Welcome to the North American Subaru Impreza Owners Club Wednesday October 9, 2024
Old 09-09-2005, 01:10 AM   #1
PastorBrian
Member#: 95584
Default Need help with emergency brake issue on 2000 Impreza 2.5 RS
I have a 2000 Subaru Impreza 2.5 RS vehicle with 4 wheel disk breaks. I have been troubleshooting a rubbing/scuffing sound coming from the right (passenger) rear wheel area. I thought that it might be a bad rear wheel bearing--but I had a local Subaru shop listen to it, and the tech thought it was a break rubbing. In the process of doing a rear break job including replacing rotors, cleaning and painting calipers and replacing pads I noticed that the rubbing sound is still there. I took everything apart on the right side and it rubs even with the caliper off and the rotor on. As soon as the rotor is removed it stops rubbing however. I can see where it seems to be rubbing on the inside of the rotor where the emergency break shoes are located. I have adjusted the shoes to the maximum and even loosened the emergency break handle (cable) inside the car, but it is still rubbing. Any ideas how to fix this problem? I am so frusterated that I am about to just take off the emergency break system altogether.
Thanks for any imput.
-Brian
PastorBrian is offline   Reply With Quote
Old 09-09-2005, 05:13 PM   #2
davis10
Member#: 70011
Rally Stuff
bump
davis10 is offline   Reply With Quote
Old 09-10-2005, 11:07 PM   #3
PastorBrian
Member#: 95584
Bump. Any ideas out there guys?
Oxygen Sensor problems on 2000 Impreza 2.5 RS Antonio Domit Subaru Conversions 4 09-25-2004 12:56 PM
FS - 2000 Impreza 2.5 RS - BRP - 5 speed - *pics* Slalom RS New England Impreza Club Forum -- NESIC 29 07-25-2003 08:57 AM
FS - 2000 Impreza 2.5 RS - BRP - 5 speed - New England *pics* Slalom RS Private Vehicle 'For Sale' Classifieds 8 07-24-2003 11:09 AM
Oxygen Sensor problems on 2000 Impreza 2.5 RS knoffer Warranty Issues & SOA Problems 20 12-12-2001 05:04 PM
Oxygen Sensor problems on 2000 Impreza 2.5 RS knoffer Normally Aspirated Powertrain 11 12-03-2001 01:42 AM
