Welcome to the North American Subaru Impreza Owners Club Sunday July 15, 2018
Old 09-20-2004, 05:33 PM   #1
SuBart
Member#: 2956
06 Sti-white Stg 2
98RS-rally blue
Default How long will they last...
Whats the most mileage you guys seen on a 98-99RS? And does anyone think the 98DOHC can hit 200k?
SuBart is offline   Reply With Quote
Old 09-20-2004, 05:36 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
If its maintained proplerly, im sure it could go 200k.
I sold my 98 RS with 113k on it.
Jay
Old 09-20-2004, 05:41 PM   #3
SuBart
Member#: 2956
06 Sti-white Stg 2
98RS-rally blue
I used to have a 98 but didn't take care of it too well (young and stupid back then). I'm thinking of buying another one just cause I miss it so much. I found a few with 90K miles for around $9500. I'm just worried about the headgasket issue and what condition the tranny is in. You guys think I should go for it?
Old 09-20-2004, 06:03 PM   #4
Brad Pittiful
Member#: 34931
. Super bowl LII
Champions!
buy it and change the head gasket...then you wont be worrying about it
Brad Pittiful is online now   Reply With Quote
Old 09-20-2004, 06:13 PM   #5
Keshav
Member#: 1654
2017 MX-5 RF LE
MV Agusta Brutale S
I'd be more worried about the oil pump seal and the timing belt. Check it for oil leaking from the front of the engine.
HG failure is always a possibility, although a lot of us have not had the problem (knock on wood)
I'll bet it has clutch shudder when cold. Mine does.
Check to see if the AC blows cold. That seems to go out frequently. Something to do with the location of the condenser and road debris, rocks?
Check the trunk for leaks. look under the spare for puddles or water damage to the particle board panel.
They're great cars aside from a few warts.
Keshav is offline   Reply With Quote
Old 09-20-2004, 06:48 PM   #6
SuBart
Member#: 2956
06 Sti-white Stg 2
98RS-rally blue
Sounds good.
How many miles you got on yours Keshav?
Stock Potenza, How long do they last? RAPTR Tire & Wheel 20 04-27-2006 04:53 PM
How long will they last? chevelle100 Normally Aspirated with bolt-on Forced Induction Powertrain 13 09-02-2005 07:04 PM
Tread wear of 140. How long do they last? txl146 Tire & Wheel 35 04-10-2005 02:40 PM
Hoosier R3S03s - how long will they last? jmott Motorsports 17 03-16-2003 08:37 PM
OEM Struts - How long do they last? macrac Technical Forum Archive 7 07-12-2000 06:51 PM
