Welcome to the North American Subaru Impreza Owners Club Monday July 16, 2018
Old 06-23-2011, 11:35 PM   #26
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
Originally Posted by n2oiroc View Post
hey guys, 93 with ethanol is still *gasp* 93 octane. its superior to 91, dont be stupid.
if 10% ethanol is bad, how bad is 85% ethanol ZOMG!!!!!!
aerosaaber is offline   Reply With Quote
Old 06-25-2011, 11:30 AM   #27
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
Gasoline for cleaner air
Your use of gasoline with detergent additives will help prevent deposits from forming in your engine and fuel system. This helps keep your engine in tune and your emission control system working properly, and is a way of doing your part for cleaner air. If you continuously use a high quality fuel with the proper detergent and other additives, you should never need to add any fuel system cleaning agents to your fuel tank.
Many gasolines are now blended with materials called oxygenates. Use of hese fuels can also help keep the air cleaner. Oxygenated blend fuels, such as MTBE (Methyl Tertiary Butyl ether) or ethanol (ethyl or grain alcohol) may be used in your vehicle, but should contain no more than 15% MTBE or 10% ethanol for the proper operation of your SUBARU. In addition, some gasoline suppliers are now producing reformulated gasolines, which are designed to reduce vehicle emissions. SUBARU approves the use of reformulated gasoline.
jonklein611 is offline   Reply With Quote
Old 06-25-2011, 12:14 PM   #28
n2oiroc
Member#: 141952
18 golf arrrr!
n2oiroc is offline   Reply With Quote
Old 06-25-2011, 12:59 PM   #29
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
yew drank the kool-aid......didnt ya
Old 06-25-2011, 01:06 PM   #30
Qcanfixit
Member#: 135762
2059 Venturi Skimobi
transparent aluminium
for a 'gasoline' engine, ethanol on the principle that it's cleaner and slightly more sustainable than the other options.
otherwise, we should be looking at running diesel engines on bio-diesel made from vegetable oil.
henry ford designed his car to run on ethanol from hemp, a renewable resource we are perfectly capable of growing in abundance -- hemp practically grows itself, it also is highly resistant to pests and requires very little if any pesticides.
Qcanfixit is offline   Reply With Quote
Old 06-25-2011, 01:10 PM   #31
Airplay355
Member#: 213825
2013 BRZ
You guys think you have it bad? In Maine there is no 93, period. I'm stuck with 91 + ethanol no matter what. Yay Maine...
I can't wait to get out of this state.
Airplay355 is offline   Reply With Quote
Old 06-25-2011, 01:31 PM   #32
Uncle Scotty
OK buy Nates beans
trust me when I say you are FAR - FAR better off than most
Old 06-25-2011, 01:57 PM   #33
wrx~god
Member#: 58755
satin white pearl
sad to say I have 92 with 10%. My 04 ran perfect before our state switched to 10%. After the first 2 full tank fills... my car went to crap. Yup...that nice solvent you put into your tank upon fill up everytime does wonders to clean your gas tank.. and junk up everything down the line.
I work on boat motors and without going into detail.... screw whoever thought using corn based alcohol for a gas mixture was a good idea...lol.
wrx~god is offline   Reply With Quote
Old 06-25-2011, 02:18 PM   #34
jonklein611
Member#: 117776
WR Blue Pearl
Just quoting the owners manual there Scotty.
Old 06-25-2011, 02:49 PM   #35
SomethingNew
Member#: 180287
2004 WRX
If you're worried about quality (octane), anyone who thinks gas with ethanol is worse is stupid. It may get you worse gas mileage, but really for E10(93 + 10%), the loss in mileage is ~3%. Many E85 tunes make MORE power than say 93 or 91 octane tunes. Koenigsegg decided to design the CCXR to run E85 tunes... The E85 version makes 200+ more HP than the gasoline version. From the wiki about Ethanol fuel, "E85 is a high performance fuel, with an octane rating of about 104, and should be compared to premium."
SomethingNew is offline   Reply With Quote
Old 06-25-2011, 03:15 PM   #36
Uncle Scotty
OK buy Nates beans
the owners manual is, at least in part, for idiots and fools
this is one part
Old 06-25-2011, 03:45 PM   #37
n2oiroc
Member#: 141952
18 golf arrrr!
You summed it up. Ethanol is clean and gas leaves varnish and dirt behind. Why that makes ethanol bad i dont know.
Old 06-25-2011, 04:19 PM   #38
wrx~god
Member#: 58755
satin white pearl
Forgot to mention its water absorbing properties are great for engines also. Cleans twice as good. Thats why I trust going on my boat with ethanol gas. I just love to hear my engines sputter with clogged injectors..or carbs... waiting to die on me. At least I know my fuel lines and tanks are clean..lol.
Old 06-25-2011, 04:42 PM   #39
naimouasta
Member#: 47998
2002 WRX Wagon
2008 Legacy QSM
where i usually get gas, there's a 10cent difference usually between 87, 89, and 91; but only 2-3 cent difference between the 91 and 93. i believe most places (if not all?) just bump the octane from 91 to 93 by adding ethanol. same with the places that have 92, they use ethanol to bump the 89 to 92 is my guess. the pumps usually say "up to 10% ethanol", so the amount is probably different depending on the octane.
i don't have a turbo so i usually just use 89, but my brother has a wrx. he gets a bit better gas mileage using the 91.
also i don't know anything about tuning but i read some thread a while ago where they had a higher injector duty cycle for 93 vs 91.
naimouasta is offline   Reply With Quote
Old 01-14-2013, 07:12 PM   #40
dcwiker05
Member#: 227864
1995 Impreza L WRX
Aegean Blue Metallic
I know I know, holy thread revival batman, but I thought asking in here would be better then starting a new thread.
My question is I have access to ethanol free gas through my job for a good price. Problem is it is 87 octane. Could I use an octane booster additive to get it up to 91/3 or should I not bother and just run 91/3 with ethanol?
dcwiker05 is offline   Reply With Quote
Old 01-14-2013, 09:07 PM   #41
Mr645
Member#: 320769
2012 WRX 5 door
You wont get 87 up to 93 with any additive. Other then a slight loss of milage, there really is not big issue with 93 that has "Up to 10% Ethanol". The main thing to watch for is the issue that Ethanol absorbs water from the air, and fuel guidelines give E10 blended fuels a 4 week lifespan from when the fuel is delivered to the gas station. Most people will tell you that the 4 weeks is conservative. I have had the stuff sit in my bike for 10 weeks in humid south Florida and had no issues. But also down here, most car dealers will tell you about customers that come back from spending the summer up North and find that their cars don;t run right and the injectors are plugged up and the fuel is no good after 6 months at the "summer home".
Mr645 is offline   Reply With Quote
Old 01-15-2013, 03:12 AM   #42
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Here in fl in just a few weeks of sitting I have ha fuel injector issues on brand new gixxers running 93
Old 01-15-2013, 08:37 AM   #43
Jack
Add Lightness
Member#: 13699
not my president
(From General)
Have you ever seen a new boat with problems? When I bought my 4 Winns, everyone seemed all hyped about ethanol. I asked at the marina and they told me that it was a problem for older boats with tons of crud in the tanks. The ethanol brings the crap into the gas and so you're running on the water and crap that's been in there for years. My understanding is that it's like dry gas and takes all the moisture out of the system. With my boat, I had no problems ever. I trailered, so almost never used marine gas....it all came from the station on the way to the lake.
This thread needs a pole. I'd check off the "I use 87 with ethanol" option.
Old 01-15-2013, 10:13 AM   #44
mrkyle3
Member#: 272675
2002 Corvette Z06
Ethanol has the molecular formula CH3CH2OH. It is a unique molecule in that it is amphipathic. This means it has both polar and nonpolar characteristics, with the hydroxy (OH) group responsible for its polar character and the CH3CH2 responsible for its nonpolar character. This means that, while it is miscible with largely nonpolar gasoline, it can also mix with water. Adding ethanol to gasoline should, in theory, increase the solubility of water in gas because the ethanol molecules could form micelles around the water, with the polar hydroxy group of ethanol interacting with the polar water and the nonpolar tails of ethanol sticking out into the gasoline. This, in effect, shields polar water from nonpolar gasoline.
While the addition of ethanol-infused gas to your boat may be bad for it because of the extra stuff in your tank (I'm no expert), based n my understanding the amount of water that would be added to the gas would be negligible. Further, water is a byproduct of combustion anyways so it likely would have no effect on the engine. The crud, however, is another story. However I believe that the crud at the bottom of your tank is insoluble in general and thus the addition of a semi polar solvent wouldn't change anything. So yeah I doubt gas with ethanol would be bad.
mrkyle3 is offline   Reply With Quote
Old 01-15-2013, 03:33 PM   #45
VinceCarter
Member#: 284694
2006 WRX 6 Speed
277/323 @ EFI Logics
"Southern Maine"
Not close enough to get 93 in NH? I'm pretty sure I'm correct that NH has 93, right?
VinceCarter is offline   Reply With Quote
Old 06-21-2015, 01:09 PM   #46
Botwin
Member#: 390514
2015 WRX Limited
Stewart's Shops in upstate NY are now selling ethanol free 91 octane. I have been using Sunoco Ultra93 exclusively. I am going to try this for a few tanks and see if there is any difference..
Botwin is offline   Reply With Quote
Old 06-21-2015, 01:33 PM   #47
Zeeper
Member#: 299286
2017 Legacy Limited
Originally Posted by soup_notzee View Post
another reason to hate NY.... I want ethanol free!
Try Stewarts
91 ethanol free is available at many Stewart's shops near my house.
It isn't available in the winter, but now you should be able to find it easily!
BTW Stewart's doesn't seem to carry 93 octane, but I refill with 93 when it is available over 91 at other gas stations.
(PS, just saw Botwin suggest the same thing...LMAO....)
Old 06-21-2015, 01:43 PM   #48
575rider
Member#: 112024
03 WRX 6sp wgn
'12HondaFit, C Bronson
There's a station here with 92 non ethanol VS. other stations 93 with 10% ethanol. Have run in it for 2 tanks now and get 1.5 mpg better mileage. It's $0.65 more per gallon but true fuel cost is $0.20 vs $0.22 per mile, pretty insignificant. Car feels better with the non, too.
575rider is offline   Reply With Quote
Old 06-21-2015, 03:39 PM   #49
I Like Cooters
Member#: 394806
Originally Posted by Botwin View Post
Stewart's Shops in upstate NY are now selling ethanol free 91 octane. ...
It's true, and here's a list of their locations which carry it: http://www.stewartsshops.com/news/et...-select-shops/. Somebody should run some comparison tests.
I Like Cooters is offline   Reply With Quote
Old 06-22-2015, 07:41 AM   #50
bigmaninjapan
Member#: 299064
2008 VF52 WRX Sedan
2016 Ford Transit Connect
^^^ What he said.
Somewhere in Nebraska:
Untitled by ch0ng, on Flickr
bigmaninjapan is offline   Reply With Quote
FS : FREE box of Legacy junk 91-94? FREE bape-ape TXIC Private Classifieds 0 07-25-2010 12:08 PM
Sex with any girl of your choice 5x, or your choice of any one car with insurance -=C=- Off-Topic 184 01-10-2010 09:02 PM
Cobb Stage 2 91 or 93 Map in OR/WA jjimpreza North West Impreza Club Forum -- NWIC 28 04-25-2006 02:06 AM
AP 93 or 91 octane questions drfrink24 Engine Management & Tuning 3 05-31-2005 11:59 AM
choice of color? Silver or White or Blue? sshus924 Interior & Exterior Modification 39 05-07-2004 05:35 PM
