Welcome to the North American Subaru Impreza Owners Club Wednesday January 22, 2020
Old 11-28-2019, 11:04 PM   #1
65bellett
Member#: 402054
Default Rear Subframe bushing spacers.
Hi guys. I have started turning up some Delrin bushings for my Budget Track Bugeye. Does anyone have any of the rear subframe spacing bushes on hand that the might be able to measure for me? The below pic is just for reference I donít want to be accused of stealing anybodyís proprietary design.
So far Iíve made some bushes for the rear diff carrier bracket and a set of lock bolt sleeves. This is all experimental as Iím learning as I go but hopefully it should work.
65bellett is offline   Reply With Quote
Old 11-29-2019, 09:33 AM   #2
Bru1212
Member#: 178770
06 STi
17 Fozz
I have the ones on the left that wonít get used if you want them. I donít have an accurate way to measure from home but I can on Monday.
Bru1212 is offline   Reply With Quote
Old 12-05-2019, 07:46 PM   #3
65bellett
Member#: 402054
Cheers for the offer bru1212. The dimensions would be great at anytime as I am running the car in itís first Hillclimb this weekend and then we have a 6 week break over Christmas so the car will be up on stands being played with over that time.
After a few bushes some cheap coil overs and a good 4 wheel alignment it is certainly turning in and hooking up nicely but it seems to have a bit of bumpsteer so I will be trying to fix that as well.
Old 12-05-2019, 08:13 PM   #4
Bru1212
Member#: 178770
06 STi
17 Fozz
I forgot, Iíll get measurements tomorrow and pm you
Old 12-06-2019, 06:34 PM   #5
Bru1212
Member#: 178770
06 STi
17 Fozz
Pmíd you the measurements
Old 12-09-2019, 05:17 PM   #6
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
Could you share those dimensions with the class? I'm trying to find a bushing to replace some obsolete OEM parts and if these are close, I could just buy Impreza bushings.
car_freak85 is offline   Reply With Quote
Old 12-10-2019, 05:54 PM   #7
Bru1212
Member#: 178770
06 STi
17 Fozz
Edit because this has been TICs’ bread and butter for a long time.
If you haven’t tried the race version it really makes a difference. I ended up buying
the comfort version after the race as it was too much for me. I’m not even
sure what the ones on the left are for it’s been like 10yrs
Old 12-10-2019, 06:47 PM   #8
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
dude - if you're going that far then just drop the subframes, push out the old bushings, and make full replacements. No point in putting sandwich pieces in there if you're making parts.
Old 12-11-2019, 02:36 PM   #9
car_freak85
Member#: 13530
EJ205
Can you tell me the dims (length, OD, lip OD, lip thickness, etc) for your EJ rear diff bushings? If they work as replacements for the XT6 & RX I'd love to scoop some bushings up from you guys!
Old 12-22-2019, 12:47 PM   #10
65bellett
Member#: 402054
That is what I will be doing now. The new race season doesnít start until the end of January so I have a bit of time up my sleeve to make the car immobile for a while.
