Welcome to the North American Subaru Impreza Owners Club Tuesday December 11, 2018
Old 11-20-2002, 04:17 PM   #1
Matty
Member#: 13408
2008 LGT
black
Default HP gains on this Mod.
Considering I have a MRT turbo back...Perrin Uppie..Samco Hoses..Apexi avc-r set at 15psi..If I go to a walbro FP STi injectors a vf30 with a u-tech Watch gains can I expect given its tuned properly..
Matty is offline   Reply With Quote
Old 11-20-2002, 04:52 PM   #2
TurboRex
Member#: 8635
04 STI, 07 FXT
If you crank up your boost to about 16.5 in 4th you can net another tenth or so. Beyond that, the vf30 will probably help another 2-3 tenths running 17psi. If you add the utec and increase your boost to about 19psi, I would guess a minimum of 2 tenths improvement but more likely closer to 4 tenths if tuned right. Have fun.
Greg
TurboRex is offline   Reply With Quote
Whats your opinion on this mod mogrl840 Interior & Exterior Modification 11 09-02-2008 01:43 AM
pls provide me a sample log base on this mods... horriblesars Open Source Reflashes 0 07-06-2008 11:42 AM
can i run a stage 2 map on cobb ap on this mod.? Mr. SUAVE AccessPort 9 04-07-2006 02:31 PM
boost controler.....max hp gain on stock car? KnightWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-10-2003 10:42 AM
HP gains from these mods... Rich L Technical Forum Archive 4 08-10-2000 04:41 PM
