#1 |
Member#: 509181
![]() Hi guys ! New to the site ! Would love some insight on my issue here , or to hear of any people experiencing this themselves .
Today I had went to but a new diverter valve on my rebuilt 2017 wrx 6mt with 19000km on it , and as I looked into my turbo I could see that the fins on the wheel were chipped , 3/6 of the fins are badly chipped the other 3 are almost fine , has anyone els had this happen to them with such low mileage ? It almost seems as if my turbo had sucked somthing in, if anyone has any insight or thoughts pls let me Know ! anyways thanks guys
#2 |
Member#: 416873
NESIC
Vehicle:2015 WRX |
![]() A lot of info missing here. Why was it rebuilt? Past and present mods, ect.
#3 |
Member#: 509198
![]() Hard to say need more info that lead to finding out
#4 |
Member#: 509181
![]() Sorry ! Car is completely stock other then axel back borla exhaust, car was rebuilt from a front right end crash needed a new hood , bumper , and rad support , car is acting completely normal but I just found it out when I went to change my bypass valve
#5 |
Member#: 483407
Vehicle:2004 Mitsubishi Montero Sport |
![]() They are definitely not supposed to look like that. Something may have broke off in the cold side during the accident while the engine was running.
#6 |
Member#: 182415
Vehicle:1999 RS Aspen White |
![]() They had a recall where the inlet came apart and sucked in parts, and its also likely something broke from the accident as its right behind the rad/support. I would definitely get a used replacement or have a new wheel put in there soon.
#7 |
Member#: 428511
Vehicle:2016 STI |
![]() no question some metal went through that, it had to end up somewhere, most likely in your intercooler and stopped.
Certainly won't hurt anything, just reduces efficiency of the fan as long as there's no more burs ready to let loose |
#8 |
Member#: 125887
AKIC
Vehicle:2001 EJ207 V7 RSTi, Mica Blue |
![]() I would be more worried about where that FOD ended up
#9 |
Member#: 90539
South East
Vehicle:My BOV goes COVFEFE! |
![]() That wheel is toast, get rebuilt or new turbo asap. Also look downstream, hopefully the big pieces stopped in the intercooler...which I'd also throw out. Something obviously got sucked in and destroyed those blades, and some bits may have even made it past the intercooler, small as they would have to be. I'd remove the intercooler and intake manifold and thoroughly clean the manifold and toss the intercooler. Not worth keeping, a small piece could become dislodged and cause a valve to stay open long enough to misfire under boost and cause other problems.
#10 |
Member#: 419354
Vehicle:2007 STI Crystal gray metallic |
![]() The wheel has relatively low inertia, but it spins in the ballpark of 150k rpm. That sucker is waaaayyyy off balance and has definitely seen some debris. I would replace it.
