02-22-2006, 08:09 PM | #1251 |
Member#: 94945
Vehicle:2015 Dodge Charger AWD |
02-22-2006, 08:29 PM | #1252 |
Member#: 41172
it's got a 20g now. 40t rapidly developed shaft play. momentum rebuilt it and I sold it. anyway, in betw boost leaks, exahust leaks, and a few other issues, it is a looot of fun.
02-22-2006, 08:39 PM | #1253 | |
Member#: 60224
TMIC’s are limited (by their size) with the air-charge they can support, which typically maxes out around 5~600CFM and is well suited for your run of the mill mid-range turbos (VF22, VF30, VF39, 16G, etc). For those who run larger turbo applications (any superzilla, GT series, etc) a much larger IC is required to cool the 600+CFM flows. Unfortunately you just can’t stuff a 28”x10” long core under your hood scoop otherwise we’d all be running TMIC’s.. |
02-22-2006, 10:18 PM | #1254 |
Member#: 41172
also the new legacy has a puny (aerodynamic) scoop compared to wrxs and sti's - even with a larger TMIC there is a question about how much air it can flow.
02-22-2006, 10:22 PM | #1255 | |
Member#: 94945
The Legacies have a much longer hood to shape the air, and don't need as big of a scoop. just what I've heard |
02-22-2006, 10:50 PM | #1256 |
Member#: 13617
Vehicle:2001 Legacy GT back to stock is a project too |
plus just from what i can visually see, the legacy scoop is basically cut into the hood so air flow basically continues straight into the IC, where as the STi or wrx had to pull air in and direct it onto the IC.
Ben |
02-22-2006, 11:37 PM | #1257 | |
Member#: 106785
Vehicle:1998 POS Ford Steel blue |
oh, now don't say that. anythings possible. I like the lack of piping for the top mount on the flat engine, extra piping equals pressure drop, and reduction of inlet port velocity. |
02-23-2006, 03:10 AM | #1258 |
Member#: 13617
do a reverse intake manifold like me and you will eliminate a lot of that piping Eventually I plan to do a setup to cut down the piping to under 3' if you make your own setup you can have all the benefits with almost zero drawbacks.
Ben |
02-23-2006, 03:31 AM | #1259 |
Member#: 106785
what side of the engine is the turbo on with these?
I would be really prone to make it twin turbo with a turbo one each head right under the car, has that been done? or would that hang too low? |
02-23-2006, 04:18 AM | #1260 |
Member#: 13617
I originally thought of doing that, however you would need to run a dry sump setup since you can obviously not use a gravity feed return, unless you could get a sealed turbo lubrication unit but I dont think they have them in large enough turbo sizes(IMO). It would be sick and someone is supposedly doing it they have told me, but it will be quite the undertaking if they do. Just the amount of money, I could have easily gone that way but I didnt want to deal with having to CNC a new oil pan and bracket and such for the sump pulley and such.
again, if I had unlimited time and money it may be a route to do as well. It would be awesome to see, I really wish there was someone that actually had the money to pay me to make a setup for them haha, that would be ideal. Ben |
02-23-2006, 08:49 AM | #1261 | |
Member#: 60224
^^That’s a common twin-turbo setup, which IIRC Audi used in their older Bi-Turbo models (S4, S6, S8), one turbo tucked under each side of the exhaust manifold. Of course this was on a V engine, not a flat motor...
This has been the problem plaguing me as well. I can’t fit any larger of a TMIC, and I can’t fab up the stock BD bumper-cover to fit a decent sized FMIC, which is keeping me from upgrading from a mid-range to a big-dog turbo. I’m still working a plan though. I’m thinking the best of both worlds with an AWIC setup positioned in the TMIC location. |
02-23-2006, 07:36 PM | #1262 |
Member#: 106785
air to water works awsome, it does weigh considerably more though.
what companies make WAIC's for the subaru 2.5? |
02-24-2006, 09:51 AM | #1263 |
Member#: 41172
TDC has announced they are coming up with a solution - but more specifically designed for the new leggacies.
02-24-2006, 10:18 AM | #1264 |
Member#: 106785
I still vote huge hood scoop
theres a pic of one on a 06 style wrx in the hella lighting thread. thing looks like a post office drop box, hellz yeeah!!! btw, anybody know were to find one of those huge rally style wrx scoops that could go on a leg hood? or a pic of how obscenely huge it would look? also, is there a company that sells the hood vents from the old skool imprezia rally car? I'm trying to force this wagon of mine to look like a rally car. |
03-12-2006, 03:51 AM | #1265 |
Member#: 76382
BAIC
Vehicle:2000 BH BP Wannabe |
2000 Legacy GT Wagon 106k when pictures were taken (3/12/06). It's strange to think about my ass sitting in the same place for so long. *It looks like my car is slammed, much lower than other cars I have seen with the H&R springs. Not sure why. 02-03 WRX MOMO Steering Wheel 05-06 Legacy GT Shift Knob KYB GR2 Struts H&R Springs Kartboy Short Shifter Kartboy Front & Rear Shifter Bushings Kartboy Differential Bushings Cobb Cold Air Intake Gruppe-S Light Pulley Whiteline Steering Bushings PowerSlot Rotors Carbotech Bobcat Brake Pads Goodridge Brake Lines SpeedBleeders 05 Legacy GT Wheels with RE92A Tires I'll continue to update this list. |
03-12-2006, 04:08 AM | #1266 |
Member#: 5893
E. Canada
Vehicle:1997 Black GC4 1995 White BK6 |
flanders, your car looks perfect. I love the color, the drop, and the 05LGT wheels. Very nice! I'm guessing it handles pretty damn well too from the mods list.
03-12-2006, 11:26 AM | #1267 |
Member#: 94945
great look, Flanders
03-12-2006, 11:38 AM | #1268 |
Member#: 73684
NWIC
Vehicle:2012 4Runner |
Looks great Flanders, and yeah, it does look pretty low. In a good way.
03-12-2006, 02:44 PM | #1269 |
Member#: 82556
Vehicle:1996 Legacy L wagon |
Flanders, the car looks great! I bet some JDM tails would really compliment it nicely. The wheels just look great with that drop. Not usually a fan of the 2000+ model years, but that one does look good.
03-12-2006, 11:13 PM | #1270 |
Member#: 103499
W. Canada
Vehicle:90's gc/bc rusty? |
Going retro. Flat black, spun alum. hubcaps 16" whitewalls, frenched antenna etc..
waiting tilll spring |
03-13-2006, 06:01 AM | #1271 | |
Member#: 106785
I'm not against any of that but your rim/tire choice. you could go with billets? |
03-13-2006, 09:41 AM | #1272 |
Member#: 80074
SWIC
Vehicle:2007 BMW 335i Sapphire Black Metallic |
Some updated pics of the legacy ..after getting my tails tinted!
after washing my car prior to getting tints .. New eyelines with blinkers tinted .. My angel eyes .. Tinted tales |
03-13-2006, 03:39 PM | #1273 |
Member#: 94945
ooooooh, the angel eyes picture is cool
03-13-2006, 09:58 PM | #1274 |
Member#: 37190
RMIC
Vehicle:01 Ford SCrew |
Legacygt05, that is a real sharp ride! Only thing I'd change are the wheels...but thats just personal preference. As a whole package, its a tight ride! Tinted tails, angel eyes, yellow fogs, window tints...nice eye candy!
Did you up the size of the muff tips? GGT |
03-14-2006, 02:31 PM | #1275 |
Member#: 80074
SWIC
yeah ... I changed out the mufflers and went with Magnaflow mufflers with 4 inch tips (Also cut the exhaust silencer out). I am almost done with my suspension mods ... up next some power mods once my fac. warrant runs out
Sweet 16" rims show yourselves. | abosworth | Tire & Wheel | 4 | 04-06-2006 03:38 PM |
1st Gen Legacies, show yourselves! | jamesfacts | Member's Car Gallery | 19 | 01-13-2005 03:58 PM |
Congrats Brickdawg and Mr. 'Bling, Bling' Orion | DanzBorin | Texas Impreza Club Forum -- TXIC | 49 | 03-11-2002 06:16 PM |
