#1 |
Member#: 12692
Vehicle:bust a move check it out i'm rockin' steady |
![]() Was at the track and noticed I could not get more than 14.5psi's of boost...If at part throttle cruising and then jumping on it, I could hit 16psi's what I set it for, but from a stop at the track it was limited to only 14.5psi's to redline? I am running a Turbo XS MBC. I also have a ABC which I'll see if that solves anything, but I confused?
Mods include: PSP uppipe Unichip - Stage 1 Turbo XS MBC Thanks, Nirmit
#2 |
Member#: 7185
Vehicle:2014 CLA 45 AMG White |
![]() I too have noticed this, I can replicate it on the street by dragging away from a stop. Do you have the TXS HP-MBC or just the standard TXS MBC ? I found by adjusting the ball&spring to within 1psi of my target boost and then adding the last 1psi with the bleed screw (I have an HP-MBC) I would get better boost on the strip. However it will boost-spike more on the street, setup in this way. So for the street I back off the ball&spring and use the bleed screw for 2-2.5psi of my target boost.
One last point to note, if your MBC is fixed on or very near to a heat source it will drop boost as it gets hot. If you notice your boost drops off by 1-2psi after running for a while, pop the hood and with caution test the temp of the MBC by hand. If it feels hot to the toutch them you need to move it to a new location away from heat. This is NOT a fix for a HEAT SOAKED engine, just a heat soaked MBC ![]() |
Possible problem with Zerosports Air Intake Pipe (replaces accordian) | BlueDemon | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 17 | 11-21-2002 11:12 PM |
HELP! Problem with MBC | Rallyman5 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 15 | 09-08-2002 04:37 PM |
Problem with MBC -> stock BC ... | Dougeefresh | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 11-20-2001 09:22 AM |
What are the potential problems with MBC? | Yellow Rex | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 07-13-2001 11:13 AM |
Possible problem with St Helen meet | jeffg | North West Impreza Club Forum -- NWIC | 0 | 01-18-2001 05:49 PM |
