Welcome to the North American Subaru Impreza Owners Club Sunday January 19, 2020
Old 06-19-2016, 08:48 PM   #1
andrewalex11
Member#: 448328
Default Fuel filter symptoms?
My car is giving me a slight jerking'ish popping kind of type deal under very heavy loads when i hit peak boost, and ONLY when I hit peak boost, I can give it 3/4 throttle right unter peak boost and everything is good but as soon as I cross over into that WOT threshold it gives me the issue.. No codes being thrown my CEL is clean.
andrewalex11 is offline   Reply With Quote
Old 06-19-2016, 09:38 PM   #2
hijinks
Member#: 440839
2003 WRX
Damn that sucks
hijinks is offline   Reply With Quote
Old 06-20-2016, 03:53 AM   #3
andrewalex11
Member#: 448328
not fuel filter issues.. wonder what it could be..
Old 06-20-2016, 10:20 AM   #4
86Dreams
Member#: 385256
V7 S204
'19 Giulia Q4
thats a tough a description to work with but it sounds kind of like spark blow out. check the spark plug gaps and if the gaps are >.03 then replace them. if you have iridium plugs(tiny electrode) be carefulusing a coin style gapping tool as it can damage the elctrodes.
Also inspect your ignition coils. worn out coils can cause a similar phenomena.
86Dreams is offline   Reply With Quote
Old 06-20-2016, 04:21 PM   #5
andrewalex11
Member#: 448328
you think these issues would only present themselves at peak boost WOT ?
Old 06-22-2016, 01:28 PM   #6
Atomicgtr
Member#: 348450
I'm havig the same issue I think. I just started checking my vacuum lines but I'll be checking my plugs then for sure. I have a version 8 ej207. It gets more jerky the higher the rpm
Atomicgtr is offline   Reply With Quote
Old 06-26-2016, 02:40 PM   #7
Cobrakai
Member#: 176408
2005 EJ207 STy
I was having similar issues with bucking/popping sounds at WOT, replaced my plugs and all is well.
IIRC you can find the OEM sparkplugs on amazon for quite cheap.
Hope that helps.
Cobrakai is offline   Reply With Quote
Old 05-09-2019, 08:10 AM   #8
junior05wagon
Member#: 499626
Default FPR or fuel filter
Any one figure out what there problem was . I have an 05 wrx wagon thats starts and drives perfect but under WOT i sputters at times and i get a miss fire CEL as soon as i let off it goes back to normal . No boost leaks has new injectors new coils new plugs timing is good vacc lines good .. Y'all feed back would be awesome thanks
junior05wagon is offline   Reply With Quote
Old 12-08-2019, 05:50 PM   #9
WRXXXED
Member#: 432652
2010 Subaru WRX STI
61K (Gray)
Same thing with me, replaced sparkplugs and coil packs, boosts fine under less than 12lbs of boost, anything more and it studders and throws a misfire on cyl 1 code, going to replace the fuel filter and see how it does 👍🏻
WRXXXED is offline   Reply With Quote
Old 12-09-2019, 02:54 PM   #10
subaru_gc8
Member#: 29292
2004 WRX wagon
your coils might be starting to go
subaru_gc8 is offline   Reply With Quote
