Welcome to the North American Subaru Impreza Owners Club Monday August 20, 2018
Old 05-16-2006, 02:12 AM   #1
designfate
Member#: 114502
Default tell me what you think about my WRX plans
Hey all, im just going over all the stuff i plan on doing to my car (in the near future) and i wanna know what you think!
For the first few mods, id like to go with the Crucial catback, Helix downpipe with high-flow cat, Helix up-pipe. To top off the power for a while so i can regain some funds and pay for gas, id like to get the Cobb AccessPort. I will be good with the Stage2 Setup for a while.
After all that good stuff, im looking at the HKS intake, HKS SSQ BOV, Perrin radiator hoses.
What do you guys think about that setup? Shoudl i change anything?
If needed to know, i have an 02WRX
designfate is offline   Reply With Quote
Old 05-16-2006, 02:25 AM   #2
-Kevlar-
Member#: 82378
<--- Hot Donuts Now
well you dont need the intake, the bov, or the rad hoses.... instead get intercooler hoses and swaybars.....
-Kevlar- is offline   Reply With Quote
Old 05-16-2006, 02:30 AM   #3
designfate
Member#: 114502
sway bars are most likely coming within the next week or two
Old 05-16-2006, 02:38 AM   #4
-Kevlar-
Member#: 82378
<--- Hot Donuts Now
everything else is fine.... but read BEFORE the other stuff i mentioned...
Old 05-16-2006, 02:43 AM   #5
Davenow
Member#: 23676
Dont do an intake. No gains to be had on the stock turbo, can sometimes cause problems.
Dont do the BOV, it will make you slower, and possibly make your car run poorly.
Dont do radiator hoses, they are a waste, and Perrins leak through the braids half the
If you have this money leftover, and are getting an AP, then you REALLY should have at least a boost gauge. The AP isnt going to be in the car, hooked up, where you can read it, ALL THE TIME. Which means you will be totally unaware if something goes wrong. An EGT gauge would be nice to have at that stage of the game as well. I have seen several AP cars with severe EGT problems. (any basemapped EM can have this happen, again, without the gauge, you will have no idea its happening, high EGTs dont usually show any symptoms, until its too late, and the prolonged high temps have melted a ring)
Then
Do intercooler hoses
Maybe do a crank pulley (lightened, not underdrive) I like the cobb unit.
Old 05-16-2006, 02:43 AM   #6
MartinD
Member#: 57231
i would get tires before anything else...
MartinD is offline   Reply With Quote
Old 05-16-2006, 03:05 AM   #7
designfate
Member#: 114502
Davenow - Thanks for all that info. I thought that the things i listed were okay to get after a certaina mount of modding. Guess i will save about 400 bucks. This may sound noob, but i really dont know how to read the gauges you listed. Where can i learn about that? Beucase i agree with you 100%. When you guys say intercooler hoses, what benifits do i get from them?
MartinD - I have brand new Yokahomas
Old 05-16-2006, 03:20 AM   #8
-Kevlar-
Member#: 82378
<--- Hot Donuts Now
http://forums.nasioc.com/forums/showthread.php?t=533787
^^^^read here
what guages are you talking about? boost?
Old 05-16-2006, 03:21 AM   #9
designfate
Member#: 114502
boost and EGT, what are the differences? Sorry, haha, i never really botherd to study up on gauges Thanks for helping me though!
Old 05-16-2006, 03:30 AM   #10
-Kevlar-
Member#: 82378
<--- Hot Donuts Now
basically.......
boost- usually measured in psi, measures pressurized air from the turbo. a stock wrx is around 13.5 psi. some, like the stock unit, measure in mpa. the reading for a stock wrx is ~.08 mpa. stg 2 would be around .11 mpa or 16 psi.
egt- is for exhaust gas temp. basically keeping check on how hot its getting inside the cylinders. im usually around 1600 at wide open throttle in 5th.
Old 05-16-2006, 03:36 AM   #11
designfate
Member#: 114502
Would a stock STi boost gauge be good enough? I think i have a friend that has one for sale. Also, what gauges do you recommend for easy reading and good price value? Im now thinking about getting a Defi style gauge cluster to mount in place of the clock. What other guage would be good?
Old 05-16-2006, 03:42 AM   #12
-Kevlar-
Member#: 82378
<--- Hot Donuts Now
sti is the same as the wrx im sure.... so it would be fine.... just do some searching on here.
Old 05-16-2006, 03:52 AM   #13
designfate
Member#: 114502
i just dont know what to look for, i see some gauge sthat are 40 bucks and others that are 170. I searched here but didnt find much.
Old 05-16-2006, 03:59 AM   #14
-Kevlar-
Member#: 82378
<--- Hot Donuts Now
look in the product review forum....
Old 05-16-2006, 04:09 AM   #15
WRX2FFU
Member#: 73872
EJ25 ,EJ22,EJ20,EA82
Originally Posted by wrxblubayou
basically.......
1600 is too hot imo If i hit 1500 i back off.
WRX2FFU is offline   Reply With Quote
Old 05-16-2006, 04:11 AM   #16
-Kevlar-
Member#: 82378
<--- Hot Donuts Now
its getting up there yes, but remember i said WOT in 5th, thats a huge load that normally doesnt get put on the engine..... you should be over 1500 or at least around that WOT any gear above 1st...
Old 05-16-2006, 04:32 AM   #17
subaru3169
Member#: 55252
* pullup bar *
suspension first buddy.. that'll take up quite a penny itself
on our type of cars, suspension is most important.. especially bugeyes<i have one>.. the come crap from factory<alignment specs>
subaru3169 is offline   Reply With Quote
Old 05-16-2006, 04:40 AM   #18
designfate
Member#: 114502
i think it handles really well stock, actually. I was just gonna do sways and struts, then maybe springs if i needed them.
Old 05-16-2006, 04:56 AM   #19
-Kevlar-
Member#: 82378
<--- Hot Donuts Now
springs, sways, and maybe struts... it all depends on what YOU want. some people will say susp. first, others say go fast stuff....
Old 05-16-2006, 06:56 AM   #20
WRX2FFU
Member#: 73872
Nope. I run 5th gear wot just under 1500. I have never seen over 1500 in any gear but 5th at wot and i got out of it quick. MY egt probe is in the manifold on the drivers side.
I still would not ever like to see above 1550. It would worry me. I am paranoid though.
This is kind of OT. He definately needs a boost gauge and an EGT gauge. Imo any turbo car should at least have a boost gauge. Also +1 for swaybars, I put on my rsb and it should have been the first thing i did.
Old 05-16-2006, 07:46 AM   #21
-Kevlar-
Member#: 82378
<--- Hot Donuts Now
also mines not completely accurate....oops... its reading of the ecu during datalogging....
Old 05-16-2006, 08:53 AM   #22
MartinD
Member#: 57231
Awesome. People usually keep the stock 92s around for too long
Old 05-17-2006, 12:25 AM   #23
WRX2FFU
Member#: 73872
That makes sense.
Old 05-17-2006, 03:32 AM   #24
dlroto
Member#: 109443
2015 WRX Premium
Sounds like a plan.
dlroto is offline   Reply With Quote
Old 05-17-2006, 03:49 AM   #25
-Kevlar-
Member#: 82378
<--- Hot Donuts Now
although i wouldnt trust em enough to push them in the snow/heavy rain/inclement weather, they are not a bad tire for everyday driving..... on public roads, if you are doing something that they cant handle, its probably illegal....
OT computer gurus. Tell me what you think about my new rig. trisk Off-Topic 37 05-02-2006 04:02 PM
Tell me what you think about looks of HKS Hyper Exhaust ProdriveRex Member's Car Gallery 42 06-28-2004 06:28 PM
OT: Tell Me What You Think About This? KurleeDaddeeWRX Bay Area Impreza Club Forum -- BAIC 14 09-23-2002 12:50 PM
Tell me what you think about this wheel. Subi-fied Brakes, Steering & Suspension 26 06-14-2002 01:36 AM
Tell me what you think about this combo (good and bad) 2.5rsMI Normally Aspirated with bolt-on Forced Induction Powertrain 5 10-28-2001 10:00 AM
