Brakes & Suspension Forum sponsored by The Tire Rack |
10-31-2002, 01:23 PM | #1 |
Member#: 11556
Vehicle:2002 impreza wrx blue |
what should i do next for '02 wrx sedan....please help
first thing my buddy got was 17 inch rims and bridgestone s03's and a more aggressive allignment....then he put on a cusco rear sway with mrt endlinks...what next???....he doesn't want to spend a ton of money...maybe $500-$1000 or less and wants to increase the handling without jeopordizing the feel...car feels more "darty" since installing the rear sway bar and endlinks...also has the short shift kit, STI engine and tranny mounts
any suggestions??? thanks in advance
10-31-2002, 02:04 PM | #2 |
Member#: 23676
NESIC
Vehicle:. |
MANY worthy options
I would say springs, but that will definately change the ride
Although he could do H&R or Eibach prokits with Koni adjustables, and that would only be roughly 900 IF he does the work himself, it will still ride nicely, because hte springs are very close to the factory rates. But for less money and still a good benefit WHITELINE ANTI-LIFT KIT |
10-31-2002, 03:20 PM | #3 |
Member#: 11556
any other suggestions....changing the front swar, will that help at all on the sedan
10-31-2002, 03:27 PM | #4 |
Member#: 23676
NESIC
Vehicle:. |
Front sway bar
Well, heres the thing, Making the front bar larger WILL do huge things for body roll, but it will also make the car push more in hard/under power turns. It all depends what you are looking for.
I myslef am going to do the front bar, BUT I am going to be spending close to 3500 dollars on my suspension, so I will still have a VERY balanced car. If 80mph highway off/on ramps are your thing, then go for it!!! |
what should i do next for more power??? | SB347 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 15 | 08-09-2008 02:07 AM |
what should i do next? help guys | GDArex003 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 02-22-2007 05:28 PM |
what should i do next? | adamrmr | STi Forum Archive | 0 | 08-09-2003 02:37 PM |
('93-'01) What should I do next? | ashtaron14 | Impreza Forum | 9 | 10-02-2001 10:07 PM |
('93-'01) What should I do next???? | 2.5rsMI | Impreza Forum | 6 | 06-16-2001 12:22 AM |
