Welcome to the North American Subaru Impreza Owners Club Wednesday January 29, 2020
Old 12-10-2019, 07:22 AM   #1
AVANTI R5
Member#: 73805
Default 2021 Volvo S90 Slated To Arrive Next Year
The Volvo S90 is scheduled to receive a mid-cycle revamp thatís expected to debut in 2020 for the 2021 model year. Once Volvo finally applies the finishing touches on the facelifted model, the S90 will feature mainly visual changes on the outside, but the Swedish firm might also tweak the sedanís infotainment system to keep up with its rivals. It may even introduce the mild-hybrid powertrain brought by the freshly-revised XC90.
Volvoís flagship sedan is due for a refresh thatís slated to arrive next year
The Volvo S90 is scheduled to receive a mid-cycle revamp thatís expected to debut in 2020 for the 2021 model year. Once Volvo finally applies the finishing touches on the facelifted model, the S90 will feature mainly visual changes on the outside, but the Swedish firm might also tweak the sedanís infotainment system to keep up with its rivals, and it may even introduce the mild-hybrid powertrain brought by the freshly-revised XC90.
A big question mark for now is how (and if) the S90ís interior will change. Volvoís prowess for nicely laid out cabins that are also comfortable and high-quality suggests the carmaker wonít fiddle too much with an already perfect recipe.
Technical Spotlight: Volvoís T6 Four-Cylinder
The Impeccable Interior of the 2017 Volvo S90
2021 Volvo S90
Year:2021 Make:Volvo Model:S90 Price:Luxury car segment:midsize cars size:Mid-Size Purpose:Family Cars body style:sedan
EXTERIOR
New Grille Redesigned Front Bumper New Fog Lights LED Matrix Headlights 3D Design For The Taillights Redesigned Rear Bumper New Body Colors And Wheel Designs
leftright
The current Volvo S90 has a sleekness of its own, which sets is apart rather nicely from the likes of Mercedes-Benz S-Class, BMW 7 Series, and Audi A8. This means that given the matured design, Volvo wonít try to shake things up too much, so expect a rather subtle set of tweaks.
As far as we can tell from the spy photos sent in by our carparazzi, those changes will touch down on the lower parts of the front grille. Speaking of which, the Volvo Iron Mark grille is likely to morph into a design thatís more similar to the V60 and V90 Cross Country. We also expect the facelift to bring LED Matrix headlights for the Swedish sedan, judging by the new light cluster pattern and redesigned fog lights. Fret not, though, as the Thorís Hammer design is here to stay at least until an all-new Volvo S90 comes to replace the current generation.
leftright
Moving to the rear end, the camouflaged taillights suggest a new design, but we canít spot any changes in size or shape for the time being.
Volvo could, however, adopt a 3D design of sorts to add more visual depth to the rear clusters. Rounding up the changes list in the back is the reworked lower section of the rear bumper. That said, we doubt Volvo will tweak other aspects of the S90ís exterior, although itís customary for a mid-life refresh to bring a couple of new wheel choices and perhaps one or two additional body colors just too keep things interesting. Needless to say, the sedanís dimensions and proportions will not be affected in any way.
Volvo S90 exterior dimensions
Length: 200.1 inches
Width (incl. mirrors): 79.5 inches
Height (incl. shark fin antenna): 57.1 inches
Wheelbase: 120.5 inches
Track (front): 64.1/63.7 inches, depending on rim size
Track (rear): 64.1/63.7 inches, depending on rim size
Ground clearance: 6 inches
Weight: 4,819 pounds
INTERIOR
Some New Materials Crispier Infotainment System Minimum Changes Needed
The S90 gets a luxurious cabin
We canít help but ask: is it really necessary to tweak the S90ís interior? We believe the answer is no and as such, we donít think Volvo will make any major tweaks in this regard anyway.
Volvo might add some extra personalization options or even new materials to adorn the sedanís cabin, but that would be pretty much it.
On a more personal note, weíd like the infotainment system to offer a crispier user experience similar to what the S90ís rivals have in store. However, our photographers didnít get a chance to capture the carís interior on camera, so thereís not much to speculate on.
In all fairness, sans the improvements that could be brought to the infotainment setup, itís hard to push the quality higher inside the S90 without crossing to another price range. Volvo has been receiving a lot of praise for its interiors both in terms of design and quality, so thereís no need to overcomplicate things at this point. After all, if ainít broke, donít fix it, right?
Volvo S90 interior dimensions
Headroom: 37.8 inches
Front leg room: 42.2 inches
Rear leg room: 40.4 inches
Front hip room: 56.4 inches
Rear leg room: 54.9 inches
Cargo volume: 15.4 cubic feet
DRIVETRAIN
Mild-Hybrid Tech On The Cards Current Lineup Should Stay The Same T6 AWD, 316 Hp, 295 Lb-Ft T8 EAWD PHEV, 400 Hp, 472 Lb-Ft
Rumor has it that the S90 will receive Volvoís mild-hybrid tech already available for the recently revamped XC90 SUV, which also has a kinetic energy recovery braking system thatís said to contribute to up to 15 percent fuel savings and emission reductions in rear world driving conditions.
But until Volvo officially confirms or denies the introduction of such technology for the S90 sedan, weíll have to look at the current engine lineup.
In the U.S., the 2020 Volvo S90 is available with two powertrain options: T6 AWD and T8 eAWD Plug-in Hybrid. The T5 powertrain used to be on the table as well, but for some reason Volvoís online configurator doesnít include this one for the 2020 S90. For the sake of the argument, however, weíll mention that this choice relies on an inline-four turbocharged gasoline engine displacing two liters. Output is rated at 250 horsepower and 258 pound-feet of twist.
Coming back to the two options loaded into the online configurator, the T6 AWD has the same 2.0-liter mill as the T5 only itís also supercharged for more grunt. As a result, the engine now makes 316 horsepower and 295 pound-feet of torque handled by an eight-speed automatic transmission and all-wheel drive.
The T8 eAWD takes the same turbocharging and supercharging recipe used by the 2.0-liter mill but takes it to the next level with the addition of an electric motor good for 87 horsepower.
All-wheel drive is also on the menu while the systemís overall power goes up to 400 horsepower, while torque takes a hike to 472 pound-feet. Itís unclear whether Volvo will bring any sort of improvements to these existing powertrains, but chances are it wonít.
PRICES
Once the facelifted 2021 Volvo S90 becomes available on the U.S. market, its price tag is bound to go up a notch. While we canít pinpoint the exact asking price, the least we can bring into discussion is the flagship sedanís pricing at the time of writing. The most affordable S90 is the Momentum model that starts at $51,195. It is followed by both the R-Design and Inscription trims, as they both require at least $54,295. However, if the T8 eAWD Plug-in Hybrid trim is specified, then the starting price tag jumps to $63,845. Also keep in mind that this hybrid powertrain can only be had with the R-Design and Inscription trim levels, while those opting for the S90 Momentum will have to make do with the T6. That said, we could extrapolate and say that
the revised S90 Momentum could start at around $53,000-$54,000, while the other two trims, R-Design and Inscription, might kick off at $56,000-$57,000.
COMPETITION
Mercedes-Benz E-Class
The Mercedes-Benz E-Class is one of those cars blessed with a flawless interior thatís hard to go up against. Those looking to get the E-Class in the U.S. wonít complain of being short of options, as the sedan can be had in three guises E 350, E350 4Matic, and E 450 4Matic. The entry-level E 350 starts at $54,050 and relies on a 2.0-liter inline-four turbocharged engine that produces 255 horsepower and 273 pound-feet of torque channeled towards the rear wheels through the nine-speed 9G-Tronic automatic transmission.
If itís all-wheel drive you crave, then the E 350 4Matic picks up where the E 350 left off and adds such a gimmick without changing the engineís power and torque coordinates. Lastly, the E 450 4Matic comes to please those looking for more grunt. Its 3.0-liter bi-turbo V-6 makes 362 horsepower and 369 pound-feet of torque for a 0-60 miles per hour sprint cleared in five seconds flat.
On top of those variants sits the Mercedes-AMG lineup that includes the E 53 and E 63 S sedans. The former uses an AMG-tweaked 3.0-liter inline-six thatís also turbocharged and paired to the companyís EQ Boost tech for 429 horsepower and 384 pound-feet of torque. 0 to 60 miles per hour happens in 4.4 seconds. The real king of the hill, however, gets a handcrafted 4.0-liter bi-turbo V-8, which blesses the E 63 S with 603 horsepower and 627 pound-feet of torque for a 0-60 sprint attainable in 3.3 seconds.
BMW 5 Series
Arguably the sportiest of the executive sedan bunch, BMWís 5 Series is trying to lure in customers with several guises. Thereís the 530i and 530i xDrive making 248 horsepower for a 0-60 miles per hour sprint of 5.9 and 5.8 seconds respectively, but thereís also the more powerful 540i and 540i xDrive which rely on 335 horsepower for a 0-60 time of 4.9 seconds and 4.6 seconds, respectively. Then thereís the M550i xDrive and its 523 horsepower, capable of sprinting from 0 to 60 miles per hour in 3.6 seconds. And if you happen to prefer a plug-in hybrid 5 Series, BMW will gladly sell you the 530e and its xDrive peer. Both are good for 248 horsepower, enough to let them accelerate from 0 to 60 miles per hour in 5.9 seconds.
Audi A6
The Audi A6 is, too, available in the US of A as the 45 TFSI quattro and 55 TFSI quattro. If youíre still confused by Audiís engine nomenclature, allow us to clear the air. The Audi A6 45 TFSI quattro relies on a 2.0-liter turbocharged straight-four engine good for 248 horsepower and 273 pound-feet of torque sent to all fours via Audiís famed all-wheel-drive setup. If thatís not enough for your taste, then you can go for the Audi A6 55 TFSI quattro, which stands for a 3.0-liter turbocharged V-6 with 335 horsepower and 369 pound-feet of torque on tap. If thatís still too soft, maybe the Audi S6 is what you want. It uses a 2.9-liter bi-turbo TFSI V-6 tuned to churn out 444 horsepower and 443 pound-feet of torque, enough to complete the 0-60 miles per hour sprint in 4.4 seconds.
CONCLUSION
The facelifted Volvo S90 is coming, but donít expect it too display a radically-changed exterior. Subtle changes are the way to go for Volvo and weíre happy that the Swedes are not overdoing this revamp for two reasons: 1) the S90 is already a fine-looking sedan and 2) thereís no point in changing things up and thus face the possibility of offsetting a perfectly good recipe that gives the S90 its very own, unique personality. Thatís something you donít see too often in the age of gaping front grilles and fake exhausts.
Old 12-10-2019, 07:30 AM   #2
AVANTI R5
Member#: 73805
Default Spy Photos Volvo S90 Motor Authority Source
Volvo's S90 sedan will come in for a round of mild updates, as evidenced by a lightly camouflaged prototype spotted during a recent round of cold-weather testing.
The changes will mirror those introduced this year on the updated 2020 XC90 and include a revised grille, new wheel patterns, and new color and trim options.
The most significant change will be under the hood, namely the introduction of mild-hybrid technology across the range. This is essentially a belt-driven motor-generator that can recover energy under braking and then store this for later use. On the XC90, Volvo said the system can improve fuel economy by 15 percent.
The S90 T8 plug-in hybrid should also benefit from a small bump in power and a bigger battery. In the 2020 XC90 T8, the battery size was bumped up from 10.4 to 11.6 kilowatt-hours.
Don't expect major changes in the cabin, though additional electronic driver assist features are likely.
The updated S90 will be launched alongside similarly updated versions of the related V90 and V90 Cross Country next year as a 2021 model. The changes represent a mid-cycle refresh for the current-generation S90 which arrived in 2016 as a 2017 model.
Old 12-10-2019, 07:42 AM   #3
AVANTI R5
Member#: 73805
Default Volvo V90 and S90 range to be updated with mild-hybrid tech
olvo is planning a mid-life refresh of its S90 and V90 large saloon and estate ranges, and winter testing shots show the models with minimal disguise.
We can see that external changes will be subtle, given the development team hasn’t really bothered to disguise these prototypes. If you look closely you can see tape obscuring the lower grille and bumper details, suggesting small cosmetic tweaks, but otherwise it appears that the S90 and V90’s design won’t be altered greatly.
There will be more significant revisions under the skin, however. Chief among which will be the adoption of 48V mild-hybrid technology, already found in the refreshed XC90 and XC60, across most of the line-up.
The system combines a 48V battery with an integrated starter/generator and energy recovery system, capturing kinetic energy during braking or coasting and using it to boost overall efficiency. It’s expected that, instead of the ‘T’ and ‘D’ badges to signify petrol and diesel variants, both fuel types will be badged ‘B’, with B4, B5 and B6 variants found in the XC60.
OUR VERDICT
Volvo V90
The Volvo V90 is less dynamically poised than some rivals, but it's still a deeply compelling machine
A six-cylinder petrol engine and a bigger battery work wonders for BMW's...
Further changes are likely to be incremental, with equipment upgrades across the line-up and small revisions to the car’s infotainment software. The T8 plug-in hybrid is expected to carry on unaltered, but Volvo could introduce a more sportily tuned ‘Polestar Engineered’ model to top out the range.
Given the timeline of the facelifted XC90, first launched in 2015, expect the three-year-old S90 and V90 to be updated in the middle of 2020 and go on sale towards the end of the year.
