Welcome to the North American Subaru Impreza Owners Club Wednesday January 23, 2019
Old 12-16-2010, 11:36 AM   #126
downest
Member#: 194343
1991 CRX B18C5 turbo
'88 4Runner daily
Yup, I hear you on that, I've got a drawer full of gas lenses that need to be thrown out from welding dirty metal.
downest is offline   Reply With Quote
Old 12-16-2010, 01:02 PM   #127
reid-o
Member#: 103631
2004 STI
Gray
For those of you messing with schedule 10 and 40, what type of saw do you use, especially with stainless?
Do you prefer a chop saw or a bandsaw? Is it just me or does it take a chop saw a heck of a long time per cut?
I'm trying to mess with some pie cuts and the cutting and beveling are taking a dang long time.
reid-o is offline   Reply With Quote
Old 12-16-2010, 01:19 PM   #128
downest
Member#: 194343
'88 4Runner daily
I use sch 10 304 stainless for my manifolds. For the straight pipe I use a tube cutter to get nice clean, straight ends, and to make angles or cut the weld-els up I use either a chop saw or a cutoff wheel by hand, then finish them with a belt sander or air grinder. It sucks, I used to have access to a bandsaw at previous shops but haven't been able to buy one since I started my own place.
Finished tacking up that VR6 manifold... ready for welding!
Old 01-06-2011, 03:09 AM   #129
oguitar
Member#: 206720
2002 WRX Wagon
I have a question for all you welding guru's. I am having a hard time getting the puddle to flow when welding 6061 T6 aluminum. I am using a TIG welder set on AC (90 Amps). Tungsten tips, argon gas and aluminum rod. I can get a puddle formed but I am having a very hard time keeping it flowing. I stepped down on the peddle and blew a hole in the aluminum.
Everything is cleaned before I start welding, and the tip is properly sharpened. Do I need to play with the gas flow or some other setting like that? Any tips for a humble welding newbie? Thanks in advance.
oguitar is offline   Reply With Quote
Old 01-06-2011, 08:03 AM   #130
yo_its_ok
Member#: 6493
2003 WRX
90amps ? kinda high, depending on thickness of material.
http://www.weldingtipsandtricks.com/...-aluminum.html
yo_its_ok is offline   Reply With Quote
Old 01-06-2011, 09:04 AM   #131
InfiniteMotorsports
Member#: 85354
Sounds like your remote is off, which makes it like an on/off switch instead of varying amperage.
InfiniteMotorsports is offline   Reply With Quote
Old 01-06-2011, 09:19 AM   #132
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
Name brand pipe, or cheap Ebay/hardwarestore pipe, billed as being 6061 T6, but actually recycled soda cans??
Had the same problem after my regular supllier was out of stock, ordered some pipe somewhere else, and with the same welding rig etc I had a hard time welding the new suplliers stuff.
Dutch Scooby lover is offline   Reply With Quote
Old 01-06-2011, 11:16 AM   #133
sidewayz
Member#: 5810
2001 S366 2.5RS
Like jake said. Sounds like you have no variable control. What machine are you using?
sidewayz is offline   Reply With Quote
Old 01-06-2011, 01:14 PM   #134
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
We need a lot more information than that. Answer these questions and you will find more helpful info...
What are the other settings on the machine set at? (cleaning percent, argon flow rate, etc)
What type and size tungsten are you using?
What size gas cup are you using
How exactly did you clean the metal?
What thickness of aluminum are you welding?
Is the material anodized?
What kind of weld are you making?
How big is your filler rod?
What does the weld look like? (color, texture, etc)
Pictures of the attempted welds would also help.
It is amazing to really sit back and think about how many considerations go into one tig weld. I remember one time I fought for days trying to figure out a problem welding aluminum, when I first got my machine. I would just burn huge, yellow holes in the metal with large black soot on the outside of the holes. I tried everything. I changed every setting I could think of. Changed the tungsten 20 or more times, changed argon bottles, changed ground cables, and countless other things. Finally I realized that I put the collet in my torch in backwards, and it was blocking most of my argon flow. I felt so stupid.
FourOnTheFloor65 is offline   Reply With Quote
Old 01-06-2011, 02:25 PM   #135
2milehi
Member#: 81633
'98 RS-T
I'll play along
4" air intake for a '73 Camaro
For a $180 Harbor Freight TIG, it works ok
2milehi is offline   Reply With Quote
Old 01-07-2011, 02:21 AM   #136
yo_its_ok
Member#: 6493
2003 WRX
Old 01-07-2011, 04:52 AM   #137
oguitar
Member#: 206720
2002 WRX Wagon
I don't want to ruin a good thread so I will stop hijacking and open a new thread with my welding questions. Thanks to all who replied.
Old 01-07-2011, 10:42 PM   #138
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
Originally Posted by yo_its_ok View Post
What did you wrap that in?
Old 01-11-2011, 08:52 PM   #139
downest
Member#: 194343
'88 4Runner daily
Finishing this thing up finally!
Old 01-11-2011, 10:13 PM   #140
PrecisionCustom
Member#: 207830
2002 Precision Built
Looks great
PrecisionCustom is offline   Reply With Quote
Old 01-12-2011, 10:44 PM   #141
yo_its_ok
Member#: 6493
2003 WRX
insulating foam known as armatex, something we discovered on the advice of one our clients who does contract work.
Old 01-13-2011, 02:47 PM   #142
sjs0433
Member#: 86061
I wish I had someone local that could teach me to weld.
sjs0433 is offline   Reply With Quote
Old 01-13-2011, 03:06 PM   #143
InfiniteMotorsports
Member#: 85354
I did too, then I read a few books, watched a DVD, bought a $2500 TIG welder, and learned.
Not ideal, but it worked
Old 01-13-2011, 05:41 PM   #144
sjs0433
Member#: 86061
^yeah I'm sure I could do that but unfortunately I don't have that kind of money to spend
Old 01-15-2011, 03:39 AM   #145
yo_its_ok
Member#: 6493
2003 WRX
there are decent tig machines for under 1000 brand new. add in consumables, and protection, you'll be up there. i was intimidated at first, but i learned it, and even when making mistakes, learned from it. I can confidently say I can tackle on almost anything.
Old 01-17-2011, 02:08 AM   #146
Valkyrie
Member#: 210971
just some quick snapshots from work. unfinished before they go off for xray.
Valkyrie is offline   Reply With Quote
Old 01-17-2011, 02:28 PM   #147
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
Where can I get some cake
Trying to weld 1/2in steel with a machine that only does up to 1/4... not so good
King of Poop is offline   Reply With Quote
Old 01-17-2011, 11:17 PM   #148
McRussellPants
Member#: 234144
crappy pictures but whatever. plus Boost Logic is lit about as well as a creepy old world dungeon.
AMS Drew and Colin at Toxic Fab are about my benchmarks for quality. I'll catch up someday.
McRussellPants is offline   Reply With Quote
Old 01-20-2011, 12:56 AM   #149
scubydrew
Member#: 32609
2005 saab 9-2x
rhd ej20tt sold...
Thanks and your not far off. I happen to be lucky to work with some really good guys. I'm still young in the game only 3.5 years working at the shop. Before that I spent a year in CT at welding school. I still have alot to learn. There are a number of people I look up to. I can only hope to someday be as good as they are now. If you look up to anyone have them teach you as much as you can absorb. Everything worthwhile is worth learning.
and if dungeon dark take your parts outside
scubydrew is offline   Reply With Quote
Old 01-22-2011, 12:53 PM   #150
orubus
Member#: 156455
2005 Aspen White STi
2 Supras - Truck for work
Real men weld on structural high rises right drew?
orubus is offline   Reply With Quote
Post Your Garages Here! Where do you keep your Subaru? RedefinedTR Member's Car Gallery 21 11-08-2009 01:19 PM
Post-Subaru Challenge #1: Post your comments here!! dowroa South East Region Forum 25 09-23-2004 09:01 AM
Impreza L's post your pics here! Pikeadon Member's Car Gallery 26 07-26-2001 10:49 PM
post your car here for ratings SubeDonC General Forum Archive 5 01-19-2001 09:22 AM
