Old 11-13-2012, 07:35 PM   #1
Coop1103
Member#: 162063
2007 STI FR TS 8374
UGM
Default Large Fuel Pumps--DW300 or new AEM?
Has anyone tried the new fuel pump made by AEM. I am looking for something that flows higher than the sub standard Walbro because I will be running 1300cc injectors with 450+whp. I have heard the DW300 is nice however knowing that the AEM just was released (cheaper than DW) did not know if it was a "get what you pay for" product?
Coop1103 is offline   Reply With Quote
Old 11-14-2012, 12:36 PM   #2
mackeymx
Member#: 258525
2004 STi-BW7670
R6-Red/White
Based on how relatively cheap fuel pumps are to begin with, I would go with a proven pump such as the DW300. I just swapped out my 255lph with one as I am going with 1200cc injectors. Good luck.
mackeymx is offline   Reply With Quote
Old 11-14-2012, 01:30 PM   #3
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
The DW300 will probably not be able to feed those injectors. It can only flow around 1100cc/inj worth of fuel (depending on boost level). Certainly better than the Walbro's 850cc/inj, but still not enough for 1300cc injectors.
Old 11-14-2012, 01:43 PM   #4
apexslider
Member#: 168101
15 BRZ Limited
SS
I'm running the DW300+ pump with DW1300 injectors, and it's fine for about 21psi on my 35R setup. It does want to drop off in voltage on the higher end though (known issue with these pumps). Some guys run a relay, some guys opt for a surge tank with another pump.
I was around 419awhp on pump gas and 502awhp on C16. So the pump can do it
apexslider is offline   Reply With Quote
Old 11-14-2012, 04:40 PM   #5
Coop1103
Member#: 162063
2007 STI FR TS 8374
UGM
Damn it prob won't cut it. I should be pushing 500whp. Yes my block is built. What are my other options? Do I buy another walbro to run both?
Old 11-14-2012, 06:51 PM   #6
apexslider
Member#: 168101
15 BRZ Limited
SS
I plan on running a surge tank with an additional pump (in the surge tank). I did hear of a retro fitted double pump hanger for two DW300+ pumps. Never saw it, but sounded plausible.
With that kind of power I would want a surge tank
Old 11-14-2012, 07:21 PM   #7
Coop1103
Member#: 162063
2007 STI FR TS 8374
UGM
Where can I find this surge tank....any threads on this? Guess this is set up in the trunk?
Old 11-14-2012, 10:12 PM   #8
apexslider
Member#: 168101
15 BRZ Limited
SS
Yeah you can search here. Most are custom. Radium makes a nice easy to conceal tank. I've seen a few in person, nice setups.
