Welcome to the North American Subaru Impreza Owners Club Tuesday February 20, 2018
Old 10-27-2001, 10:07 PM   #1
scootr
Member#: 2649
00 2.5RS-t cpe BRP
64 chevelle SS
Default SS Voltage clamp and J&S question
First of all I need to know how to hook up the voltage clamp. Also I have the instructions on how to hook up the J&S, but am not sure what "to the loom" and "from the plug" means. These were the terms used in the instuctions I found on a thread on where to cut and splice the wires in. On the number 25 and 26 wires I guess you have to splice in two different places on the same wire? Any help?
-scootr
scootr is offline   Reply With Quote
Old 10-27-2001, 10:23 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
You have to split the wire (cut it) and 'to the loom' means away from the ECU, ie. to the motor. 'To the plug' means to the ECU connector, ie. the one going towards the ECU.
The split second clamp has instructions as well... get those and the ECU pin ut from the web and you're set.
8Complex is offline   Reply With Quote
Old 10-27-2001, 11:02 PM   #3
scootr
Member#: 2649
00 2.5RS-t cpe BRP
64 chevelle SS
Ok so one plug goes into the ecu and one goes to the engine. I think I got it now. Which wire do I splice the SS voltage clamp into?
Old 10-28-2001, 05:19 AM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
The MAP voltage wire. You need to split it and put one wire to the sensor side and one wire to the ECU side. It's pretty easy, just gotta make sure which is which. Oh, and it needs power and ground as well (duh).
WTBS: SS volt clamp and front o2 sensor MadMax New England Impreza Club Forum -- NESIC 3 06-09-2005 04:39 PM
Link2 and J&S question N/A Normally Aspirated with bolt-on Forced Induction Powertrain 3 01-26-2003 08:09 AM
Voltage clamp and Super AFC the spacecowboy Normally Aspirated with bolt-on Forced Induction Powertrain 4 12-06-2002 01:30 PM
SS Voltage Clamp Help Wedge Engine Management & Tuning 7 11-21-2002 12:43 AM
Random Questions: MAF sensor / J&S Safegaurd / Voltage Clamp tsfxRS New England Impreza Club Forum -- NESIC 1 07-29-2002 11:40 PM
