Welcome to the North American Subaru Impreza Owners Club Sunday January 20, 2019
Old 05-07-2003, 02:14 AM   #1
AndreWRX
Member#: 35802
2005 Pontiac GTO
Yellow Jacket Yellow
Default running too rich
02 WRX, 3" turbo back high flow cat, APS large top mount, Aem intake, samco tubing into VF30 turbo, STi injectors, walbro 255 l/ph fuel pump, w/ Unichip and Pruven catless upipe. Car is sitting at Pruven Performance, at idle car is demanding tons of fuel as though my foot was in it. Things checked and/or replaced thus far, fuel pressure regulator, unichip, ECU, EGT probe, compression test excellent, pressure test fine. They are checking the MAP sensor and getting back to me and have been excellent to me. Any suggestions are welcome to helping to solve this problem?
AndreWRX is offline   Reply With Quote
Old 05-07-2003, 02:44 AM   #2
Matty
Member#: 13408
2008 LGT
black
Default I've been reading
The MRT performance forums for awhile now...many guys over in Australia are running VF30's,28's23's.. at fairly high boost with only a fuel pump upgrade...and using the 440cc injectors and good engine management, they've been at this longer than we have...so maybe there is something to this..They seem to be going to bigger injectors with the Vf22 at high boost...like 18-20 and even more psi
Matty is offline   Reply With Quote
Old 05-07-2003, 01:53 PM   #3
AndreWRX
Member#: 35802
2005 Pontiac GTO
don't think that's the issue, the guys at Pruven tune the car and set the fuel amount via Unichip, the car seems to be panicking and thinking its running ultra lean, maybe a bad 02 sensor? Someone help, my car has been there for over a week, I miss it!
Old 05-07-2003, 02:20 PM   #4
nizz
Member#: 188
2004 Forester XT
24k gold on white
Try taking out the Unichip and then start the car and see if it still idles rich. If it idles fine after you remove the Unichip, then it is more than likely that the fuel map on the Unichip is bad.
nizz
nizz is offline   Reply With Quote
Old 05-07-2003, 03:06 PM   #5
AndreWRX
Member#: 35802
2005 Pontiac GTO
Thanks guys, I appreciate all replies. If you read my post, I have listed everything they have already tried such as removing the unichip and letting the car run with stock ecu, replacing Unichip, egt probe, MAF, etc. I wish it were something that simple.
Running too rich, what to do (UTEC) EJ205rulezall Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 04-24-2004 04:00 PM
running too rich! Haase14 Mid West Subaru Owners Club Forum -- MWSOC 3 04-22-2003 02:37 PM
running too rich romoranger Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-01-2003 02:35 PM
Running too rich...will intake help? KillerRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-10-2002 07:57 AM
Can running too rich for too long throw a CEL? Bighurt1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-26-2002 05:57 PM
