08-31-2009, 10:45 AM | #1 |
Member#: 180861
Vehicle:2005 IAG Closed Deck Larry's Power built heads |
The Shop CT Junior Tuned 05 vf34
This past weekend i had the chance to get my05 wrx tuned down at the shop by Junior. Definitely a cool place and cool people. The donuts were pretty bad ass too. Previously I had been tuned at another shop and put down 280 Hp and 265 Tq at a little over 18 psi. on a dyno dynamics. I decided to go with a catless downpipe and a set of grimmspeed manifolds with crossover pipe. My baseline pull at The Shop was 286 HP and 268 Tq. We then removed the Snorkus in the stock air box and did another pull and gained 10 Hp. Before the tune my prodive boost contoller was swapped out for a manual one. Final numbers after Junior worked his magic were 310 Hp and 320 Tq at 22 psi! Spool comes on much faster. The new HP actually overlaps my old tq curve as the turbo spools. So Much more area under the curve and still makes 300 Hp and 220 tq at redline. Juniors said we probably could of squeezed out a couple more Hp, but i was running out injector.
Mods list: 2005 wrx 27000 miles Snorkus delete AFE drop in filter Invidia uppipe and catless downpipe Maddad Catback vf 34 turbo grimmspeed ported manifolds with crossover 06 injectors Spearco top mount one step colder plugs manual boost contoller fuel pump Andrewtech PPG close ratio gear set. Act stage 1 clutch |
08-31-2009, 11:21 AM | #2 |
Member#: 68647
Vehicle:07 STI 35R 05 BMW M3 ZCP |
Wow, great numbers! Any particular reason you switched tuners? Just curious...
A bit tough to say the reason for the gains, isnt it? 4 more psi of boost plus ported exhaust manifold should net you a nice chunk of power and a huge increase in torque. Also the MBC and exhaust manifold can/will get the turbo to spool faster. |
08-31-2009, 12:25 PM | #3 |
Member#: 114631
Vehicle:2009 GTR, 735whp 13' Benz, 15' WRX |
Wow, holding 300 at redline along with that trans, this car is going to go fast. Good luck with it!!
08-31-2009, 12:31 PM | #4 |
Member#: 220098
Vehicle:2009 Leggy GT |
dyno sheet?
08-31-2009, 01:23 PM | #5 |
Member#: 180861
Its a no brainer why i switched Tuners. Junior does good work! My old tuner told me my car was happy at 18.3 psi and would not push it any harder. Yes ported manifolds and catless downpipe make more power, but i know my old tuner would not have gotten this kind of power out of my set up. This thing rips!
08-31-2009, 01:24 PM | #6 |
Member#: 180861
no dyno sheets unless some one is willing to post them for me. Send me an e-mail and i will responds later tonight.
08-31-2009, 01:39 PM | #7 | |
Member#: 68647
08-31-2009, 04:18 PM | #8 |
Member#: 180861
Thanks. No worries.
09-02-2009, 07:26 PM | #9 |
Member#: 199906
Vehicle:2008 Infiniti G37S World's quickest: 11.13" |
I happened by The Shop, checking on my own progress when this tune was underway. Yes, it not only made more power and torque, but Jimmy and Junior both agreed the AFR was safer than before they touched it. It's having your cake and eating it, too.
Congrats! Coop |
09-02-2009, 10:56 PM | #10 |
Member#: 180861
ya it was running pretty lean before.
Similar Threads | ||||
Latest installation / tune packages from The Shop CT!! | Visconti | Tri-State Area Vendor Classifieds | 10 | 09-18-2010 01:04 PM |
The Shop CT Tuning, Installation Specials & WaCkY WeDnesDaYs!! | Visconti | Tri-State Area Vendor Classifieds | 59 | 04-04-2010 11:22 PM |
The Shop CT Holiday Tuning, Installation Specials & WaCkY WeDnesDaYs!! | Visconti | NESIC Vendor Classifieds | 14 | 02-23-2010 07:29 PM |
Got My 2006 WRX Tuned At The Shop CT today :) | 02 wrx sleeper | Proven Power Bragging | 9 | 12-20-2009 09:02 PM |
The Shop CT | patsy630 | Tri-State Area Forum | 28 | 06-26-2008 10:00 PM |
