09-23-2022, 11:50 AM | #1 |
Member#: 304111
2020 Sti g35-900 .83ar 94(acn91) pump gas
I haven't seen a whole lot of information on here with the new G35 series turbos so I thought I'd post up my setup.
CJM sleeved block with o-ring hg JE Ultra Pistons Manley Turbo Tuff I-beam rods 1/2" arp head studs GSC S2 cam GSC stock size valves GSC springs KB pickup/baffle Tomei UEL header ETS rotated kit COBB FMIC ID1300 injector Iag rails -6 lines (stock line from pump to firewall) Aeromotive FPR Aem 340 pump Exedy twin disk clutch Iag street motor mounts Mocal 19 row oil cooler with thermostatic sandwich plate We ran out of fuel as expected but before adding a surge tank and making things more complex I wanted to get the car running and any bugs worked out. At 26psi it made 490whp at 7300rpm and 431ft/lbs at 4600rpm on a dynojet Dyno at 82°f. It's hard to read but legible. A stock sti makes 250-260whp on this Dyno Last edited by SubieEJ; 09-23-2022 at 01:20 PM. Reason: Dyno sheet attached |
09-23-2022, 12:52 PM | #2 |
Member#: 508105
NWIC
Vehicle:Link G4X flex tuned 02' EJ205 20G 6MT wagon |
Sweet ride!
Any plans for ethanol? |
09-23-2022, 12:55 PM | #3 |
Member#: 304111
Thanks! It's been a dream of mine for a lot of years to do a build like this and I finally could.
I think so. I need to buy it by the barrel up here and it's not cheap at almost double the price of premium. I might grab a couple 30gal barrels at $320ea and when it runs out it runs out. |
09-23-2022, 01:10 PM | #4 | |
Member#: 508105
NWIC
Where are you located? The closest E85 station is 30 miles from my house and every so often I go up there with some VP cans and get ~56 gallons of fuel from the pump. Usually at or below the cost of premium. E85 is the turbo corn juice of the gods - once you try it, you never go back. |
09-23-2022, 01:17 PM | #5 |
Member#: 304111
100% on the bigger injectors! Over the winter I’ll be installing bigger injectors, surge tank, dual pumps, new lines, and I’m sure a few other things as well as trying to get my cooling setup sorted out better. I’d like to do a few track days next year and the car is currently running hotter than recommended.
There’s zero ethanol pumps here in Canada. Even finding a retailer that offers barrels for a reasonable price is tough. |
09-26-2022, 03:09 PM | #6 | |
Member#: 47143
btw, toronto is not part of "ACN91" status, the petro94 fuel here is great (that was for west coast 91 octane that had 0% ethanol and messed with the cobb staged tunes) |
09-26-2022, 06:32 PM | #7 | |
Member#: 304111
09-30-2022, 09:04 AM | #8 |
Member#: 260588
MWSOC
Vehicle:2019 WRX Sti Black |
Nice numbers for sure and I love the way that graph looks! Are the heads ported as well?
I have a similar build with a 6466 but I went standalone and I'm just waiting to get a map built to do the break in and I'll be heading to the dyno. |
09-30-2022, 10:06 AM | #9 | |
Member#: 304111
We tuned using Cobb at first and then EcuTek. Stand-alone might be in the future but for now I’m working on getting the car sorted properly which probably won’t happen before they start salting and the car is put away. Everything was delayed by two months so my goal of doing a track day by the end of this year is done The car will never be finished, I might post up some of the build as I did it all in my garage myself minus tuning and the long block. |
09-24-2022, 07:26 AM | #10 |
Member#: 57064
Vehicle:2008 STi IAG built HTA86 E85 Kel272s Cos IM |
Great numbers on pump and beautiful ride
09-24-2022, 09:24 AM | #11 |
Member#: 304111
Thank you. I spent a lot of hours researching and spent a few of those in your build thread.
Other than the long block assembly and initial startup all the work was done by me in my garage. It’s my first time doing most of this so it’s been a learning experience. Thankfully almost every question has been answered here as I haven’t had much support locally. |
09-26-2022, 12:36 PM | #12 |
Member#: 144044
South East
Vehicle:2006 STI OBP |
You might have more luck looking at suppliers/manufacturers for other industries than automotive. You would have to then mix it with gasoline to get whatever ratio you wanted. I didn't search for Canada specifically, but there are suppliers that sell from 1 KG up to 10 metric tons. And no, I don't know where you would store 10 tons of ethanol.
10-01-2022, 10:40 AM | #13 |
Member#: 526046
This thing is super clean. I made 473whp on my Garrett GTX3584RS on 24psi. I am currently changing up the setup. I am trying to see what a G35-1050 does for me next!
10-03-2022, 11:03 AM | #14 | |
Member#: 304111
I’d like to see how the 1050 does! Make sure to post up when you get some results. |
10-10-2022, 08:11 AM | #15 |
Member#: 524857
10-10-2022, 08:48 PM | #16 |
Member#: 92894
BAIC
Vehicle:2015 Wrx - fury kit silver duh |
10-10-2022, 10:45 PM | #17 |
Member#: 508105
NWIC
10-11-2022, 12:12 PM | #18 |
Member#: 524857
10-11-2022, 09:13 AM | #19 |
Member#: 304111
10-09-2022, 06:05 AM | #20 |
Member#: 92894
BAIC
Any videos? Haven't seen many subies with this particular turbo as well.
10-12-2022, 04:42 PM | #21 |
Member#: 167794
Vehicle:08 500+whp sti |
awesome chart, I just got my latest build tuned. made 460hp/430tq on a hub dyno @ 24psi using a VSR 5855.
that g35 -900 chart looks very similar to what I did, but I am on oem cams and a super basic piston/rod/stud motor. your setp is spooling 300 rpm sooner at least based on peak tq, which I think is the main thing I was wondering since I went with a more "budget" turbo. |
11-01-2022, 01:31 AM | #22 |
Member#: 179846
NWIC
Vehicle:07 STi Limited EFR 8474 TS EWG |
nice power band, seems like after 6.5k its starts to choke.
do you have waste gate duty cycle table pic? |
11-02-2022, 10:06 AM | #23 |
Member#: 304111
I don’t have one handay no. I’ve been chasing issues for the last month but if I get the car sorted this weekend I’ll take a log and post it up. Maybe lack of fueling?
11-02-2022, 10:24 AM | #24 |
Member#: 508105
NWIC
Check your IDC
11-04-2022, 01:50 AM | #25 |
Member#: 179846
NWIC
