Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 02-28-2003, 07:03 PM   #1
romoranger
Member#: 14701
94 camaro
big cam/heads/slicks
Default running too rich
it seems to me that my car has been running waaaay to rich. my egt's are not coming anywhere close to 1400, and the one time i tried getting them up by driving at 5k rpm for about a minute i hit the 1340 mark. just wanting to be sure that this is ok, or if my car is running super rich.
and would it be possible that a reset ecu would help, as i have installed a downpipe and unpipe and not reset it yet
romoranger is offline   Reply With Quote
Old 02-28-2003, 07:15 PM   #2
codean
Member#: 10186
Where did you install the egt probe?
codean is offline   Reply With Quote
Old 02-28-2003, 07:16 PM   #3
romoranger
Member#: 14701
94 camaro
about an 1.5" after cylinder 4
edit: ok, maybe 2"
Old 02-28-2003, 11:16 PM   #4
tdxflex
Member#: 13634
1340F or 726C, seems a bit on the low side, not that it's bad or anything. i've got my probe the same distance from the heads as you. the closest setup to you that i've had is an uppipe and bosal downpipe and stock ecu, and i would hit about 790C max , 1454F (4th gear WOT uphill). when i was running a unichip with it i could get up to 840C which is a bit higher than i would have liked. all you have is the vishnu uppipe and helix downpipe, right? you could reset the ECU and do some runs to get the ECU to adapt to a different driving habit/pattern, that would probably make a difference.
tdxflex is offline   Reply With Quote
Old 03-01-2003, 12:38 AM   #5
romoranger
Member#: 14701
94 camaro
i will reset the ecu tomrrow morning and see how that goes. i hope it kind of fixes it because i know how super rich i am considering the color of the tail pipe after driving catless for only 3 days
Old 03-01-2003, 01:05 PM   #6
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
I'm guessing it's all black with soot? Mine's like that, too, and I have a turbo XS exhaust with a cat.
rex n effect is offline   Reply With Quote
Old 03-01-2003, 01:18 PM   #7
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
I just finished a round trip to California, and I noticed a difference in my egt's with the change of gas formulations. With the wintergas at home, I was seeing about 1300 as the temp at 70mph in 5th. But with the summer formulations in the south, I was getting a tad over 1400. Food for thought.
fragment is offline   Reply With Quote
Old 03-01-2003, 02:35 PM   #8
romoranger
Member#: 14701
94 camaro
i reset this morning, i will see what the egt's are at when i take it out for a drive later
Running too rich, what to do (UTEC) EJ205rulezall Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 04-24-2004 04:00 PM
running too rich AndreWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-07-2003 03:06 PM
running too rich! Haase14 Mid West Subaru Owners Club Forum -- MWSOC 3 04-22-2003 02:37 PM
Running too rich...will intake help? KillerRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-10-2002 07:57 AM
Can running too rich for too long throw a CEL? Bighurt1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-26-2002 05:57 PM
