need to wire in connector B40. You should be able to trace the RW wire from the test connector to the OBDII plug. If its not in the harness some where then you should have some wires cut and hanging out. I will take a look at my harness and see where the obdII wires run. IIRC when I flipped my harness I had to extend the obdII connector wires, you might want to look for the connector over by the ecu somewhere.
Here is some info on the test and read connectors. It applies to the svx but it may be similar.
http://www.wbx6.de/doc/selbstdiagnose_motor.pdf
Scoobie Steve is offline   Reply With Quote
Old 02-08-2009, 11:56 PM   #3
ckcadavona
Member#: 135730
93 L
Looks like the read memory ground wasn't grounded. After grounding I'm getting a code 24. Which according to the SVX link is a bypass air control solenoid valve which is the same code as the pre 97 ej22t, ej20g, ej20k, etc.
Old 02-10-2009, 12:43 AM   #4
ckcadavona
Member#: 135730
93 L
Are you saying I need to find a 16 pin OBD-II plug and wire it in per the Link wiring diagram
B40 pin 6 > B76 pin 2 read memory
B40 pin 10 > B136 pin 13 ?
B40 pin 1 > B47 pin 4 main relay ?
B40 pin 12 > ground ?
B40 pin 13 > ground ?
B40 pin 4 > B136 pin 4 select monitor signal
B40 pin 5 > B136 pin 3 select monitor signal
Any luck with checking youre wiring out?
Old 02-10-2009, 03:10 AM   #5
Scoobie Steve
Member#: 2289
Yes if your harness doesnt have an OBDII port/plug tucked in somewhere it SHOULD. I did check mine and it didnt appear that I modded the wires. Like I said try tracing some of the wires you listed, they should lead you right to the plug.
Old 02-10-2009, 06:23 AM   #6
jeffmoorman
Member#: 105736
2011 135i
lemans blue
i thought obd2 wasn't integrated into jdm cars until v7..
jeffmoorman is offline   Reply With Quote
Old 02-10-2009, 07:09 PM   #7
Scoobie Steve
Member#: 2289
Complete OBDII compliance wasnt integrated until Ver 7 but Ver 5/6 still have an OBDII style plug. Another thing to note is the Delta dash reads codes for the Ver 5/6 in the generic P format. I dont know that I trust your code 24 100%....that is for older OBDI cars and may not be the same.
Old 02-10-2009, 09:04 PM   #8
ckcadavona
Member#: 135730
93 L
Steve, I found your old thread... http://forums.nasioc.com/forums/showthread.php?t=299593 and it seems my check engine light comes on in the same situations...always on decel, usually on a hill, but not always, but always under engine braking conditions and it goes out right away. Did you ever find the source behind this?
Old 02-10-2009, 09:54 PM   #9
Scoobie Steve
Member#: 2289
Wow 6 years ago. I hate to say I cant remember the solution or really what caused the problem. MAF is always suspect, I went through many. That was shortly after I finished the swap....hmm.
Old 02-10-2009, 11:54 PM   #10
ckcadavona
Member#: 135730
93 L
maf is new...hopefully I can figure out the OBD-II wire in when I get some time
Old 02-17-2009, 02:17 PM   #11
Keenah
Member#: 133754
1998 3.6RSTi
All blue, all blue baby
Yes you need an OBD2 port since your car did not come with one. I'm assuming you merged your v5 into the L, and didn't do a RHD swap. FOr the OBD2 port you would only need to wire the powers/grounds and the pin 10 to the ECU. Then you need a version 1 tactrix cable and a program called ECU explorer. That will read your code.
Keenah is offline   Reply With Quote
Old 02-17-2009, 06:42 PM   #12
Scoobie Steve
Member#: 2289
Just so we are clear Ver 5/6 cars DO come with an OBDII plug from the factory. There should be no need to wire one in.
Old 02-18-2009, 12:47 AM   #13
ckcadavona
Member#: 135730
93 L
I took a quick look at the ecu pinouts today and noticed b136 pin 13 is empty. B136 pins 4 and 3 are wired but I'm not sure to where yet.
Old 02-18-2009, 01:06 AM   #14
Keenah
Member#: 133754
1998 3.6RSTi
You don't care where 4 and 3 go because its for the subaru select monitor tool which you don't have. Are you sure pin13 is empty because someone would have to physically remove the pin to have that happen.
Unless you merge in the harness, it gets cut during the stripping process.
Old 03-15-2009, 11:12 PM   #15
ckcadavona
Member#: 135730
93 L
update...
I got a used Delta Dash hard wired into the proper wiring and its the same code. 24 isc valve (stick). Thanks for all of the help everyone. I think the used Delta Dash was worth it considering the additional features.
Old 12-18-2010, 02:03 AM   #16
Jimbo2NR
Member#: 259095
I have the same code 24 Version 6 WRX. Now my idle stays really high even when coming off the throttle, very annoying. Can someone show me a pic of the engine so I can see where the ISC valve is so I can try cleaning it? Thanks
Jimbo2NR is offline   Reply With Quote
Old 12-19-2010, 07:11 PM   #17
Scoobie Steve
Member#: 2289
It is mounted on the top of the throttle body.
Old 12-24-2010, 03:48 AM   #18
ckcadavona
Member#: 135730
93 L
I've tried cleaning it, I've tried swapping it, and I have 3 used spares and have yet to get rid of the the 24 code. It only comes on when i engine brake / down shift sometimes. Once I let the RPM's go down the light goes out.
Every time I have swapped the sensor the ecu re-learns the new sensor. Some took longer than others. Some worked better than others.
Old 12-30-2010, 09:43 AM   #19
Jimbo2NR
Member#: 259095
I have the exact same problem, so annoying
Old 12-30-2010, 07:39 PM   #20
N8WRX
Member#: 99395
2015 Impreza WRX
World Rally Blue
not sure if you tried used ones the times you have replaced it but these sensors are EXTREAMLY common to go out the door. I had to also replace mine when i did my version 7 swap, i know not a 5/6 but same sensor and it crapped the bed. Needed to replace it with a brand new one to fix the issue i had. Good luck
N8WRX is offline   Reply With Quote
Old 01-07-2011, 12:18 PM   #21
ckcadavona
Member#: 135730
93 L
It has not seemed to affect anything else. I have made it come on and did a pull from 2k-6k and had no issues. I even data logged it. Not worth the 200-300 the dealer is asking.
WTB: LI, NY: Version 5/6 STI Type-R Cams - (aka v5/6 Camshafts) chrisarella Tri-State Area Private Classifieds 5 05-08-2009 06:34 PM
WTB, NY: Version 5/6 STI Type-R Cams - (aka v5/6 Camshafts) chrisarella Private 'Wanted' Classifieds 2 05-08-2009 12:45 AM
FS (AL): 1999 STM RS w/Version 5 STi EJ207 swap, Version 7 Seats 992.5RS Private Vehicle 'For Sale' Classifieds 35 02-27-2008 03:49 PM
Feeler: Apex'i PowerFC for JDM version 5/6 EJ207 dmross 1993 - 2001 Impreza Specific Parts 0 09-12-2007 02:44 PM
need JDM version 5/6 version spoiler Yusuke Private 'Wanted' Classifieds 0 08-04-2005 12:40 AM
