Welcome to the North American Subaru Impreza Owners Club Sunday January 26, 2020
Old 06-13-2010, 03:54 PM   #26
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
I think the pill is the same per turbo; I know for sure WG spring pressure is different year to year as stock max PSI is different year to year.
As has previously been stated I would just go for a new EBCS or MBC, stock BCS is crap anyway.
OrbitalEllipses is online now   Reply With Quote
Old 06-13-2010, 04:09 PM   #27
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
Originally Posted by While At Rome View Post
well thanks for jacking my thread. Jer;embo go read up so u know what parts are supposed to be there
I am missing the restrictor pill in my inlet-to-T vac line. is there a part no i can get from autozone or do i need to get that from the dealer??? If that doesnt fix it, new boost control it will be.
There are a few yards around here, is the vac line/pill the same for 02-05, or even more cars?
Thanks, Bill
Sorry didnt mean to jack your thread but your post related to my problem.
Jerembo47 is offline   Reply With Quote
Old 06-14-2010, 01:39 PM   #28
While At Rome
Member#: 247550
09 STI
ok im going to pick up an MBC today. hopefully that fixes it.
Another important question... If i DC the OE boost controller and use say a turbo xs mbc, do i need a re-tune, even if i run it at 13.5 psi?
While At Rome is offline   Reply With Quote
Old 06-14-2010, 03:15 PM   #29
XanRules
Member#: 157348
180+ IQ Genius
Mindset Lifestyle
yes. Definitely yes.
XanRules is offline   Reply With Quote
Old 06-14-2010, 05:33 PM   #30
While At Rome
Member#: 247550
09 STI
are you sure?
after researching, im pretty sure that i will be fine running 13.5 or 13 with an 02. I bought the Perrin MBC.
Old 06-14-2010, 05:37 PM   #31
Chi_San
Member#: 53558
2005 Baja Turbo
White/Silver/Black 3tone
it'll throw a code, and go into limp mode. On top of that, MBC behaves totally differently than an EBC, so get tuned.
Chi_San is offline   Reply With Quote
Old 06-14-2010, 06:59 PM   #32
snobordboi
Member#: 149130
2002 WRX,
2010 X5M
On top of that, since there was obviously some type of boost control system on there before, it may (hopefully) have been tuned for it, and is only safe right now since you arent building much boost. I would get the boost control situation sorted, and get it tuned as quickly as you can, and don't hit high boost levels until tuned.
snobordboi is offline   Reply With Quote
Old 06-15-2010, 01:59 AM   #33
samneumann
Member#: 245075
I am having the exact same problem, i just put in a boost gauge and it reads im only boostin like 6 to 7lbs also. Im pretty sure im not leaking boost, and my BCS is good. what is this pill that needed for vaccum hoses?
samneumann is offline   Reply With Quote
Old 06-15-2010, 02:19 AM   #34
XanRules
Member#: 157348
180+ IQ Genius
Mindset Lifestyle
start your own thread, please.
Old 06-15-2010, 02:46 AM   #35
Jeffman44
Member#: 239072
2005 WRX Wagon
white
are you sure?
research "partial throttle, full boost" or PTFB. It is a condition created by manual boost controllers. the EBCS won't let you hit full boost unless you are on the throttle hard.
running a manual boost controller will give you a lean condition while not WOT causing risk to your engine.
Jeffman44 is offline   Reply With Quote
Old 06-15-2010, 12:22 PM   #36
While At Rome
Member#: 247550
09 STI
Im thinking about getting it tuned. What tuning options are out there?
i got an up-pipe and an MBC right now. Im not trying to go anything more than 15 psi as this is my daily driver. it may lead to an exhaust and an FMIC, but that is to be decided.
Old 06-15-2010, 12:25 PM   #37
WhyHelloOfficer
Member#: 193989
2007 Stormy Blue
Blown Roadster
So we can have 3 threads on the first page of the 2.0 Tech Boards that say "I too, am only hitting 7psi?"
You, need to do a lot more reading. FAQs are your friend.
http://forums.nasioc.com/forums/show....php?t=1169980
WhyHelloOfficer is offline   Reply With Quote
Old 06-15-2010, 12:57 PM   #38
While At Rome
Member#: 247550
09 STI
ive read almost all of that before i even bought my car, and then read it again to try and figure out wtf is going on.
If you read it, it simply says "talk to your tuner for best options" for about every single mod and fuel management question.
I know im hitting wg pressure, my EBCS is not working, but electrical tests that i did according to the shop manual says that it is, or should be. And every single thing says ECM failure. This leads me to believe that the ECU is tuned, and coverted back to stock in a half ass way. I pulled off the kickplate on the passenger side and the ECU clips look like they had been removed a few times.
Old 06-16-2010, 02:49 AM   #39
While At Rome
Member#: 247550
09 STI
regardless wtf ends up being the source of this ****, im goin down to cobb tomorrow and talking to them about accessport. MBC and a tune will be more fun no matter what.
Old 12-06-2014, 11:14 PM   #40
huezo_e
Member#: 408009
Was the problem fixed?
If so what was the fix?
huezo_e is offline   Reply With Quote
Old 12-08-2019, 02:57 PM   #41
Rljs
Member#: 476120
2000 RHD JDM Bugeye
I know this is an old thread but I was searching through here while trying to figure out why my car would boost maybe once or twice and the be limited to wastegate pressure for the rest of that drive or even a week at a time. I determined my maf sensor was shot so if all your other tests from above check out look into it. As I did the bcs and it was fine. If you need rock auto sells maf that are cheaper just to test if it fixes your problems.
Rljs is offline   Reply With Quote
Stage 2 WRX Only Puts Down 214 hp? Is This True? Turbo20VJetta Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 11-02-2005 09:38 PM
alternator only putting out 12.4 volts yellowscooby New England Impreza Club Forum -- NESIC 1 06-06-2005 03:27 PM
Only 7 PSI boost with STi Tanman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 12-03-2004 12:26 PM
How Many CFM's of air does the stock WRX turbo put out? BrysImpreza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-02-2002 07:55 PM
Help! My WRX is Only Putting Out .5 bar (7psi) of Boost clsmooth71 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-01-2002 10:49 AM
